Everything posted by cog
Nulli Cedo by peveka - A Dutch War Clog
cog replied to peveka's topic in - Build logs for subjects built 1901 - Present Day
I think I would pass for seafood on my baguette in the morning So what will you do with the other clog? -
Zutphen is more for tourist. I prefer Apeldoorn or Deventer. Maybe it's the Westerner in me .... You must miss "hagelslag" ....... -
electricity for cars use the same crimping method for sockets and plugs, but it will be slightly if not a lot to big. Used it on the reconstruction of a mini's loom, maybe it would do the job as well. Made some joins for multiple cables out of brass tubing that way
- 227 replies
- BlueJacket Shipcrafters
- Stephen Hopkins
Live in Empe, near Voorst ... Zutphen. I see you swapped living quarters ... lovely region where you are -
Nice build, Pieter. It has a certain panache. Whilst waiting for glue to set or paint to dry, you can do a Dutch clog dance to kill some time #2 if in doubt, use another clamp ... or two -
Steve, nobody told you modelbuilding wasn't a walk in the park!? Or are you, like others on this forum, a glutton for self inflicted punishment/mutilation. Oh, about the learning. You will make the same mistake another time, maybe not all, but some. I know I did ... but then I tend to forget things too ...
- 446 replies
- zebulon b vance
- deans marine
(and 3 more)
Or you are not so easily satisfied ... Like Steve, with his railing now
- 446 replies
- zebulon b vance
- deans marine
(and 3 more)
Beautiful work, both on the brass, as well as on the mast hoops. I like the mold with the little cut to shape the hoop. Very nice jig
I am sorry to have to point out to you, that you will have a serious problem with the door on the second picture. Steve. Iknow you don't like me saying it, but you also want me to point it out ... It won't open all the way as the other door does ... the railing advances to close to it. With regards to mounting the railing: Since you predrilled the holes for the railing, you could have pushed them through, CA on the inside and pull the supports out slightly ... no need messing about
- 446 replies
- zebulon b vance
- deans marine
(and 3 more)
Will you add the lights too on the OKTO? A lot of builders are adding led into their builds ... you could do it with fiberoptics ... like Dubz on his battle cruiser (Star Wars), and you build your models in just the right size for it
Ai, that ain't nice. You don't get a like for that. You want to solve this I presume ... What I would do: Get a piece of wood with the same thickness. Copy the outline to a piece of paper and adjust/correct the crooked part. Paste the drawing onto the wood, and cut it out with a "mini saw bow". Cut it just outside the line, which will make it slightly to big. When finished sand the surplus off carefully. Sand off the drawing and stick it on the keel. If you want an easier way out: Correct the shape of the blue rectangle on the left side. The gap at the bottom will get bigger, but we'll deal with that later. File or sand the top to the horizontal you need. Take some scrap pieces of wood (probably there is some in the box, else you need to quickly start to collect scrap wood )with straight sides. Glue those pieces to the sides of the blue rectangle (front and back), in such a way, the sides of the scrap wood follow the correct line of the vertical slot. Do it on both sides. Voila, quick an' dirty Who said you wouldn't get value for money ...
good luck in finding the wand ... although, I don't know if you really need it
- 4,152 replies
- cutty sark
- tehnodidakta
brilliant Frank. I am very taken by the details you manage to add to even very small items
The further I came in your log, the less obvious it became to be of plastic origin ... it is hardly possible to distinguish it from wood. Very well done, and as Steven mentioned, especially at this scale
- 90 replies
- bomb ketch
- pyro
