cog
Everything posted by cog
  1. I wouldn't mind a lemonade ... Nice covered rubbish, mate. What did you use for tarpaulin, plastic bag? I love the paint, and weathering you've given her ... nothing to obvious ...
  2. She must have had a severe bomb blast near the rungs So am I. That's why I buy multiple sets from a single size, instead of various sizes. I use 0.3 mm most
  3. You've added some wonderful detail to her, Nils. She is really filling out to be a lovely spirited lady
  4. I don't mind, I can enjoy all those improved parts. As for the other model ... I will definitely follow your steps again ... I won't ask what build, others will do that for me
  5. Someone wrote that he blackend the PE before painting, which made the pimer stick much better ... I haven't tried it yet, but will
  6. Only those hammocks which are used are put in the netting, so the actual number of sailors and marines
  7. If ypou know the type or rate of vessel you should be able to get that number. You will find it here You posted just before me ... Darn wrong syren, but the page might be useful in future
  8. Have a look at Nills' log of the Pegasus Nice spearhead on your bow
  9. CA seems to give it's own problems with certain finishes ... you tackled that very nicely. Love the way it turned out!
  10. Depends if you like a skinny or a fat wale ... I would keep it the way it is ...
  11. Good to see you back at the workbench, Håkan. Like the type too I know I will enjoy your build Cheers
  12. What looks to bulky? If it's the shelf, considering the thickness of the planks, you could make it thinner, but it will probably look very fragile. I would advise you to add some masts to the model, which will change the overall look of the "scenery". You'll want to stain(?) the shelf I presume ... don't give it a dark colour, which will certainly make it stand out. Start with a light and go to medium darkness from there if you do not like the light colour. Use test material before you stain definitively ... I like the way it looks. I might go for the colour of the parket (floor) ... lovely job
  13. Nenad, You gotta do what has precedence. Right now it's your children, the beast, and whatever else comes first. Sorry to hear about the cataract problem, fortunately you can be helped though. Just drop a note from time to time, so we know you are a life and kicking! Take care, and make the most of the little time you have now
  14. Same to you Nenad, Lovely rudder, or you been painting have your nails
  15. Good to see you back at the model again,Jeff. Nice paint job, although, the image's colour is somewhat off I presume. How's the chess goin'?
  16. I can hardly see the difference, Johann I wish I could be able to do the one on the left, the right hand side is out of my league ... you do have improved tremendously over the years with your brass prowess. I hope, you will not be looking for much more replacements for previously made parts !? In the end you might not be able to finish the model caused by "never ending redo's"
  17. Perhaps you should show the contrast between this and the previous version ... this one is stunning, but you'll probably find fault with it as well ...
  18. Best wishes to you, Daria, and your wife, Mike. You certainly have an understanding lady ... actually ladies, Daria can't run from her room with your contraption between the chairs ... I really look forward to the case with the protective foil removed!
  19. tabycz I presume you are running a windows box. Go to Administrative tools|Event viewer Select Windows Logs|Application the Column Source is the program. Check if iDraftSight shows up, you can find the problem at Level = Error
  20. A happy, and healthy New Year to you too. And that was merely one side ... I think I would have taken the easy way out: Use a file ... lovely piece ofwork and machine prowess
