russ
Members-
Everything posted by russ
David: Thanks for the suggestion. I have no problem cutting the brass strips. I have a handy pair of scissors that can cut just about anything and they do so without rough edges or distortion. I just need to pay more attention to what I am doing. I designed them at 3/64" wide and I lost track of that number as I was having too much fun drilling holes in the chainplates and soldering pins in them. Elia: Thanks. I am much happier with these. Thanks for the all the likes as well. I apologize for this bit of tedium. Russ
Here is a second pass at the main deadeyes and chainplates. The chainplates are much better in that they are nearly right on the design width, about 3/64". The height of the deadeyes above the rail is good and they are just about equal in height. I think once the cap is in place and everything is painted, this approach will work. The key for me is to keep the chainplate width as close as possible to 3/64". Russ
The shroud, deadeye, lanyard setup looks good. Very neatly done. That spacing jig is always a good idea. Russ
- 188 replies
- constitution
- mamoli
That looks great. The cherry stain works well against the lighter colored bulwarks. Very good work. Russ
- 95 replies
- virginia
- artesania latina
The main deadeyes and chainplates have been fabricated. I still need to make the cap over the edge of the railing. I am not sure if I will stick with these assemblies or give it another try. I am concerned about the inconsistent height of the deadeyes. Once the assemblies are painted, they will look okay, but.... Late tonight I decided to make a few more deadeyes and broke two consecutive pieces while making them. That told me to walk away and try again tomorrow. Russ
Nice work on the cradle. Looks like you are getting close to rigging. Russ
- 296 replies
- herreshoff
- buzzards bay
HMS Druid by Krug - FINISHED - 1:48 - Hahn
russ replied to kruginmi's topic in - Build logs for subjects built 1751 - 1800
It is a fine piece of work, all around. Well done and congratulations on a great looking model. Russ -
The anchors and stocks look very good. The paint job is realistic. Very good work. Russ
- 601 replies
- constitution
- revell
Frank: I use a clear plastic ship's curve to draw the plank shapes when I spile. So far it looks good. I would run that entire upper strake of planks before overlapping with the second strake planks. It will probably make it easier to keep the lines of the planking running smoothly. Also, run a plank on one side, and then its opposite number to the other side. Avoid running too many planks on one side. That could result in some distortion of the hull from one side to the other. It is something best avoided by planking the hull evenly from side to side. Russ
The deck, coamings, and rudder hardware look great. Well done. I agree about the flat white. I think that is a good call. It plays better in scale. Russ
- 296 replies
- herreshoff
- buzzards bay
Help with a Byrne's Saw - end of cut problem
russ replied to rtropp's topic in Modeling tools and Workshop Equipment
I would contact Jim Byrnes about your problem and get his advice. Russ -
You are doing a very neat job of planking. You may end up liking the color contrast on the lower hull. Russ
- 95 replies
- virginia
- artesania latina
Looks good to my eye. Very nice job. Russ
- 142 replies
- buzzards bay
- herreshoff
Ken: Excellent work. The guns and their rigging look great. Russ
- 455 replies
- fair american
- model shipways
That looks great. Nice job taping the hull. Russ
- 296 replies
- herreshoff
- buzzards bay
