Everything posted by cog
Must have been an off day, mate ... it excludes you from being German as those usually are very thorough Those golf balls on their tees, ... range finders? If the ladders are the type you have to put the steps at the propper angle you really must have had a ball kicking them into shape
- 345 replies
- graf zeppelin
- trumpeter
Mark loves to paint the sky, he is just modest Jo, you've got the modelbuilder's attitude. You will get through, the first build is the hardest, it is often said. Well, lass, I find all my builds hard, and painting aint easy. Fortunately, I can spray layer upon layer, upon, layer, upon layer, until I changed the scale of my build to full size. As long as I learn something I don't mind. Try to find out what went wrong. When you pull off the paint with your masking tape, the adherence of your tape is to strong. Plastic builders often try to get a less sticky masking tape, or - this will sound odd - put the tape on their forhead, or on their trousers first before applying it to the build to diminish the initial strong stickiness, and hence, avoid pulling off the paint layer(s) I use several brands of masking tape, however, lately I am using the blue or purple "home and garden" painters tape, as those seem to be less sticky than e.g. Tamiya (I use the latter on bare plastic) Keep you spirits up, and go for it, I look forward to see the result of your renewed effort slàinte
Interesting little tool. That is some very nice planking and finish on the deck
- 193 replies
- wilhelmina vii
- fishing
I'd rather keep my toes attached ...
- 446 replies
- zebulon b vance
- deans marine
(and 3 more)
Good to see you at the bench again, Mike. Great restart!
- 969 replies
- hahn
- oliver cromwell
If it should be outside for sailing, can't you bring it inside the shrouds for storing?
so I can drop my anchor through a chain passing through my slippers ... ?
- 446 replies
- zebulon b vance
- deans marine
(and 3 more)
A wee bit (very wee bit) a progress ... Image nr 1. Drill template for the torpedo netting's booms Image nr 2. Result after drilling. Used many 0.5 mm & a 0.8 mm drill bit Image nr 3. First PE, a lot to follow before I can even point at a primer can ...
Looks like the wall of a POW camp ... don't lock yourself in. PER-SE-VE-RANCE. Well done!!!
What is the advantage of glue penetrating the wood, whilst you want to bond two surfaces to one another. It is not that you need "inner bonding", and neither - at least to my knowledge - will the penetrated glue give additional strength to the bond, like e.g. tenons would. Please, correct me if I am wrong
To me they looked higher. However, if the a chain link on it's side can get through, it's high enough. I like the grey, shouldn't use black on the windlass
- 446 replies
- zebulon b vance
- deans marine
(and 3 more)
Very lucky on the small misalignment. The deck does indeed look very well. Follow the yellow brick road ...
- 345 replies
- graf zeppelin
- trumpeter
shape some sides, to bring it up, and than cover it. The "V" is to sharp it could jam the chain ... If you make it higher as per Kevin's photograph, you will only need a vary shallow rounding, instead of the sharp "V" you are working with. I like those images Rcboater!
- 446 replies
- zebulon b vance
- deans marine
(and 3 more)
Looking good, but what about the yellow streaks sloshing down at the stern?
- 345 replies
- graf zeppelin
- trumpeter
Prepping the hull. Drilled the holes for the torpedo net suppot beams, just the port side. Oddly enough, the starboard side is off scale by 2 mm(!) I've decided I've just got to live with it. Work is pestering me. Somehow the real important things in life get the least attention! Pictures will follow ... after I've taken them.
Very well done. You aren't doing so bad yourself on the weathering, Yves. Painting rust is always difficult. You can do chipping, or use rust powder which you add with a brush (dry or moistened) or a combination. Spraying it all will be near impossible to get what you want. You should als take into account how the rust forms. Good effort though
You will probably glue the chain down to the deck. If so cut the last eye at an angle in half and glue the half to the respective "openings". It will look somewhat ... natural ... Your buffing turned out quite nice!
- 446 replies
- zebulon b vance
- deans marine
(and 3 more)
The only thing missing from the flight deck down seems to be the water ... weathering turned out real good
- 345 replies
- graf zeppelin
- trumpeter
we'll be waitin' (impatiently) so no worries mate. We'll try to jot down some nice posts in other buildlogs for ya
HMCSS Victoria 1855 by BANYAN - 1:72
cog replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
You've got the time, a leisurly pace would be nice ... on the other hand, you did see Victory, and other ships which I still have to visit!- 1,021 replies
- gun dispatch vessel
- victoria
