JeffT
Everything posted by JeffT
  1. Welcome. Looking forward to seeing your build.
  2. I felt the same way when I started mine. Just take it one step at a time and you'll do fine.
  3. Your Wasa looks great. I'm curious about the bolted on piece at the bow though. Whats that?
  4. Thats one thing about this kit,,,there is so much to do and then redo several times
  5. I haven't used primer over the poly. I just paint over the poly. Usually two coats is enough with badger paint.
  6. Yes, paint colors. Once the wood is prepped I apply the poly and paint after. It makes a nice smooth finish. I don't think its possible to stain after applying poly as it would prevent the wood from absorbing the stain.
  7. They look expensive
  8. Wipe-on poly is a protective finish that would be applied after staining. On the other hand, its nice to paint over so I apply it to unfinished wood and then paint.
  9. My fingers have been the clamp. The blocks are so small that clamping them is difficult. However, I might be able to find a way. Maybe clamping them in the end of a hemostat might work. The blocks get ruined because I end up chewing up the end of the block trying to drill them. Maybe I'll post a topic and see how others have approached this little task.
  10. Its a little detail really. I'm in the process of rigging the guns and I chose to drill holes in the ends of the 3/32" blocks to install the hook. After destroying a dozen blocks and successfully completing only one, I gave up for now...I'm building up the courage to try again. If there is a easy way to drill that hole, I would like to know what it is.
  11. Thanks RoadRunner! I have been a bit neglectful of the model as of late but she will resume eventually. Hit a couple of frustrating areas and decided to put her aside for a little while. I have not been completely idle though.
  12. This is the best picture I have of the area. You can see how the wooden deck fits around the structures. I can't remember which wooden deck it was. I want to say Pontos but I'm not 100%% sure. It was self-adhesive and also sprayed it with a white glue water mixture an it worked great. No peeling at all to date.
  13. I built this model last year and used a wooden deck. I didn't have a gap like that so you might need to do a little trimming.
  14. Good luck with the build glennard. This one will keep you busy for a while. Also, I deleted the duplicate log for you.
  15. Thanks Jerry. That answers my question. It looks like you might need two sets of hands to attach one of those patterns.
  16. Hey Jerry, you're Vic looks great. I'm curious about the long gun port patterns used on the model. Did you have to glue those down a couple of bulkheads at a time to keep the glue from drying before the whole thing was secure?
  17. Bill, you will need to clean it up as best you can. As you mentioned, fairing will take care of most of the hull. It does leave kind of a residue on the surface of the wood that may affect gluing.
