FriedClams
Everything posted by FriedClams
  1. So glad to hear Maggie is doing much better - wonderful news Keith! It's also good that your lives are becoming less chaotic and stressful. Much needed "Keith Time" - excellent. Everything pointing to the positive. Gary
  2. Another fantastic model, Glen! Congratulations. Ditto all the above comments. A very difficult subject to model but it came out great. Gary
  3. Druxey, Glen, Keith, Roger and Tom – Thank you for the positive and encouraging comments. I sincerely value them. And thanks to all for clicking on the "like" button. Druxey and Glen. Too bad about the cloud cover - disappointing no doubt. Here in Maine, early April is a time of year when we expect fast changing and unsettled weather. In fact, four days prior we had a late snowstorm – wet heavy stuff with strong winds that dropped many trees and limbs and left us without power for several days. The day of the eclipse was some of the nicest weather we had seen in weeks. Unbelievable good luck. @Glen McGuire @Keith Black @TBlack Thanks for the comments on the eclipse photos. I shot about 20 photos with a cable release during totality. All were exposure bracketed sets of three - so 60 images total. All were very over exposed, and the three I posted were the most interesting of the lot. Never thought I'd be grateful for lens flare. Hey Keith - yes, because I'm not sure one would see anything down there without it. But it will be on the dim side. Thanks everyone. Gary
  4. Greetings Fellow Modelers After a busy month with little time for modeling, I've finally begun work on the fish hold of this dragger. But first, please allow me a quick diversion. The path of the recent solar eclipse tracked over Maine on a day when there was barely a cloud in the sky. My wife and I traveled several hours north on country roads to get close to the center of totality. A total solar eclipse is such an astronomical coincidence that it's hard for me to get my head around it. That from a moving 100-mile diameter shadow on earth, two spheres appear to be the exact same size because one being 400 times larger is 400 times farther away, and that they line up precisely with the smaller sphere blocking all the direct light of the larger while leaving the entirety of its corona visible. Perhaps I'm a simpleton, but I find this extraordinary. To be honest, I thought this was going to be an interesting but ho-hum visual event, but when it went dark and I took off the glasses to see where the sun had gone, I was mesmerized. I had a DSLR mounted on a tripod with 200mm of lens. I promised myself beforehand to enjoy the experience and not spend the few minutes of totality tinkering with camera settings. So, I preset the camera and hoped for the best - manual focus, aperture priority, exposure bracketing, cable release and crossed fingers. I pushed the cable release quite a few times without ever looking at the results. Later, I found most were completely blown out and a few were just terribly overexposed. But I'm not disappointed. The lens flare image below is my favorite. A lousy eclipse photo, but an interesting image just the same – kind of surreal. Fish Hold My decision to display the boat with the hatches open and maybe a bunker plate or two, requires that the entirety of the hold be modeled as I can't predict what will be visible through each opening and view angle. Mainly that view will be small fragments of individual bunkers and planked partitions, so this modeling will be on the quick and crude side. Before I started in on that, I first washed the hull exterior with India ink/alcohol to give it a little age. About 2 parts ink out of a hundred. I've yet to decide on how the hull will be painted/weathered, but this small amount of coloring doesn't narrow my options, and the alcohol tends to remove shiny sanding spots and helps to unify the overall look – at least to my eye. I then penciled on the water line. I placed the hull back onto the base and used a squared scrap of construction lumber with a pencil glued to it. The fish hold uses up almost 17' (5.1m) of hull length. The area is partitioned off into 20 individual bunkers/pens as shown below in the top-view drawing. The pens with green dots hold the ice/fish and the red dot areas do not. The blue dots are the stationary posts that hold the wood slats which make up the partitioning. The four pens in the center over the keel functions as a walkway but can also be partitioned to hold ice/fish. Shown below is the lower half-section at station #7. The open space against the side of the hull is the area identified by red dots. This area is empty and begins at the lowest bilge ceiling strake. This drawing detail is actually from the “transverse section” plan sheet of a completely different boat by the same designer a few years prior to the Pelican, but it is labeled as the “type plan” for the Pelican. Consequently, the dimensioning is incorrect for my boat, but the structural construction is the same – presumably. The bases for the posts are 6” square timbers and on the model the six center bases are mounted on wood strips that span the entire length of the fish hold. The six bases away from the center are beveled to reflect the changing shape of the hull as it narrows toward the bow. The drawing below shows the bevel for the posts in the area near station 6A. And for the posts in the area near station 4A. Note that the bevel has changed due to the base sitting higher up in the hull. This is necessary because the interior space is narrower yet the distance between posts must be maintained. I print out spacing guides to locate the center line for the wood strips the post bases will sit on. I mark the center line for the inner and outer strips on each station bulkhead. The strips are placed, and the outer post bases are beveled and glue on. As per the plans, there are three planks below the lowest bilge ceiling strake and below that is concrete. Although they are not yet glued down, the image below shows those three planks in position. The six inner post bases have been added as well as some styrene sheet material to act as a support floor for the “concrete”. Also, note how the post bases (top of photo) incrementally sit higher from left to right as the hull narrows. It would have been easier to place the two lowest bilge ceiling strakes as one piece and mount the post bases on top of that. But, I didn't and decided instead to piece it together around the posts for reasons that in retrospect make absolutely no sense. But that's water under the bridge and in the end it won't show anyway. I smeared on some Hydrocal to form the floor of the main fish pens. Colored up the bulkhead planking with chalk/alcohol (burnt sienna, raw umber and black). Made up the grating to place over the keel and gurry trough. I'll be placing some dim-ish lighting in the hold, so a gloppy PVA mixed with black acrylic paint is slathered onto the hull to prevent light leaks. All of this mess will be hidden by the wood plank partitioning. Next – posts, partitioning and completing the hold. Thanks for taking a look. Stay well. Gary
  5. Another terrific and imaginative SIB, Glen. Looking forward to the final presentation. Gary
  6. Very nice update on the Caroline, Brian. As always, your modeling is clean, crisp and beautifully detailed. Excellent! Gary
  7. I see that you are not only a master in brass, but in wood also. The wheelhouse is very clean, crisp and precisely made. So too is the hatch and decking. Excellent! Gary
  8. Wonderful progress on Peerless, Eric. I too agree - very convincing results from your canvas method. Gary
  9. I turn my head for a few moments, and you've completed half the lightship. Breakneck speed and very nice workmanship. Keep it up Nils. Gary
  10. HA! Whenever I see such a vehicle, my natural instinct is to recoil in horror. To spend 6 hours cleaning it, attests to the level of affection for your daughter. I hope she appreciates how fortunate she is to have such a father. Masterful work on this rudder frame, Keith. Carefully thought-out process and expertly executed. Gary
  11. Yes, what is it with white paint? It's not just the light color and I've read it has something to do with the titanium dioxide. Whatever it is, it's irritating. But as Keith has correctly stated, in the end your hull painting has turned out very well. Looking good Vaddoc! Gary
  12. Ouch and danged! Self-inflicted wounds just hurt a bit more don't they? Oh, how I know. Amen, but the lure is irresistible. Gary
  13. Good to hear of Maggie's continuing progress, Keith! Putting away the walker seems a huge milestone. Stay strong my friend. Wishing the very best for both of you. Gary
  14. Nice progress on the station bulkheads, John. During these first hull building steps, one really starts to get a feel for the size and eventual presence of the model. This is going to be larger than I first imagined. Gary
  15. Hey Paul, good to see some movement on this model! Easy to do - I know. I think model building should always be about enjoyment and just doing the best you can, rather than the rate of progress. And your sharpie is coming along very nicely. Gary
  16. Indeed - coming along beautifully. Gary
  17. Nice update on the dories, Richard. That last photo shows how identically you're building them. Excellent! Gary
  18. Hello Keith, It is good to hear that Maggie continues to improve even if progress in some areas are slower than others. My understanding of this is that slowdowns and even temporary setbacks are not uncommon. I can only imagine how busy you must be and the level of stress you’re experiencing. It must be exhausting. All you can do is your best. Try to find some time for yourself to decompress on a daily basis. I wish you both a speedy return to some level of normalcy and a peaceful future. Gary
  19. Yes, the drawings are detailed in some respects and vague in others. They are copies of the designer's originals that were used in the construction of three individual boats. The intended users of these drawings were professional boat builders and consequently exhaustive details are not offered. Details that a modeler would love to see. This question stings because I agonized over the decision to not build this boat in a larger scale with one side of the hull fully exposing the entire below deck arrangement. Fully framed with every possible detail shown. But I chickened out, so no, there'll be no need to build the engine. Thanks Richard. Yes, the boat is about 79' and in 1:48 that's just under 20". Not huge by any means, but the largest boat I've built. Thanks Marc. And thank you Rick for the nice comment. Gary
  20. Hello Keith. How is Maggie's recovery progressing and how are you holding up? Gary
  21. Thanks guys, for the kind comments, it's so appreciated. Also for the likes. It does - and it seems a practical matter of finding a spot for the engine room and 3,000 gals of diesel. The fish hold takes up about 16'5" (500cm) of prime real estate right out the center of the hull. But, I still think she's a handsome girl. Gary
