Everything posted by bruce d
Before you do anything at all, post a picture. Trust me, my grandfather was a blacksmith. 😁
... like finding something that leads to someone else building a model!
- 433 replies
- open boat
- small boat
https://archive.org/ If it is new to you, be prepared to spend waaaaaaay too much time exploring 🤐
- 433 replies
- open boat
- small boat
Pazar caique by mhmtyrl - 1:48
bruce d replied to mhmtyrl's topic in - Build logs for subjects built 1751 - 1800
Mehmet, you have made a great weathered appearance. It has the look of a real working boat. Well done. 👍 -
Retired and ready to build my first model!
bruce d replied to lraymo's topic in New member Introductions
Welcome to MSW. It is no surprise that there are a few (!!!!!) other retired folks here so just get comfortable and settle in. Looking forward to a build log, have fun 👍. Bruce -
Ships vs Boats
bruce d replied to Mike from Aus's topic in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
It is a General Purpose vehicle = Jeep 😉 -
New to the community and wooden models
bruce d replied to Harland Wolff's topic in New member Introductions
Hello Harland Wolff (is there a message in that name? 😉), welcome to MSW from Sussex. It is a great place to learn and get support with those new tasks you will encounter. Hope we see a build log from you. Bruce -
Were the guards actually intended to resist that type of impact? I assumed (I know, assumed = guessed) that the metal guardsover and around skylights spanned wooden slats/beams and their function was to add additional protection, not do the heavy work. This is based on a contemporary model, details long forgotten. It had a metal grating across the skylights clearly in the role described above, cutting out the minimum of light while offering protection against most whoopsies. HTH Bruce
I am going to butt in here. If the MDF is wetted and then clamped as you have shown, drying will be problematic. The only place for the moisture to escape is the exposed edges. This method can bite, and I am speaking from experience. May I suggest you get room temperature air circulating across those wetted surfaces? HTH Bruce
- 160 replies
- Alert
- vanguard models
Hand Saw Recommendations
bruce d replied to Jonathan_219's topic in Modeling tools and Workshop Equipment
Thank you, Mike, for that useful and colourful description. It makes perfect sense. Welcome to the forum, sounds like you have the skills many of us wish for. Why not post an introduction in the 'new members' section? https://modelshipworld.com/forum/3-new-member-introductions/ Regards, Bruce -
👍 Fantastic.
Mind if I look over your shoulder? BTW, I am sending you via PM the original PDF from which I took the article. There is no additional information there but you may want to see if the photographs can be enlarged any further for details.
- 433 replies
- open boat
- small boat
Electric sanding belt file
bruce d replied to Don Case's topic in Modeling tools and Workshop Equipment
That is exactly what a 'service representative' said when I complained about an expensive machine that broke in the 1980's. Good thing I married a lawyer.🤐 -
HMS EURYALUS by Matiz - FINISHED - scale 1:56
bruce d replied to matiz's topic in - Build logs for subjects built 1801 - 1850
Beautiful work, Matiz. -
Hello Mauro and welcome to MSW from chilly southern England. Very nice engine, looking forward to seeing more of your work.
Deadwood
bruce d replied to Don Case's topic in Building, Framing, Planking and plating a ships hull and deck
Also, this should be useful to understand the placement of a hance. From 'Naval Architecture' by John Knowles 1822: -
Deadwood
I was totally wrong. Turns out the cut-out, called a hance, indicates a step in the dimensions of the rudder. From Steel: This is pretty much in line with the comments from experienced members earlier in the thread. -
Deadwood
I thought that feature at the top of the rudder was to allow a yoke to be dropped in place for emergency steering. -
Deadwood
This may help. Below is a detail from a drawing showing how sternposts were connected to keels in Woolwich shipyard (circa 1820). The subject is a 74 gun ship. A bit later than your subject Don, hope it helps.
