Posts posted by RGL
After a few days off due to illness, the 25mm triple mass production continues.
For ease of application they are laid out on masking tape and the barrels added.
Then the magazines folded and placed in blue tack facing the right way for application.
Then the sights and rear handles added. Whilst the alignment is not perfect, they are soo tiny it is not really noticeable with the naked eye.
Just gently tap on the bit you have glued down with the tweezer head, if it falls off then it will fall off late and you'll lose the piece. I find about 10% of all assemblies do this as the glue has not been put on correctly. Better to fix it then than when it's on the model.
- popeye the sailor, src, mtaylor and 4 others
- 7
Nice! How's then back? Cramping yet?
- mtaylor, Old Collingwood, BANYAN and 3 others
- 6
Sanding is probably a bit harsh, but I can rub the soot off and it's as good as new.
- Old Collingwood, Canute and mtaylor
- 3
I just use a cigarette lighter, takes seconds then sand
- Old Collingwood, Canute, cog and 1 other
- 4
The thing is with tweezers I find that if any CA gets on them they have to be polished back as CA builds up in layers making them useless.
- CDW, Old Collingwood, cog and 4 others
- 7
Thanks all, slight miscalculation, there are actually 28 triple 25mm guns, so that's 76 barrels to insert, and 76 x 2mm magazines to fold and insert.
Just completed that aspect and somewhat cross eyed. Still, easier than stropping blocks.
- cog, Ryland Craze, Canute and 2 others
- 5
The Pontos kit provides 29 guns mounts, and the model requires 24.
So I spent the afternoon and this morning working of the first draft so to speak to see how it goes together. Not as hard as the smaller guns, but still fiddly, the final product is very rough and now I know what to do it will improve. The gun shields come off as they are not on the real ship and I expect they are required for the Mushasi, and there are two options for the sights, which the reference material says were simple iron sights in 1944/45. .
As I have spares, there are a few more ideas I want to try for ease of construction, the only thing is to have enough barrels I will probably have to pull the draft apart and burn it to get the glue off.
This is going to take a while.
I am limited with my photography with my phone, my job once sent me on a course but it was all about not being seen by the subject. Needless to say my eyes are going with the scale and I've got great near sighted vision. The triple 25mm's are a lot easier but there are 26 of them, I did up the first draught this afternoon without glue and they're quite easy.
Can someone please recommend the very best brand of tweezers they know of? Tamiya is too big, and there must be something out there that can handle 1mm pieces without sending them into orbit. I have one excellent pair but open to suggestions
- BANYAN, mtaylor, popeye the sailor and 1 other
- 4
- davec, GuntherMT, Old Collingwood and 12 others
- 15
That is magnificent Mr Rabbit. Very very clean work.
- CDW, Old Collingwood, mtaylor and 3 others
- 6
Cog, the answer is no, I also have the old tool which I bought second hand to practice painting, and the new tool does not need them as the detail is a lot better. The time spent in making the corrections would be saved with the new tool.
Mr Taylor,
Nothing is impossible but at this scale you use such tiny dabs of glue, they are very fragile and break very easily, not to mention that if you bend some etch the wrong way then bend it back they snap off.
The designers have to be engineers to make it all work, and still do it economically. My biggest issue is the instructions seem to make perfect sense once you have finished making an assembly. I dare say it is the language barrier as well and lack of decent photos. I would be happy for Pontos to give me free stuff and I would do their instructions for them. There is a fantastic build on another site which I have been following,and the bloke from Pontos seems to drop in and out of their forum in the way of marketing his wares.
Working rigging blocks on a tall ship are feasible but given the amount of crew they require, not possible for the single modeller to represent. If I hadn't made some wooden ships first I would never have the patience to do this one.
Next is the 25mm single(portable) guns. Thanks goodness I only have to do 6 of them. They are tiny, and whilst not perfect, will do and I expect they are a little too big.
As you can see from the Pontos instructions, you need to be a bit of a mind reader, but keep referring back to the reference materiel. About a full day's work.
The brass pedestals have four 1mm support struts each, and a base which the pedestal penetrates through which will go into the deck.
Then lots of folding (some of the bends are <1mm). then throw it together.
- Ryland Craze, Captain Slog, CDW and 14 others
- 17
I've got large paws Cog, if I can do it anyone can.
- cog, Canute, popeye the sailor and 1 other
- 4
Good to see you here Mike, Jan, OC, thanks for visiting
Some more pics. Pontos PE (Keith, got this set from Australia)
pontos.1.jpg pontos.2.jpg pontos.3.jpg pontos.4.jpg pontos.5.jpg pontos.6.jpg pontos.7.jpg
Some reference material
And the underside of the turret. At first I thought it were etched lines, looking more closely ... it's a mesh!!!
Cheers
IJN Yamato by RGL - FINISHED - Tamiya - 1/350 - PLASTIC
So, 27 more triple 25MM's.
The bases including the seats and windage levers.
Plonk the barrels on.
Finished and I'm just a bit over these things.
