Dr PR
Everything posted by Dr PR
  1. I'm not sure it is a "good call" but it certainly is Schooner's choice. These large latrines are shown on a number of plans for topsail schooners of the mid 1800s. The revenue cutter Joe Lane (1851) is a good example (Howard Chapelle, "The History of American Sailing Ships," Bonanza Books, New York, 1935, Plate VIII between pages 205-206). Chapelle's plan is taken from Coast Guard drawings, and the hull looks very much like your model of the Harvey. Joe Lane was 100 feet long between the perpendiculars, and that would make a 1:50 model about two feet long at the water line. I have also seen these privies placed at the stern. When they stopped building heads on ships there were no longer "heads" for the crews. They had to have something so these latrines or outhouses appeared on some ships. I have photos of a late 1800s schooner Wawona that had a fore deck above the windlass, and it had seats of ease along the bulwark under this fore deck. There are a lot of drawings of these vessels that do not have these privies. I suspect that smaller vessels just had buckets for crew use, but I do not have a reference for that. So you can do pretty much whatever you want. For further discussion of schooner heads see this thread: https://modelshipworld.com/topic/29060-schooner-heads-1700s-through-1800s/?do=findComment&comment=829120 As for the 5 mm planking (9.8 inches at 1:50) I faced the same problem on my 1:48 Baltimore clipper. Some vessels did use pretty wide deck planks, but 10 inches does seem a bit large. I decided to use the 5 mm planking and it looks pretty good. Here are links to what I experimented with and ended up doing: https://modelshipworld.com/topic/19611-albatros-by-dr-pr-mantua-scale-148-revenue-cutter-kitbash-about-1815/?do=findComment&comment=602855 https://modelshipworld.com/topic/19611-albatros-by-dr-pr-mantua-scale-148-revenue-cutter-kitbash-about-1815/?do=findComment&comment=603771 https://modelshipworld.com/topic/19611-albatros-by-dr-pr-mantua-scale-148-revenue-cutter-kitbash-about-1815/?do=findComment&comment=605072 Since you are making a mid-1800s model you can realistically use the nibbing method I used. This came into use about 1830-1840 and was still in use more than a century and a half later. Before that planking (deck and hull) was often "hooked" and that is much more difficult to implement.
  2. It would help if you said what type ship you are modeling. Rigging can be very different on different type of ships. But since you mentioned a book by Underhill, I looked in his "Masting and Rigging of the Clipper Ship and Ocean Carrier." Figure 24 (page 24 in my copy) shows brails attached to the leech (aft side) of the sail at three points and the brail blocks attached to the mast at three points - also stated in the text. However this is for a mast with the gaff permanently attached to a swivel below the mast top (late 1800s configuration). The sail is taken in to the mast by the brails. This arrangement wouldn't work if your gaff can be raised and lowered on the mast to set or take in the sail as was common in earlier periods and on many types of vessels. In Plate 10 (page 50 in my copy) he shows the metal main mast of a barque, and it shows a mast band with lugs for brail blocks and a jackstay. Mondfeld's "Historic Ship Models" (page 325) shows a different arrangement for brail blocks for gaff sail on the mizzen mast where the gaff is lowered down the mast to take in the sail. Three brails are attached to the leech of the sail as before, but the brail blocks are attached to the gaff at three points. In this case the brails would draw the sail up to the gaff. Lees "Masting and Rigging of English Ships of War" (page 109) shows rigging for the mizzen brails similar to what Mondfeld shows. Lever's "The Young Sea Officer's Sheet Anchor" (page 63 Fig. 346) shows the same arrangement as Mondfeld and Lees, but states that the blocks are spaced on the gaff at the same distance from the peak as the cringles (where the brails attach) are spaced on the leech.
  3. juhu I can see where the descriptions you posted could be confusing. I had to tread them a couple of times to understand them (mostly). The gaff topsails had three points where lines were attached. The halliard at the top/peak corner was used to raise the sail. The clew corner was at the end of the gaff, and the sheet line pulled the bottom side (foot) sail out from the mast to the end of the gaff. The tack was the lower corner near the mast, and the tack line pulled the bottom of the sail down. The vessel could have one or two tack lines. With two tack lines one would run down to deck on one side of the gaff and the other tack line would lead down on the opposite side of the gaff. Ideally the tack corner of the sail would be hauled down on the up wind (weather) side of the gaff. The weather side tack line would be pulled tight and the tack line on the Lee (downwind) side would be slackened. In this way the weather tack would take some of the strain on the mast caused by the force of the wind, acting somewhat like a running stay. The lower part of the sail would be blown against the gaff. Then when the vessel changed course to bring the wind in from the other side of the ship (tacking) the tack of the sail would be hauled up and over the gaff, and the other tack line (now upwind) would be pulled tight and the lee side line slackened. However, some vessels rigged only one tack line to one side of the gaff. On some ships the line would be hauled up and over the gaff when the ship changed course, but on other vessels they didn't bother to pull it up and over the gaff when the ship changed course. The instructions suggest that only one tack line be rigged on the model. The instructions say to attach the standing part of the clew line to the bottom mast hoop and the running part lead through fairleads at each corner of the sail. This is described in Howard Chapelle's "The American Fishing Schooner" (W. W. Norton & Co., New York and London,1973) on page 475. This is an excellent reference for American fishing schooners of the late 1800s and 1900s. It shows the clew line fastened to the lowest mast hoop. The line then lead down and thorough a single block at the tack corner of the sail. From there it ran through a single block at the clew corner of the sail, and then up through a single block at the peak corner of the sail. Then it lead down to the deck. The line was strung through rope loops (lizard fairleads) spaced along the edges of the sail so it would not tangle with other parts of the rigging. When the halliard, sheet and tack lines were slackened and the clew line pulled tight it would pull the three corners of the sail to the bottom hoop, causing the sail to collapse into a ball like a "string purse" (a bag with the top drawn together by a draw string). Then a rope (gasket) could be tied around the sail to furl it to the mast head. This apparently was common on the fishing schooners. The instructions say the clew lines lead down to deck on the port side. A less complicated arrangement was used on earlier schooners. The clew line was fastened to the clew corner of the sail and lead up thorough a block at the head of the sail and back down to the deck - this line hauled the clew of the sail back to the mast for furling the sail. This line was needed only on vessels that had the topsail leech side (closest to the mast) attached to the mast with hoops. These sails were furled to the mast when not set. The sheet was loosened and the clew line pulled the clew corner of the sail in toward the mast. At the same time the halliard was loosened so the clew line also pulled the top of the sail down toward the mast cap. The tack(s) was also loosened, allowing the sail to be gathered into a ball near the lower mast head. For topsails where the leech side was not attached to the mast the clew was not needed. All lines were slackened and the sail was lowered to the deck when it was not flying. I have posted a lot of information about fore-and-aft sails and rigging in this thread: https://modelshipworld.com/topic/25679-topsail-schooner-sail-plans-and-rigging/?do=findComment&comment=750865 If this doesn't clear things up post more questions.
  4. I have used rub-on letters as masks for painting. I needed a font and color (silver) that apparently wasn't made at the time. I did find black letters of the correct font and size. I painted the surface silver, and after it had dried thoroughly I placed the letters. Then I sprayed the background color (black) on the surface. When it had dried I peeled off the rub-on letters and I had silver lettering! There are several advantages to this method. One, the lettering won't peel off at some time in the future. Second, the painted letters had no apparent thickness, unlike the rub-ons whose thickness was way out of scale for the painted letters on the original. And because good paints were used there isn't much chance the colors will fade.
  5. Mark, Thanks. Those are very good illustrations of the round and square tuck. When I tried to decipher some of the descriptions I found I ran into a lot of new terminology that I was unfamiliar with that made the descriptions incomprehensible. So I did a bit of research and compiled a lot of information from nine sources on wooden ship building. I thought this information might be useful to others so I have put it together in this drawing. The key term that came up over and over was wing transom. It is the rear most horizontal beam. It is set into the stern post and extends out to the fashion pieces. Below this are several other transoms called first, second, third, etc. that support the planking and strengthen the stern. These transoms may support planking of internal decks, and are then called deck transoms. The part of the aft end of the ship below the wing transom is the tuck or buttocks. The part above is the stern. However some authors say the part immediately above the wing transom is the counter, and it extends up to the lower window frames (if any). In this case the stern extends from the counter to the top rail. The counter is divided into a lower counter, which is a concave part of the planking that extends the stern back past the rudder post. The rudder post passes through an opening in the lower counter. The upper counter extends above the knuckle between lower and upper counters to the lowest window frame (if there is one). The stern is framed by the vertical counter timbers that rest on the wing transom. The taffrail (tafferel) is the upper part of the stern above the windows or counter. However some authors also use taffrail to mean the rail across the top of the stern, and this is common usage on modern vessels. The fashion pieces are the aft most complete frames that determine the shape of the hull at the stern. They attach to the stern post at the keel and the ends of the transoms, and extend up to the top rail. I have noticed that it is common to use the term fashion pieces interchangeably with quarter badge, but none of the authors I read agree with this usage. Quarter badges are curved pieces that attach outboard of the ends of the side planking and extend the width of the stern, giving the stern a rounded appearance from astern. On vessels with quarter galleries the structure of the gallery serves the purpose of the quarter badge. This all applies to ships before the mid 1800s. After this the shape of the sterns of ships changed radically, with round and elliptical sterns and eventually the elliptical transom. But even with these changes the same names and functions of the framing were still used. References Davis, Charles G., Ship Models How to Build Them, Dover Publications, Inc., New York, 1953. Desmond, Charles, Wooden Ship-Building, The Rudder Publishing Co., New York, 1919. Dressel, Donald, Planking Techniques for Model Ship Builders, Tab Books, New York, 1988. Falconer, William, Universal Dictionary of the Marine, T. Caldwell, London, 1769. Landstrom, Bjorn, Sailing Ships, Doubleday & Company, Garden City, NY, 1969. Marquardt, Karl Heinz, The Global Schooner, Naval Institute Press, Annappolis, 2003. McCann, Armitage, Ship Model Making, Norman Henley Publishing Co., New York, 1926. Mondfeld, Wolfram, Historic Ship Models, Sterling Publishing Co., New York, 1989. Steffy, Richard, Illustrated Glossary of Ship and Boat Terms, Oxford University Press, 2013.
  6. I tried one more stain, a Minwax oil based "gunstock" color. The color closely matches the color of the wood I used for the bowsprit after it is coated with shellac. I applied it to the four sides (left) of the test dowel that the masts were cut from, and let it stay on for 3, 5 10 and 15 minutes on different sides before wiping it off. I also did this with the red mahogany stain (right). The cherry stain (middle) was applied for 3 and 6 minutes, overlapping. Allowing the stain to remain on the wood longer produced little or no visible differences. The results were horrible in all cases. Punt! The reason I wanted to stain the basswood masts was to try to match the color of the bowsprit wood. I have decided to just paint the bowsprit, masts and spars. Then there will be no problem getting matching colors. Besides, at 1:48 scale the wood grain wouldn't be visible anyway.
  7. Many excellent examples have been shown, illustrating the many ways sails may be handled and operational states ships may be in. There is one other consideration - much of the running rigging is not aloft if the sail is not aloft (flying or furled). But the running rigging makes up a majority of the lines in the rigging. So if you don't put sails on the model the rigging can look pretty sparse. An option is to place the running rigging aloft, but bring together the ends of the lines that normally attach to the sails. For example, the jib halliard (hoists the sail) can be brought down and hooked to the jib downhaul (pulls the sail down) so the lines are rigged and waiting for the sail to be brought up and attached. So the sail is not in the way of viewing your handiwork but most of the rigging is in place. A lot of the running rigging can be modeled this way. It just depends on what you want to see. If sails and rigging are not your cup of tea you may want to just model the hull with minimal or no masts and rigging.
  8. Please excuse my ignorance, but I have seen several discussions of "round tuck" and "square tuck" and they are all as clear as mud. What is the part that is curved in a round tuck? There are "stern pieces" and "transoms" and these terms seem to be used interchangeably. There is the aft most, more or less vertical planking below the rail that is sometimes decorated and carries the vessel's name. It is usually called the transom in modern vessels. It can be flat or curved from side to side. Then there is the transverse (side to side) planking below the stern piece/transom that extends down and forward to the stern post that the rudder post usually passes through. The planking below the stern is sometimes shown flat or curved (along the centerline). I initially interpreted this to be the "flat or "round" tuck. But it can also be flat or curved transversely, with the part at the centerline more aft than at the sides. So is this the curve of the round tuck? But then I learned that some people say the "round" or "square" tuck had nothing to do with the curvature of the transom or stern piece but was the way the fore and aft planking terminated at the bottom of the planking below the stern (whether curved or flat either vertically and/or transversely). So there are four possible curvatures that could be interpreted by a novice as "round," and very few (if any) writers seem to understand the potential for confusion and just assume everyone knows what they are thinking. Some might call this "functional illiteracy" or the inability to communicate effectively. So can someone tell me what is the common or "official" names for: 1. The more or less vertical piece that extends up to the top rail? It is typically made of horizontal planking that may be flat or curved transversely (side to side). 2. The angled planking below this piece (that the rudder post usually passes through) that can be flat or curved vertically along the centerline, and flat or curved horizontally transversely? 3. An accurate description of round tuck and square tuck and how it relates to 1 and 2?
  9. Bob, I am glad it has been helpful. After wading through all this information I hoped that putting it here would be useful to someone else.
  10. The upper drawing in post #41 is a "jackyard topsail." Leather's "Gaff Rig Handbook" says it was invented to get around rules for class racing where the gaff was limited in length. The gaff yard increased the sail area over what the other gaff topsails provided. Without the spar attached to the gaff and just the spar hoisted to the mast top it would be a "spar gaff topsail." This was also a way to increase the sail area and raise it higher to catch winds above the surface. Without either of the spars it is a gaff topsail - but I have found at least eight different gaff topsail configurations. I have posted quite a bit of information about schooner sails and rigging in the following link. Some of it may be of use in your build. https://modelshipworld.com/topic/25679-topsail-schooner-sail-plans-and-rigging/?do=findComment&comment=750865
  11. I have seen one reference where Douglas fir (Pseudotsuga menziesii) was used for decking on a fairly recent build. It still grows in the Pacific Northwest, although almost all of the original native forests have been clearcut. I don't think it would be a good material for decking. Even here in Oregon where it is harvested we don't use it for decks or fencing that is exposed to the (wet) weather. It is a fairly soft wood and rots quickly. The blueprints for the Cleveland class cruisers of the late 1930s and 1940s say they had two inch laminated planking for the decks. The upper one inch was teak and the lower one inch was Douglas fir. I suspect this was common on all US Navy ships of the period. Douglas fir was cheaper and more readily available than teak. So the more durable teak was exposed to the elements and the Douglas fir was a filler. I have a piece of the teak deck from the USS Oklahoma City CLG-5 that was removed before the ship was used as a target and sunk in 1999. So teak was still being used as late as 1979 when the ship was decommissioned. We replaced the decking in Japan in the early 1970s but I didn't pay any attention to the materials so I don't know if it was laminated.
  12. I have read that sheer poles were introduced in the mid 1800s, so if your vessel dates back before about 1830 it wouldn't have had sheer poles. I seem to recall that I was able to adjust the individual strands of the lanyards that tie the deadeyes together to create a counter twist. Pulling one side (inboard or outboard) tighter creates a torque to twist the upper deadeye and shroud. This takes a lot of fiddling but I have two models where the deadeyes have remained aligned correctly for decades. After you get the deadeyes aligned and they have stayed that was for a few days you can paint the deadeyes and lanyards with varnish or clear paint (flat or satin) to hold things in place.
  13. Gregg, I have had the same problem trying to decipher what different authors and plans mean by "mast length." Most authors just assume you can read their minds! I have encountered four different "mast lengths" in references on mast construction. This drawing shows what the terms "measured length," "hounded length," "deck to top" and "deck to hounds" mean. Measured length and hounded length are the two most commonly used terms for "mast length," although most authors just say "mast length" without actually saying which actual meaning they are using. The same ambiguity often applies to the "length" of the ship, with the three measurements shown in the drawing being used for the length of the ship. I can't see the tops of the masts in the image you posted, but I suspect the "measured length" is what they are talking about. It is the dowel length, and that has to include the measured length from the heel to the cap.
  14. One way to hide the jaggies would be to cut one edge straight and put all the steps on the other edge. Then make the edge with the steps the inside edge that will be hidden by the overlapping plank. I need to make a small boat for my current build so I am watching with interest.
  15. George, I have been experimenting with Minwax wood stains. I have been testing on a scrap of basswood that the masts were cut from. Since I was trying to match what I think is mahogany on the bowsprit - after it is sealed with clear shellac - I tried their red mahogany. After applying and waiting three minutes (according to instructions on the can) I wiped it off. It came out dark brown with no reddish tint, nothing like the color on the can! Then I tried Minwax cherry stain. Again the color on the can was close to what I wanted, and the instructions said I could apply multiple coats to get a darker color. However, I was careless and bought a can of their "gel stain." It is like brown jello. After applying it I had a very close match to what I wanted, but after wiping it off almost no color remained. Maybe a very, very pale hint of brown. I have applied three coats and always got exactly the same result - almost no color. So much for Minwax stains! As you night expect I am a bit frustrated. I'll look up the stains you mentioned and maybe give them a try. But right now I am just thinking of getting some acrylic paints and mixing up a suitable color.
  16. Even in the modern US Navy some color schemes were the prerogative of the Captain, or even the bosun's mates. For example, on some ships the capstans, catheads or chain pipes were painted red on the port side and green on the starboard. On other ships they might be deck grey. Awnings might be grey or white, etc. On the OK City Captain Howell ran a no nonsense warship grey ship. We got a new Executive Officer who wanted to replace the grey canvas with white, with lots of frills and McNanara's lace, and paint all the plumbing a rainbow of colors. "Rodney," Captain Howell replied, "you want to turn my ship into a circus boat!" White awnings in particular were a bad idea on an oil or coal burning ship, especially if it spends time in harbor with other ships. They "blow stacks" during the mid watches to clear soot out of the smoke pipes, and the soot settles on everything. White canvas has to be scrubbed every morning by the deck crews.
  17. Jim. I have been thinking about that. The bulwark brown is more of a milk chocolate color - not quite as red as the mahogany. But I guess it would make sense to use that brown for the masts and bowsprit since it was already used on the vessel. Thinking in terms of the early 1800s and what was available (cheap) at the time, if they had the brown they could use it to seal the masts and bowsprits. I have some Minwax cherrywood gel stain that I will try on a scrap of the basswood dowel to see if it comes close to the bowsprit wood with clear shellac on it. It seems to be a bit lighter than the mahogany, but the can says I can apply multiple coats to get a darker stain. I'll see how that works out. If not, I can always paint the bowsprit black.
  18. Thanks George and OldSalt 1950. The repair came out OK. Now there is a place for the gammoning ropes. On some ships there was a wide gap between the knee and the bowsprit, and the gammoning was tied across horizontally in that gap. But on many schooners the bowsprit seemed to rest on the knee as shown here, so the cross tie wasn't used. For a while I considered a bit fancier knee with a bit of scrolling at the forward end. But I decided that wasn't necessary. These little revenue cutters were pretty basic, with few frills. There are many small details I have to add to the hull and deck before it is ready for rigging. But my biggest problem now is deciding how to paint the masts and bowsprit. I have created a problem for myself. I used a piece of square dowel I had on hand for the bowsprit. I think it is mahogany that I bought at our local hobby shop decades ago. It has a nice medium brown color. When I started looking for matching wood for the masts I learned you can't import mahogany into the US any more - it has almost been exterminated from the Brazilian forests. I had to settle for square basswood dowels for the masts, and you can see in the picture how much lighter they are than the bowsprit. That's poor planning! I wanted to just finish the bowsprit and masts in a natural wood color, but so far I haven't found a stain that will darken the basswood masts to match the bowsprit. The Minwax red mahogany stain is way too dark, even if it is wiped off immediately after applying. I am considering the color scheme on the modern La Recouvrance and Pride of Baltimore II schooners. The bowsprit is painted black from heel to the cap, and the jib boom is a natural wood color. The lower masts are natural wood color from the deck up to the hounds. The cheeks, trestletrees and crosstrees, mast head and cap are black. The topmast is natural wood color, with the heel black on the La Recouvrance. The spars are natural wood color, with the yardarms (tips of the spars) black. So I would lose that nice natural mahogany color on the bowsprit but I will be able to stain the masts a darker wood color than the bare basswood without trying to match the bowsprit color. And I have lots of black paint!
  19. Valeriy is obviously a very experienced model maker. In addition to the clean crisp lines I am impressed that he really understands the order that the assembly needs to go together. And he doesn't forget to clean off the dust before he takes his photos!
  20. I have searched through the forum for information about the color or finish on masts, mast tops and bowsprits and there are only a few posts. I thought I would create a separate topic. I am building a model of an early 1800s American Revenue Service schooner, but I am interested in painting practices on other ship types, eras and nationalities as well. I have found no historical records of the colors or finishes on revenue cutter masts. Rather, in early American vessels, including the early US Navy, there seems to be no standard color scheme. Many ship owners and captains followed British practice, but others didn't. Sometime after about 1830 it seems the US Navy did adopt a standard color scheme. Were masts and bowsprits painted or just left the natural wood color? I have seen both on modern models. I have read that some vessels had "natural wood color" masts, but the masts were greased where the mast hoops moved, and were darker as a result in these parts. If painted, what colors were common? Was the entire mast painted or only parts of it? How did this vary over time? What color was common for the tops (doubling and crosstrees)? I have seen black on some models and white on others. What periods were these colors common? Another interesting discussion was about the color of mast hoops. I read that the hoops were a different color from the masts in the British (and other) navy up to Trafalgar. Then Nelson ordered that the mast hoops be repainted to the same color as the masts so the British ships could be distinguished easily from the opposing ships. Unfortunately, the posts discussion this didn't say what the colors were for the masts and hoops before Trafalgar! All comments and discussion are welcome!
  21. I performed surgery on the bow of the ship. The "knee" that projected under the bowsprit wasn't long enough or thick enough for the gammoning that was needed. Between the 1980s when this project was started and through several moves about 1/2 inch (12.5 mm) was broken off the tip. I decided it was about time to replace the knee. The amputation began with a series of saw cuts to remove material. I was a bit anxious about working on this because the plywood the stem was made of was quite old and the layers might separate. However the wood was soft and cut easily. The operation was successful and the cut area cleaned up nicely. The next step was to fashion the prosthesis out of a (relatively) new piece of plywood. I selected a piece from my scrap box and shaped one edge to fit the place on the hull. After that I used a coping saw to rough out the part. Then I used files to refine the edges to fit the hull and the bowsprit. Finally I finished shaping the part so the curves matched the curves of the hull. After cutting the hole for the gammoning rope I drilled three 1/16 inch (1.5 mm) holes through the part for wooden pegs to give strength to the joint when it was glued to the hull. I made the pegs from bamboo cooking skewers. The new knee served as the template for drilling holes in the hull for the pegs. The photo on the left shows the part temporarily pegged in place. On the right is the finished part glued in place, with some putty to fill in a few chips and create a filet where the planking met the stem. The repair is very sturdy. It looked as if the knee might be a bit too long so I took measurements from a dozen drawings in Marquardt's "The Global Schooner" and averaged the results. The length of the knee was compared with the bowsprit length from the hull planking to the bowsprit cap. The length of the knee varied from 0.17 to 0.39 times the length of the bowsprit outside the hull, with an average of 0.25. The new piece was a bit longer than average but I trimmed it back to 1/4 the length of the bowsprit outside the hull. Now I just need to seal the wood and paint the bow.
  22. Fore-and-aft rigged schooners often did not have rat lines, and the spacing between your shrouds makes it unlikely that the boat had them. Access to the upper mast was either by bosun's chair as Kieth said, or just by climbing the mast rings when the sails were set. And "bosun's chair" is a rather loosely defined term. Often it is just a rope sling that you sit on while someone hoists you up the mast.
  23. I have been using the free Chitubox and I am satisfied within how it works. Their tech support is pretty amazing, often responding within a few minutes to my email questions! 1. You can create custom settings for different resins and save them for future reference. 2. You can add settings for any printer - if you know them. For my Anycubic Mono I just started their Photon Workshop slicer program (not nearly as good as Chitubox) and copied the settings from it. 3. Chitubox sometimes doesn't add enough default supports and the print fails, leaving the part stuck to the FEP film. I have been manually placing supports with mostly good results. Most of the failures I am seeing are always due to not enough supports near edges and corners. If it isn't supported a surface will flex during printing and come out warped. Another related problem is supports that are too narrow at the contact point with the print part - the support doesn't connect to the printed part and is worthless. 4. Chitubox offers many options for designing individual supports, including the base shape and size, support shape and width, support end diameter, shape and depth of penetration into the surface. The only thing that doesn't seem to work correctly is cross links between supports. For me these are a nuisance, but turning them off in the settings doesn't prevent the program from adding them anyway. These can make it very difficult to remove supports from fine details. **** On another topic, I have using denatured alcohol (95% ethanol and 5% methanol). This was recommended by Anycubic for cleaning their Basic Grey resin. It is sold in gallon cans for about $18 the last time I looked - look for it in the paint stripper and wood finish products. It has always been cheaper that 95% isopropanol (isopropyl alcohol), primarily because it is available in gallon quantities. **** And now a question: I read in someone's post that they used hot water or a heat gun to soften warped pieces and then bend them back into shape. Has anyone tried this? Do you heat the part before curing or after? The single greatest frustration I have found with 3D printing is that thin details like hand rails are often distorted by the forces of separating the print from the FEP and then pressures from resin flow as the part returns to print the next layer. These parts are always bent between the supports, and often come out "fat" in between supports. So far this problem has made 3D printing useless for many of the things I have tried to make. If I can reshape the warped railings and pipes after printing there are a lot more things I could use 3D printing for.
  24. Belaying plans (where the rigging tied off on deck) are rarely found for ships because everyone knew how to do it and didn't need a plan. The fore-and-aft schooner rig was pretty simple (compared to a square rigged ship). Normally there would be pin rails along the bulwarks along the sides of the hull (but your model doesn't have bulwarks) and the fife rails at the base of the masts. Lines could also belay to ring bolts in the deck at the base of the masts and along bulwarks and cleats near the bottom of the masts and on the bulwarks. The general rules for belaying the running rigging were: 1. Lines from lower on the mast would go to the more forward belaying points and lines from higher on the mast would go to belaying points more aft on the rails. This makes sense because masts often had rakes leaning aft so the origins for lines higher on the mast would be more aft than those lower down. A few vessels had forward raking fore masts so the rule would be reversed in this case. 2. Lines originating on or close to the masts led down to the base of the mast, and lines originating nearer the ends of spars (square rigged) would lead down to pin rails, cleats or ring bolts on or near the bulwarks. On some vessels lines from the higher parts on the masts were belayed to points on the bulwarks or along the sides of the deck. 3. Lines must run free without touching other lines (or anything else). If ropes rubbed against something they would chafe and this could lead to the line parting. At sea the ship pitched and rolled and everything aloft was in motion. Even in port the winds and tides caused the ship to move. If a line rubbed against anything else it would cause wear on the line and whatever it touched - even a sail. Where lines must touch something else they were wrapped in chafing gear (wraps of canvas and/or rope) that was supposed to take the wear. The idea behind these rules was to prevent lines from crossing and getting tangled with one another. Since there is no original belaying plan for your model you can rig it just about any way you want. Keep these rules in mind and you can't go wrong in rigging the model.
  25. Howard Chapelle would approve! Would this be the hoy Delay mentioned in Shakespeare's "Comedy of Errors" Act 4, Scene 3?
