Tigersteve
Everything posted by Tigersteve
  1. A very precise build so far! Steve
  2. If you’re not loving how dark the stain is you can sand it. That will lighten the color. Steve
  3. Sanding the char from cherry wood is tedious and time consuming. One tip I can share is not to sand the char from sides that will be glued and unseen. One is likely to sand pieces out of square. Sanding was done with 220 grit progressing to 400 grit. A test fit of the brass tubes reveals that the holes need to be sanded slightly so the tubes can spin freely. Two coats of wipe-on-poly applied with a fine sanding between coats. The below photo shows the work at this point. Steve
  4. This marks the start of my build of the Model Shipways Mayflower kit, designed by Chuck Passaro. This is the last kit in my possession to build. I've been following the Medway Longboat (1742) project with interest, but I will need to hold off on that project for future. Mayflower will be my third project and first actual ship build. Kit supplied wood will be used for the first layer of planking. I will be using cherry for any wood that will be left unpainted. Deck planking will be maple or cherry. I have yet to decide. Below the whales will be panted tallow. Modifications to the color scheme will be addressed as we are further along. Those of you who have followed my other projects know that I work slowly. I anticipate this project will take much longer than the previous ones. My goal is to attain a quality representation of the Mayflower. I received the Syren Serv-o-Matic serving machine at the end of my Pinnace project and have been sanding the char from the parts. I will be treating the wood with several coats of Wipe-on-Poly before assembling all parts. I will include photos in my next post. Included in this post are photos of Chuck's prototype of the Mayflower. Steve
  5. Minwax natural stain creates a nice look. A little darker than just applying wipe-on-poly. Use pre-stain first. Check my longboat log for the results. Steve
  6. You can easily post and upload from your phone if you wish. It works well. Steve
  7. You should use the funds to purchase Chuck’s Medway longboat. Better quality all around. Steve
  8. Rob, I know you have a lot of projects going, but I’m looking forward to seeing this one completed. So- keep the momentum! Steve
  9. Looking forward to following your project. Steve
  10. 10 or 11 streaks- doesn’t matter as long as they are in proportion. However, I would rip off those two garboard streaks and redo them. It will cause problems when you start laying out the remaining planks. You’ll see when you start trying to match that curve. This log will help: Steve
  11. Start your build log so we can properly guide you. Steve
  12. That looks good. From the photo it looks like the garboard has a very sharp curve. It should be more gradual so the next streak does not need to be bent so severely. Steve
  13. I can’t wait to see how all this modeling content pans out in the next volume! Excellent work. Steve
