Posts posted by xken
Kits that I have designed to date are: Mountain Buckboard; Allerton Steam Pumper; Ladder Wagon; Hearse; Armed Longboat; USS Constitution Cross Section; Jail Wagon; Fokker EIV; Oberusel 14 Cylinder Rotary Engine; Wolsey Eight Cylinder “Viper” Engine; SE5a British Fighter; Beer Wagon; Horse Harness (pulling); Horse Hitches for Wagons- 1 Horse; 2 Horse; 4 Horse. They said that they have plenty more in the lineup; I will be 76 next month so who knows how many more. The BeerWagon and some others are at the Nuremberg International Toy Fair, Germany.
Life is good.....I get paid to do my hobby what more can one ask for.
Amongst all of this I did these personal projects: the Niagara; USS Constitution; Maersk Detroit (WIP); Dirty Dozen; and 1961 Showboat a pet project. A couple of stained glass windows for local church.
Here are just a sampling of them.
The Niagara now has a much steadier and lower base to rest upon. My daughter found this in her travels and immediately bought it. Now people can now look down at the deck details which was not possible before. Perhaps the Detroit will be displayed above it whenever I get back to it. ModelExpo has been keeping me designing various model kits for them.
- Prowler901, ccoyle and Coyote_6
2
1
- mtaylor, Ryland Craze, Jack12477 and 3 others
6
After years of dust and battle damage she was put up in dry dock; cleaned layers of dust and battle damage repaired due to young growing girls. Then a brass plague added, new base to index a custom built glass case she now resides for years to come completely protected. The granddaughters now truly appreciate the work involved in building models having grown up watching me build various model subjects. In fact the younger one now builds Star Wars spaceships with LEGO blocks that are quite intricate.
Fair winds and following seas in her new home!
- ibozev, David Lester, ccoyle and 9 others
12
Ben, I have made the propeller, but have really been buried non stop designing model kits for Model Expo and they have several more in the line up. They are various subjects and time consuming. I started this for my son in law as a spare time project and guess what no spare time yet. It is one of those good news, bad news situations.
But it will get done some day. Thanks for checking in.
We have visited that museum twice, all are in for a really great experience and time. Just a fantastic place to see and explore.
- mtaylor and Ryland Craze
2
Kurt, I to use Staybrite almost exclusively and with a 120 or 45 watt soldering iron. If a brass part is really thick then I will use a propane torch bottle type from hardware store. Also what dvm27 said is true for best results in most soldering operations.
- kurtvd19, mtaylor, thibaultron and 1 other
4
Nice build and great presentation the medal is a nice touch! What’s next?😎
- popeye the sailor, mtaylor and Canute
3
Paul, your build came out great! I really enjoyed seeing the alterations and detailing you did. I have always considered kits to be jumping off points for extra detailing. Keep up the great work and the next thing you know you will be scratch building.
Paul, please keep in mind that the 5/16" dowel is a reference dimension for the dowels to be ordered by M.E. for kit production and given manufacturing variances dowels can be slightly larger or smaller. Please reread page 34 where is says use the boom ring as a gauge when tapering the mast. The cast parts are labelled correctly. As for the 3/8" that is tolerance to allow straightening the mast allowing for variances in the build by individual builders if the mast foot is slightly out. I personally do not like to see crooked ( out of perpendicular) masts.
I hope this helps. Look at page 37 for the finished part.
I learned very early on about plan reproduction which is why I include a 1 inch reference square on my plans. Plan reproduction variances can be large or small based upon the machine settings, quality of machine and quality of paper. Also file transfer can cause issues as well, to minimize this I and the M.E. folks both work with CorelCAD now. They were using CorelDraw to covert the CAD files for plans and laser cutting and when I would get laser cut parts they were usually 5% off in size due to the conversion from on program to another. This also happens with PDF files we discovered, hence they finally bought the CorelCAD so we all worked with the same program.
None of these I can as a kit designer control. I have seen variance as much as 3/8" and if using plans as dimension guide could be disastrous.
The greatest challenge I have with the kit designing process is writing the instructions which is a balance between enough information to too much information and I like to err on the too much side. Builders also have to use a degree of common sense and allow for variances in building.
When working with laser cut parts the finished dimension is on the bottom of the part sheet not the top, and laser cutting based upon the thickness of wood will have a slight taper (draft) though the thickness of the wood.
The hexagon versus octagon is my bad, I should have caught that, but neither did the three other Proof Readers.
Arthur, not sure why you are experiencing the problems you are having. The boat in the pictures in the instructions were built from the laser cut parts in the kit and before being released M.E. also had two independent builders assemble the kit as well as part of the proof of production and the only issues were tweaks to the instructions for better clarification of terms for new builders. This is a standard practice I have asked M.E. to do with all kits I have done for them.
I also purchased 1/24 scale sailor figures for my build, not to be included with the kit just for my own display purposes. See attachments.
Here is an image of the rear cockpit area using the laser cut parts from the kit.
Here is just the hull completed with all the laser cut parts from the kit and all fitting well. As for the quality of the wood in the kit's Basswood that I have no control over; however, they do supply me all the materials used.
Good luck with the rest of your build, should be smooth sailing here on out.
Michael, great brass work on the lantern. I am looking forward to the engine build which is the part I enjoy the most in my builds. Have a great day!
Jon, I emailed Marvin and he said yes to the 1,000 or more discount. Email him with the size and quantity and he will give you a cost. I have known Marvin for years he is honest and fair. Have a great day and keep up the great job you are doing.
Jon, are you aware of these Marvin is set up to sell these in bulk packs of 1,000 for members of this site. You might want to check out the various sizes they offer, this is the smallest and you may need magnification to use them. I have used these and other items they offer in my builds. Just FYI Ken
2 hours ago, Arthur Wayne said:
I just realized, aren't you the same Ken that built the prototype and did the instructions?
Guilty as charged! I will look forward to your progress and feedback. Just a note again on the plans they were 100% size when sent to Model Expo so the size increase is due to what I mentioned above about reproduction.
When designing kits the challenge is always the instructions. M.E. wants short and sweet and as few pages as possible while some builders need ever nut and bolt explained. I always try to put myself in the builder's head while writing the instructions and strike a happy compromise between novice and experienced.
Keep up the great build you have going.
- Jim Rogers, Sea Hoss and CDW
3
Great job on the planking and tree nailing! Just FYI look at the second row from the bow at 5th and 6th plank up from the bottom. I marked mine as I planked using a .5mm mechanical pencil while I could see the bulkheads and just pressed the lead straight down. This left a pencil lead mark even after sanding.
Dave, try tinning the thicker copper ring first with a thin coating of solder plummer's 50/50. Then solder the elbow parts with Staybrite solder and leave excess solder in place then with soft binding wire hold the ring to the elbow and heat the edge of the ring the copper will carry the heat faster to the thinner brass and flow the joint. The 50/50 has a lower temp than the Staybrite. Looking at the size of the parts you should be able to do this with a small 40 watt iron. Or if using a torch set the flame as small as possible. Make sure the iron is hot and use the correct flux.
Another option is to us a wood plug through the ring to index the brass elbow while soldering; you will love the smell of burning wood in the morning.
Solder Putty as mentioned above is available at www.OttoFrei.com , but you should be able to do this no problem. Update: I just checked their site and they no longer sell the Solder Putty.
- lmagna, Richard Griffith, mtaylor and 6 others
9
Looks like you are off to a great start. The increase in plan size seems to be a common problem with plans being printed, I have run across this even having CAD drawings reproduced locally. I now add a one inch reference square to all my CAD drawings and check when I pick up the drawings and have had some off by 5% and had them reprinted to the correct size. They are suppose to calibrate machines every 10 days which I am sure most printing operations are not doing.
Keep up the great job!
Dave, Great job! Now your mornings are free to exercise!
- Piet, Canute, SawdustDave and 1 other
4
1961 Showboat Dragster by xken - 1/8th scale - scratch built
in Non-ship/categorised builds
This was a tribute build of Tommy Ivo’s exhibition dragster powered by four Buick Nailhead engines. The left two engines drove the front wheels and the right side the rear wheels. They were geared so that only the front would smoke during the run. I was able to purchase four CD’s of pictures of the replica build from the original builder Bruce Dadra. The reference material was awesome in details. The engines were purchased cast resin and completely enhanced, exhaust pipes were bent brass. The body was .010” bass sheet formed and butt joints to maintain thickness. Tires we’re modified cast resin with aluminum wheels custom made by Dancing Bear Components. The decals I designed and we’re reproduced in Australia by a supplier that could do the gold leaf background. The parachute is carved wood with removable access panel to get at mounting screws. I did all my own chroming using Caswell’s products. The front wheels turn. The upholstered seat was done using Sculpty baked in oven. The seat belts are leather and work. I also added the Hot Rod magazine cover from 1961. Tommy did send me a wonderful email telling me how great the details were.
