Everything posted by Tigersteve
Take the instructions into consideration also. Unless Chuck Passaro has written the instructions, Model Shipways istructions leave much to be desired. Also, cost should be a factor. Constitution kit is very expensive and that’s a lot to spend on a first ship build. So many options and cheaper. You can supplement better wood on other options for less than the cost of the Connie. Steve
Hi Ed-Just wondering if you were going to separate standing and running rigging on some of the rigging plan sheets in the upcoming volume. I’m sure the planning and assembly of this next volume is daunting. Steve
- 3,618 replies
- young america
- clipper
Repositioned ZZ one more time. Bulkheads A and B were shifting out of square on the port side so some strips of basswood were used to shift them back in alignment before the dummy cannon support strips were added. The eyebolt at the foremast was created and added after the void was painted black. Now to put together a wood order consisting of cherry. The decks will be planked with cherry as well. Thanks Mike and Chuck for your input. Steve
I received some new plywood bulkheads from Model Expo. Although the sheet was warped, I was able to salvage bulkhead 2b, which was the one I needed. Bulkheads are set and stern framing is complete. The stern was especially tricky to align and frame. I hope the fairing will balance any symmetry errors. I’ll have one more update before I put together a wood order. The laser cutting on the wood in this kit could be better. Very inconsistent, non square edges. Steve
Nope, you won’t be using any nails. Not sure why they’re included. Steve
- 50 replies
- model shipways
- 18th century longboat
I used 1“x2”x3” steel blocks to square the bulkheads. It worked well. Some of the mast filler blocks are installed while I wait for the replacement bulkhead from Model Expo. The remaining bulkheads cannot be squared until bulkhead 2b is installed. I dry fit the bow filler blocks and beakhead platforms. This will be tricky to install as you need to center the platforms with the reference lines on the bulkhead. I will use the bullwork templates to check the lines before I install the bow fillers and platforms. Steve
Get well soon! Crazy level of detail. It’s so much fun to follow your work. Steve
- 1,035 replies
- royal katherine
- ship of the line
The bearding line was transferred to the other side of the bulkhead former. In preparing to create the gradual taper from the bearding line to the rabbet, I attached 1/16” pinstripe tape. Instructions call for a taper to 3/32”, but referencing a discussion in Mike’s Mayflower build, it must be tapered more to accommodate a smooth transition into the 1/8” stern post after planking. The hull will be planked with 1/16” thick planks. Steve
Good morning, gentleman. I’ll attach a photo of the sheet to clarify. Jim, I do not think it was a design mistake on Chuck’s part. It seems like the shape of the bulkhead was altered by Model Expo to fit the sheet. That still makes little sense. Osmosis, I could definitely contact Model Expo, but at this point I will most likely just make the modification myself. Steve
As expected there are a couple of discrepancies with Model Shipways’ laser cutting and the plans. Bulkhead 2b is flattened on one side where it should be round. The bulkhead former is not an exact match to plan sheet four. Although, it seems to match on the other plan sheets. Not major issues, but annoying nonetheless. The bulkhead can be adjusted easily enough. I wonder why these discrepancies happen. Steve
After much planning, trial, and error, I was able to retrofit this dry-erase board to part of my workspace. The board was no more than $10 at Home Depot. Not magnetic, unfortunately. It is mounted with two closet brackets also from HD. Scrap wood was used to space the board from the wall. It holds the Mayflower plans nicely. Steve
HMS VICTORY 1765 by albert - 1/48
Tigersteve replied to albert's topic in - Build logs for subjects built 1751 - 1800
Awesome Steve -
Chuck, the model is looking really sharp. Great work. Steve
- 421 replies
- medway longboat
- Syren Ship Model Company
Very clear tutorial. Nicely done! Steve
- 1,035 replies
- royal katherine
- ship of the line
