Everything posted by Chuck
Who would of thought my twelve pounders would ever be used as swivel guns. They look very good and if your hand was not in that picture to show scale, you would think they were small and the to scale as if on a 1:48 scale model. Chuck
- 421 replies
- granado
- bomb ketch
Looking Good Augie... Of course those scrapers work!!! Sometimes the etching goes too long and the point is a little dull. But for soft woods it works a treat. I have to deepen the grooves for harder woods. You will notice many extra profiles on the sheet. You wont need then for the kit,...I just thought I would throw in several extras. They come in real handy. SHH!!! Dont tell EXPO
- 2,191 replies
- confederacy
- Model Shipways
Yes the kit as I researched is intended for those 8 and up. At least according to the few places I saw it offered. Its only about $25. Chuck
That is OK but its a kids model for eight year olds. But I wouldnt prevent you from bilding it here at MSW. Chuck
Yes I was but I cant think of a logical place to put it.....can you send it to me in a PM. I imagine I will just keep it on hand as most will end up contacting me for it. I suppose I am logical keeper of that list. Chuck
- 162 replies
- 18th century longboat
- model shipways
Looks simply beautiful. Well done.
- 100 replies
- model shipways
I never worked one up...but I am sure that someone here in this forum has a list. Its basically just whatever is on the materials list plus a sheet for the keel and stem and transom.... Chuck
- 162 replies
- model shipways
Really look terrific...well done. Really hope you had fun with it.
- 58 replies
- model shipways
Great looking project Ben. I will be following along with much interest and so far you are doing a fantastic job of it!!!
- 889 replies
Victory by mikec - FINISHED - Mamoli
Chuck replied to mikec's topic in - Kit build logs for subjects built from 1751 - 1800
They were attached the same way you did the other flags. The penants and flags that flew off the masts were in fact attached to un through sheaves in the ball trucks. These are the caps on the tops of each mast. They were belayed in the tops usually to a shroud cleat or to the rail in the top. Hope that helps. Chuck -
That looks great. Yes the top frame pops up a bit. Your planking run looks real good. Proceed as shown in those photos. Chuck
- 137 replies
- finished
- model shipways
Thanks for the kind words. I actually have thought about it...but its one of those ...where do I find the time.......things. I am sure I will get around to it at some point. Chuck
- 137 replies
- finished
- model shipways
Looks fantastic....Dont forget to check out these photos of the pinnace in the NMM museum. This is the pinnace I based the kit on for teh most part. http://modelshipworld.com/index.php?/gallery/image/5287-london-517/ You will notice a few changes or omissions that I made to keep the kit more simplified. If you have any questions at all please let me know. Chuck
- 137 replies
- finished
- model shipways
Tom The three bobbins should spin independently to twist the three strands first. Thats what the Byrnes ropewalk does. You cant make rope unless the three strands are twisted first and then afterwards you twist those three strands together in the opposite direction. Its the opposing tension that keeps rope from unraveling. Otherwise you are not making rope. You are just twisting three strings together and using glue or something to keep them from untwisting. With those machines its just all done at the same time. Without the initial twisting there is no way on the planet that the rope wouldnt unwind afterwards. I am sure those three bobbins are actually spinning independently to put the initial twist into each thread before they are laid up into rope. Its the only way you can make rope. As far as I know anyway. Chuck
Those machines do twist the initial strands separately as that is the way all rope is made. The key is to adjust the speeds so that initial twist are the correct amount in comparison with the turning of all three strands together in the opposite direction. I like the feel of the manual machines better because this can be adjusted to suit where as the machines make this difficult to feel and adjust. You have to finish a whole spool before you find out that the rope has the correct opposing tensions. To harden the rope I dont do anything elaborate. I just stretch about a 2 foot section of the rope at a time before I cut it free from the rope walk. I stretch it for just a fraction of second. Then I cut one end free and pull it lightly. I dont pull too hard or I will break my machine on the other end of the ropewalk. Just a quick light stretch. You will "feel" when its enough. In fact...if after cutting the rope free from one end of a manual machine it kinks up or it unravels....thats the sign that the tensions are not correct. If they are correct the line will not kink up or unravel at all. Its a pleasure to cut a length of rope free and see it just sit there without kinking or twisting. Thats when you know the opposing tensions are perfect.
My guess is that when you glued the pieces together the lower parts of the stem were not assembled at the correct angles. The scrph joints are tricky and the pieces should be assembled over the plan to get the proper curve in the stem. It also depend on how much of the laser char you sanded off. If not enough char was removed to get a nice tight fit...the creep could have made teh entire assembly slightly larger. All of these factors will compound to make the piece oversized...in addition, measure your plans scale bar to see that it is printed at the correct scale. You plan may also be too small. It could be tons of things actually...the laser parts could be off as well. Great start either way. Chuck
Thank you Druxey. I just made some .062 rope yesterday. So I just ran down to the shop to cut the ends off with a sharp fresh blade. You can see that there is no unraveling at all. This is a six strand rope. Initially my six strand rope did unravel and it took me months to adjust my twisting and ratios before i got it just right. I do fear that those who initially bought my larger rope may experience some unraveling, but once you get the tension correct and the hardening correct you wont have any issues. I have since stopped using an automated machine like the ones offered and have reverted back to using my hand held version. The rope is manually twisted and then hardened afterwards. None of my rope will unravel now that I have the ratios correct. After making thousands of feet of rope in just a few months I began to get a feel for the tension in the line. I believe that this "feel" can only be ascertained by making the rope by hand and getting accustomed to what the right "feel" of tension and spring I can sense while holding the end of my rope walk and the line. I also examine the lay of the rope and have a sense for what is correct now. I also do this when twisting the initial individual strands. Its a matter of feeling that it is correct. Last month I brought my rope walk into my club meeting and made a 21 foot length of .045 rope in about 10 minutes. It initially started out as three strands of thread that were 26 feet long. After twisting the individual strands...they were now just 20 feet long. Give or take. After twisting all three strands together the line was lightly waxed and then hardened. This stretched the rope to 21 feet long and as soon as I finished it up...I cut the rope in half with a sharp blade to show how the rope would not unravel... It is absolutely possible. Chuck
The plastic stuff in kits is treated and thats why it wont unravel. Same is true for the natural stuff. But not all laid rope will unravel. If properly hardened after laying it up it certainly wont unravel. My rope wont unravel at all. If you use a sharp...sharp blade this is especially true. Using a dull blade may make the ends start to frizz up a bit. My larger ropes may unravel a little bit, but not too much. I have since created a method to ensure that doesnt happen. The smaller sizes will not unravel at all....The key is getting the opposing tensions in balance. If you dont wind the three strands initially enough times then it is most likely the final rope will unravel. That is usually the mistake that is made. When I first started making rope, that was the case. But I kept increasing the amount of twist in the initial strands until I was doing it four times as much. Each time I increased it....the rope unraveled less. Also remember not to over twist all three strands together. That will cause kinking in the final rope. You must through trial and error strike the correct balance in the tension. Chuck
Nope....its definitely wrong...I dont understand how they can print those wrong every time.... Download these and print them out. Remember to make the page scaling "none" in adobe before you print it out. That is what they keep doing wrong. That is why it always prints too small. Chuck framingplan1.pdf framingplan2.pdf framingplan3.pdf framingplan4.pdf sternframingsyren.pdf framingplan5.pdf framingplan6.pdf
18th CENTURARY LONGBOAT - WHAT FLAG TO SHOW?
Chuck replied to samueljr's topic in Wood ship model kits
Thats a tough question Sam. I searched but in the end just left it out of the kit because I couldnt find a definative answer. But the typical jack would be safe. Chuck
