Posts posted by Tarjack
Much time has passed, but now i am back
Next step was to build the deadeyes and chainplates for the main-platform.
For the holes in the deadeyes I need a helpfull tool.
The tool it´s made from wood and brass.
The deadeyes are made on the lathe
After drilling the deadeyes the edges are chamfered upward
Now it´s time to made the chainplates.
The plates have the dimensions of 1 mm x 0,5 mm x 12mm; above an eye and down a long hole 0.5 mm x 1 mm
The plates in position
The plates are fixed with glue on the deadeyes ready for stropping
The stropp for deadeyes is made with a real splice
The rope, made from three strands, will opend and for each strand i use a needle to made the splice.
All deadeyes are finish spliced on plates
Have fun
The lantern on the mainmast platform
The shape of the lamp is hexagonal
The floor
Roof
Holder for the lamp
The windows of the lamp
The windows were made from Plexiglas and bone struts.
The struts are to be recorded on the Plexi and cut with a 0.3mm circumsawblade 0.5mm deep into the Plexiglas.
After that the struts may be glued into the jointsCut and assemble the window frame
The roof cap made on lathe
Bracket for the lamp
Lamp in position
The struts of the lamp have been round and made by three parts
This is what the finished result looks
have fun
Thank you all for the nice comments
After some rough forging work let us turn about the finer things.
The Mainmast mars of Royal Caroline
The Saling and Floor
Floor
Floor mounted on Saling
Cover around the floor
The ribs
The railing and stanchions
Steps for the canons
Handle on the canons
Complete canons
Canons in position
the next step is the equipment of the Main-mars..
have fun
The anchor of the Royal Caroline
Agent "P" has discovered a large blacksmith on one of its many rides and accurate documented as there made the anchors.First Step: The material
But here we go, this time without much bla bla ..... let the pictures speaks
I hope you have enjoyed the photos, the next round deals with the large Mars.
Have fun
- Keith_W, dvm27, AnobiumPunctatum and 22 others
25
Thank you all for the good wishes,
HAPPY NEW YEAR
- Dimitris71, mtaylor and Piet
3
Thank you Dimitris,
yes i feel fine now......
- Dimitris71, mtaylor, Piet and 2 others
5
Hello friends,
I am unfortunately somewhat extremely busy at present.
But the next report is nearly finished
Bye for now- harvey1847, mtaylor, WackoWolf and 2 others
5
Hi Mike,
I do the glue on a small disk and from there I take the glue with a narrow blade
Hi Michael,
Yes, it is.
The work with bones is a nice addition and opens the
model horizon to do other things -
Ingenius. I would not have thought of doing that way. Why go to the trouble of making your own goue when CA works great on bone?
David B
because CA glue is the biggest sh......peep
CA shall be taken only to attach small pieces befor glue with real glue
CA did not work great on bone CA crystallises out and the component is destroyed.
Tell me ....... have I already shown, how I've made the blocks ? ..................
Not ?
well then
At this point should be said....... exactly the same method applies to wooden blocks
First, as always choose the material
The length of the blocks and the length of disk apertures are marked on the raw material and cut out on the table saw. The bar is sawn on both sides for two-disc Blocks, so it is guaranteed that both discs openings are parallel
Now the parts are joined together. So that nothing can slip secured with guide pins
Next step is to make the axle holes. The holes are the same diameter as the discs
Bring the pieces together with bone glue.
Now mounting the rotated axes / turn washers ..... if you will, that the discs are portable, leaves the glue away at this point
will be continued
Af-fen-geil!
Now try to translate that!
Peter
mon-key...peeeeeeeep; terrific
he dude booyakascha
- qwerty2008, ggrieco, dj.bobo and 11 others
14
Not happy is not the proper expression.
I pressed me long years before the remodeling
La Salamandre by tadheus - 1:24
Posted · Edited by Tarjack
well done Pawel......Gratulacje
