dgbot
Gone, but not forgotten
Everything posted by dgbot
  1. Great looking deck Popeye. I see that you follow a rule I always like. When caulking a deck try to make it subdued so that it does not stand out and detract from the beauty of the planking and the wood used. David B
  2. It was the bilge area I was talking about. Herreschoft hulls were nice but you had to be very good at your craft to build them. David B
  3. I am still surprised at the patience you have. Nice work. David B
  4. Your hull looks great. It has that unique look that I like. I still think planking that hull must have been trouble. David B
  5. My bad I thought it was the British vessel. David B
  6. I would go with Russ stick with 12" for your planking. The Alert makes into a lovely model. Are you going to use the AOS series to help you build it? David B
  7. May god be with you Nenad. I have been a witness to the damage flooding can cause. I pray that you and your family are safe and unharmed. David B
  8. Omega, I know several miniaturized who have used Holly to simulate what you are doing. The wood is durable and flexes very nicely. David B
  9. Omega, I like the way your schooner is turning out especially at that scale. How is the plastic ad work I go for you and where did you aquire the plans. David B
  10. You are doing a bang up job. David B
  11. Your dory looks like it is double planked. The inner planks in one direction and the outer going vertical. David B
  12. I read a article about raising and lowering these props. It was done when the sea was calm a lot of headaches. David B
  13. Nice work. And these have to be custom fitted. David B
  14. I like, two alike yet different. David B
  15. You are doing a swell job. It must feel good when a project comes together. David B
  16. I found your build. I like the way you are upgrading everything. David B
  17. Paul my advice would be to stay at the original scale. Your kit is not very accurate but if you do not mind doing a bit of kit bashing and want to practice your skills go for it. Remember you are not in a contest. This for you to have fun and enjoyment. David B
  18. If my memory serves me this craft was painted the way the fisherman wanted it to identify it. There was no standard shade. David B
  19. I came across your build a little late. You have an interesting build. I am always interested in working or fishing craft. David B
  20. It is really starting to shape up. I like the form. What colors have you decided on. David B
  21. Testors has an enamel paint remover. You can also use a product called Stripeeze. This stuff gets brushed on and then let sit. It will remove almost anything. Then use a little mineral spirits to clean up. For nooks and crannies you need a thinner paint than Testors enamel. Try Tamiya acrylics. David B
