Posts posted by Chuck
Just a small update. I worked on the inboard stern details. The seats are completed. Card templates were made first using the plans as a guide. Then they were tweaked to get a nice tight fit with the parts.
Cleats were added...these are all laser cut Syren cleats (5, 7, and 9mm). All that was needed to do was sand them a bit to shape and then add a piece of wire as a pin. Then they were glued into place. I decided to paint these bulwark red also to match the many contemporary models I have seen.
Finally....the horse was added for the boom sheet. This was just a small piece of wire bent to shape. Two small washers laser cut from paper were added to finish it off nicely on each end. They were painted to look like metal. I should have dusted the model better before taking the pics....next time
I will now continue my way forward along the bulwarks adding eyebolts, cleats, ladders and pin rails.
Chuck
- michael mott, rtropp, Canute and 33 others
36
That would be a bit risky.....i wouldnt do it...you would have more control just doing it by hand.
Chuck
- mtaylor, Stuntflyer, Canute and 1 other
4
Just catching up with this project. You are doing a fantastic job on this model.
- mtaylor, michael mott, Piet and 1 other
4
If your planking is pre-shaped/spiled to the proper curves...there is no need to clamp or pin. Thats the way to go. Planks fit perfectly with no force needed....no springback.
- Mark P, BRiddoch, Seventynet and 7 others
10
If it wasnt for the good folks who managed to copy my logs from version 1 of this site...They would be lost forever. I dont however know any way that it can be done easily. But yes....you should ask permission first. My gues is that many have already done this without asking...but it is better to ask first.
Chuck
- dgbot, edmay, Scottish Guy and 5 others
8
Thanks for that.
Chuck
I have a design for them which could be laser cut....I think the smallest I could comfortably go is 5/32" long though. I just havent had time to laser cut them and try building the prototypes. I probably wont be able to do that for a few weeks.
I am also having a problem sourcing brass strip thin enough and the correct dimensions for the strops at these various sizes.
Its been something on my to-do list for some time.
Chuck
How quickly do you need them Allan....?
Single line and yes, I will be serving it its entire length. Although in most cases you wont see it served its entire length on contemporary models. I believe its because most contemporary models do not show the original rigging or no serving was used on the entire model regardless. But I will be doing it. definitely a single however.
Staff??? What staff? Its just the three of us. Me, myself and I.
But seriously...the amount of blocks he uses per month is just an astounding number. You couldnt even imagine. An impossibility to manufacture by hand my blocks and rope for his needs. Its just not possible. I can at best make about 1400 blocks per day. Then I want to stick a fork in my eye.
Chuck
If you didnt create it....you have no claim to it .....and you shouldnt profit from it. If you want to use it...you must pay the person who created it or ask their permission to use it...simple rules in society. Period
Unless you reach out to the creator, and make amends for not having the skills or creativity to think it up yourself. Otherwise its no different than you breaking into my home and stealing from me. Those people are called parasites and thieves with small brains unable to innovate on their own. I personally loathe these self-serving, greedy individuals...
...and anyone who thinks otherwise because they might be too cheap to pay for the original or two lazy to ask permission....the willingness to support these parasites is just as bad.....and the law is not on their side thank heavens...at least not in this country...you could however move to China.
Locking this because its just going round and round.....and remember, even though we do have international members on this forum, it is based in the good ole U. S. of A.
This topic was not created to open a discussion on copyrights. It was created to define the NRG Policy. The NRG will always protect the rights of the creator and their wishes and not those of the profiteer. Members can have a different opinion but understand that all members not adhering to the policy and choosing to post or use copyrighted material obtained without proper compensation or permission from the authors...... will be warned and then finally banned if repeatedly in violation.
Chuck
HM Cutter Cheerful 1806 by Chuck - FINISHED - 1:48 scale - kit prototype
Yes there would have been a discharge hole through the counter but it is rarely modeled. You can absolutely choose to show it if you want.
Chuck
