Everything posted by ccoyle
Indio, eh? Make sure your AC unit is in good working order!
Very well told, Mark. All of us here were beginners at some point, so we can all (well, most of us at least) relate to that first reaction upon seeing the unpacked kit. Good luck with your project!
Micro-Make angled grinder from Micro-Mark
ccoyle replied to Kevin Kenny's topic in Modeling tools and Workshop Equipment
I fixed up your title to help clarify the possibly confusing relationship between the manufacturer, Micro-Mark, and the name of the product line, Micro-Make. I think their marketing department was perhaps trying to be just a tad too clever. -
Wow! That is more models than I would probably complete in several lifetimes -- and all very well done! I have to confess that I did not know until just yesterday that Ragusa is the old name for the modern city of Dubrovnik in Croatia. The only reason I found out is because an old high school friend is honeymooning there. It's a beautiful city with a fascinating history. Cheers,
Hello, watchtinker. The answer to your question depends in some measure on what kinds of vessels you are interested in. There's plenty of suitable beginner-level kits out there, but not all of them will suit your fancy -- or budget.
Hi, William. 1. Use any plastic modeling cement, such as Testors, or CA (cyanoacrylate), e.g. Zap. 2. Just eyeball the thread size, but keep in mind that it's better to err on the narrow side -- looks better on the finished model. 3. The shininess might be due to a releasing agent used in the molding process. It can't hurt to give the parts a wash in mild soapy water, rinse, and dry. 4. There's a wide range of both enamel and acrylic paints available for plastic models. Acrylics are easier to work with, since they are water-based. If there's no painting guide in the kit, then use the box art to get a rough idea of colors to use. EDIT: I see Canute beat me by one minute! Cheers,
We've had one or two build logs started for models from this company. Try searching for Mariefried or Bohuslan in the kit logs section.
Feeling overwhelmed is normal; eventually you'll have to choose a technique and have a go at it -- maybe you'll like it, but maybe you won't. All part of the learning curve. For deck caulking -- yes, you can use pencil. If you do a search on "caulking", you'll find many threads whose authors use a variety of methods. Testing your selected method on a piece of scrap and applying your varnish to check for possible smearing would be wise. Plank shift patterns varied by nation and time period. Only the most learned viewers of your finished model will notice whether you used the correct pattern or not. The three butt shift was typical for English ships of that period. The nails you refer to are actually wooden dowels, and the task is called treenailing; search that term and you'll find lots of suggestions. Modelers who use treenailing can either use actual treenails (or trunnels), like the toothpick method you mentioned, or simulate them. Done well, treenailing adds a lot to the look of a model; done poorly, then not so much. Personally, I do not do treenailing on my models, because on actual vessels they weather along with the planking and are virtually impossible to see at stand-off viewing distances. Lots of decisions for you to make -- don't sweat it too much, and have fun!
- 6 replies
- deck planking
- caldercraft
Fantastic models!
Mike makes an excellent point. You'll run into some other situations with this kit where the suggested build sequence will need some careful consideration with regards to later structures and additions.
- 126 replies
- fly
- victory models
This tid-bit of info might be too late for you, but those "lateral planks" are a kit feature that is designed to divvy up the planking into zones -- supposed to be easier for beginners. They're not a historical feature. You can leave them out if you want to.
- 126 replies
- fly
- victory models
Welcome, Gunnar. The short answer to your question is yes, all of those methods will work. To some degree you will need to experiment and see which method you like best. The porosity of the wood you use for decking will affect how well those techniques that require a liquid medium (e.g. paint, markers) will work. Holly is a popular wood for decking, but since I tend to stick with kit materials, I will let some of our more knowledgeable members give you advice on that topic. Cheers,
Based on my very limited experience with Corel (one kit -- woo-hoo!), this is not likely to be the last difficulty you encounter. Of course, such problems exist in just about any kit, but Corel in particular seem to put less effort into their lower-end offerings compared to their top-of-the-line models.
Bit out of the way for me, but let me know if you ever do a show somewhere on this side of the pond.
Feedback will likely do little good. The reason for that is that these companies tend to do a single print run of the product, and when that is sold out, that's pretty much all she wrote. Off the top of my head I don't know of any instances in which Halinski has done a reprint. They do, though, offer corrected parts, but these are printed as part of some subsequent offering of a different subject. Not exactly convenient, but that's the way they do it.
Hi, Quincy, and welcome. The San Juan Nepomuceno is a substantial undertaking! Right away I can see some potential for problems with your planking technique. Fortunately, we have some resources here that can help you out. Check here to find some PDF planking tutorials, and be sure to start a build log so that you can get some more tips, advice, and encouragement. I hope this turns out to be an enjoyable hobby for you for many years to come. Cheers!
Kopeikin, The Swan-class were English ship-rigged sloops of the late 18th century. The Fly and Pegasus models offered by Victory models are of this class, though in 1/64 scale. 1/48 is the scale in which many admiralty board models were built.
- 6 replies
- swan
- sixth rate
- (and 4 more)
Yep, these are great kits, and sadly Midwest is no longer making them. Our loss.
