Baker
Posts posted by Baker
  1. Welcome on the build of an Italian WW2 armoured car.
    General info ( wikipedia)   https://en.wikipedia.org/wiki/Autoblindo_Fiat-Ansaldo
    I started this build a while ago. Then I came to the conclusion that according to wikipedia the AB 40 ferroviaria (fv in the future) would not have existed. Only the improved AB41 would have been converted to the fv.
    Italeri error ?? No, after a lot of searching, the wrong information turned out to be on Wikipedia. So good work from Italeri !!
    Box, contents and plan
    IMG_20191208_112648.thumb.jpg.7b499562fd7e3bf702117de2bc294345.jpgIMG_20191208_112811.thumb.jpg.3313ddeb237f43be7ef747449e3e3c9d.jpg
    Building went without problems. Everything fits perfectly.
    IMG_20191208_113901.thumb.jpg.82ad1fc829b2216b0f9343c8cfc2d602.jpgIMG_20191209_132718.thumb.jpg.745014cf49874271ae7ae30568b1251d.jpgIMG_20191210_164232.thumb.jpg.aa63e1ba5ff89360e6cd323c729c4509.jpg
    The horn has been drilled out
    All this happened a few months ago. Then the build stalled (wikipedia's fault ;)) Now restarted and the basic color has been applied since today.
    Current status on the photographic proof that this vehicle actually existed.
  2. On 7/7/2020 at 12:41 PM, druxey said:
    The channels simply space the shroud out away from the ship's side. The strap or chain only attaches to the ship's side on the channel wale below. Usually there was a groove in the edge of the channel to prevent sideways movement.
    19 hours ago, mtaylor said:
    With the strap/chains in the notch, a small dab of CA or epoxy will hold them in place.  Note that some vessels also had a thin wood strip on the edge to keep the strap/chains in place in addition to the notch.
    Thanks for the advice.
    I think this will be the solution to my problem :
    There must indeed be grooves in the channels. So that the schrouds cannot move.
    And.
    The thin wood strip will be applied temporarily. This way the deeadeyes stay in place during installation
    This strip will then be removed later when the shrouds are completely ready
  3. For my Pelican project I have reached the stage where the deadeyes are attached to the channels.
    My problem is now how to attach these deadeyes to the channels.
    Judging by various drawings these are not attached at all (see drawing)
    I think the masts will probably have to be placed first and then the chain, the 2 deadeyes and the schroud.
    A complicated method. Anyone have any suggestions how I do this best?
  4. Michael,
    Thank you for the suggestion
    I actually planned to do this.
    But, this does not seem to have been in use  in the 16th century.
    It is without this detail for the time being. But I can still add this.
    My biggest problem will be, how to attach the deadeyes to the channels.
    Judging by various drawings from differend ships these are not attached at all.
    The masts will probably have to be placed first and then the chain, deadeye and schroud
     Complicated method ....
  5. Thank you, thank you, thank you 👍
    So no more photos with watermark. I have no idea how to do it without the Samsung logo and otherwise, this build will be a Samsung commercial.
    And, i upload from the smartphone to the PC using dropbox.
    For some reason this was no longer possible. After hours of searching, it turned out that dropbox suddenly no longer had access to the photos on the smartphone.
    Why?? another IT mystery for me.
    But problem solved. :Whew:
    Meanwhile, the deadeyes for the foremast and the mainmast are ready.  Made them in batches of 10. I had 6 "splitters" but repared them with CA glue.
    Collored with thinned Tamiya paint and polished with scotchbrite  (48 ready and 2 scrap)
    20200630_143844.thumb.jpg.4ea302746505387360a3fcf84c7c7f63.jpg20200630_144012.thumb.jpg.ddf4b19fc6a2a49c8efedbbcd7e2c284.jpg
    Thanks for comments, likes and following
  6. What I learned from my first scratch build.
    With filler blocks between the frames you can sand away many errors. I used fillerblocks and one layer of planks.
    Sanding filler blocks and sawing planks yourself creates a lot of dust. Saw and sand outside in the garden.
    And the wife will not complain
    Hull with sanded fillerblocks
    Dust in the garden ...😉
    IMG_20170325_113305.thumb.jpg.442a5ee6f8386258225859a9c368e88a.jpg.7b80d3afee1d983388ef9b7c0bcfeb50.jpg
