Baker
Posts posted by Baker
  1. Building the mast tops
    Mast tops
    The size ??
    In this era you will find all sizes : small, big,  high, low.
    Looks like 2 armed soldiers or sailors should have enough space in it.
    And the  "supports" under the mast top are usually longer than the bottom diameter of the mast top (white arrows)
    The top of the main mast is usually slightly larger than that of the fore mast.
    20200803_163143.thumb.jpg.bf6ffbab410318968653186a0d66d112.jpg20200803_163203.thumb.jpg.067716ef342a79afd70aafab2d24b30d.jpg
    First did some testing with paper before buildig the "baseplate"
    I first do the main mast until the base plate is ready, and then do the same with the fore mast.
    20200728_110313.thumb.jpg.c5d7c29fe107e538a52b84efb0d257e4.jpg20200801_135355.thumb.jpg.698b901b7b8d3c7ca9dd03944cea12f3.jpg20200728_153920.thumb.jpg.e05288acfc39aab7d72a61cd8b423742.jpg
    20200802_125447.thumb.jpg.bf7b33ad4e2d5418b767b81fed1e1515.jpg20200802_185438.thumb.jpg.8be9a86d6f983760d33ca83e47e556c6.jpg20200802_190733.thumb.jpg.e53c60b4b10a88c013cc9c814834c5e8.jpg20200802_190742.thumb.jpg.d11efae15a46fd4f1d652c04d88b69b7.jpg
    Thanks for following
  2. 23 hours ago, Bill Morrison said:
      Should the dark wood between the painted pillars be cut out?  For example,  look at the row above the green and white triangular markings.  I wonder if the seven lighter and narrower vertical and slightly slanted areas are actually pillars or posts that support the red and white striped railing?
    Bill
    Yes,
    There is a build log of the  Mamoli GH here somewhere on this forum
    The builder also opened these holes later in the build.
    Great work so far
  3. 7 hours ago, Egilman said:
    They did build a couple of updated versions which they used in WWII to shell southern England across the channel several times, they were captured by american forces shortly after D-Day... (that might be what you saw but I can find no record of them ever being put on display)
    A 21cm K 12 (E)  (the specs are from other cannons)
