Posts posted by Retired guy
Wow just love your micro machining Keith.
Regards
Richard
- FriedClams, mtaylor, KeithAug and 1 other
- 4
Coming along nicely Dave 👍
Regards
Richard
Absolutely brilliant Gary well done mate 👍
Regards
Richard
- Jack12477, FriedClams, thibaultron and 2 others
- 4
- 1
There is no disadvantage, but if you bevel bulkheads it's a lot easier to do before installing / gluing and you can see them line up with the bearding line while being flush with keel in the middle
Also it gives you indication that a bulkhead is out, did have to add thin strips to build up
Best regards
Richard
- Seventynet and Keith Black
- 2
Hi Arthur did write a reply to your question on my Bluenose hope you saw it and here are some more tips.
I read the instruction manual and went with the stages, they are very clear and I had no issues.
Make sure you add the reference line to the Keel pieces also the bearding line, and then add reference line to all the bulkheads ( this will help to see if you need to adjust any height issues) and at the same time trace and mark all bulkheads with side bevel on both sides and then sand these before installing this really does help down the road.
These are all the tracings I did
You can see the reference lines in this picture
Hope this helps and have fun
Regards
Richard
- Keith Black and Nirvana
- 2
Your workmanship is absolutely brilliant Gary, also your subtle weathering which make it look so real 👍
Regards
Richard
- Keith Black, Jack12477, thibaultron and 1 other
- 3
- 1
14 hours ago, Arthur Goulart said:
Richard, do I love your build, omg. Clean, that defines it. Best Bluenose build I've seen.
I started my Bluenose today, got them keel pieces off the sheet, checked with the plans, and... They don't match up. Some of the bulkhead slots are offset. The keel pieces actually don't even match up with eachother, the back piece doesn't fit properly with the middle piece, the fit is loose and the back piece is wider. Did you have these same issues? If so, how did you fix them? Did you manage to get the keel perfect to the plans?
Anyways, I'll be definetely following your build along, and checking it every once in a while as reference for mine. Keep it up!
Cheers from Brazil.
Hi Arthur thanks very much for your kind comment hope what I have posted helps all Modelshipways Bluenose
Regarding the keel pieces they do not fit one another and it is the middle piece, lay the keel pieces on the drawing and line up the top if you have to adjust the keyways between all pieces do so then you will be adding some wood to the bottom of the middle keel piece.
From the picture you will see how much was added and also the left keyway you can see I added little stipes as well
Hope that helps.
Regards
Richard
On 3/31/2022 at 6:34 PM, Nirvana said:
Richard, those decorations are amazing.
I am going to try the same, thank you.
Hi Per thanks for your kind comment its quite tricky to make but just take your time.
On 3/31/2022 at 6:35 PM, jwvolz said:That's fantastic Richard.
Thanks Joe she's coming along slowly
On 3/31/2022 at 7:53 PM, gsdpic said:Wow, cool work on the scroll decorations. I had something similar on the trail boards of my America build and the thought never even crossed my mind to try to make it out of brass rod as you did. And nice work on the captain's cabin. Looks like you have a nice large, comfortable work area.
Thanks for looking in Gary took awhile to think how I was going to do the scroll, but it has turned out how I envisioned, Captains cabin is coming along just not sure if this was how it was in the Bluenose.
Regarding the work area, it is very comfortable work area, started with this
Then made all tables
On 4/1/2022 at 4:21 AM, CPDDET said:Nice way to "think outside the box", Richard. The scrolls came out beautiful!
Hi Dave thanks for your kind comment
On 4/1/2022 at 6:34 AM, bhermann said:That is a really nice treatment for the scrollwork, much nicer than the free hand drawing I did!
Bob
Thanks Bob they have turned out how I wanted them to look
On 4/1/2022 at 8:30 PM, FriedClams said:Oh, I do like that brass wire scroll work Richard - very nice.
Gary
Hi Gary thanks for looking in, do like thinking how to make, then making/soldering small items
Thanks to everyone for you comment do apricate it very much and also for all the likes
Regards
Richard
I was wondering how I would do the scroll around the hawse pipe, I tried to carve the scroll but the kit supplied wood is no good for this so thought about painting it but trying to make both the same 🤔
So came up with making the scroll from .018" brass rod, using a pattern from LB Jensons book, in the book it does say ( these were drawn free hand cutting in with a chisel and painting with gold leaf) and also says scrolls done in summer seemed to have more knobs than those done in winter, being in flower, so to speak.
This is the start of the two scrolls as you can see there were some very small parts to solder together.
One completed and then I filed it down
These are the tools I used.
Now got to finish the second one and then paint yellow same as cove.
Thanks again to all who comment and for all the likes do apricate.
Regards
Richard
On 3/12/2022 at 9:04 AM, Sabre said:
Nice, very nice and a lot better than my efforts.
Thanks for your nice comment Sabre
Regards
Richard
On 3/12/2022 at 8:34 AM, FriedClams said:
So good to see you posting again Richard, sometimes it's good to take a break. Nice progress and such clean work on the cabin. I especially like the curved wall and moldings. Nice work area too!
Gary
Thanks Gary was playing about with a 1/32 scale Lancaster changing the cockpit area but still doing small parts to the Bluenose.
Regards
Richard
That is some very nicely laid planks Keith don't see a gap anywhere 👍
Regards
Richard
- Keith Black, mikegr, FriedClams and 1 other
- 4
Coming along brilliantly Dave 👍
Regards
Richard
Thanks for your comments Wally and Dave, these are the drawings from LB Jenson book the Bluenose 11 (these are to help with my build if not allowed please delete)
He shows a drawing of the Bluenose which I have used for stove and chimney and the other two show the inside of the Schooner Caroline Rose.
This is part of the Captain cabin
This is where I am now and will paint it white inside.
Will be adding some curtains where their beds go
Also got the cove painted and also the bowsprit painted and installed
Until next time
Regards
Richard
Getting close to a year without a post 🤔 where does time go 🙄
A while ago I started making some parts inside the main cabin, used the information from LB Jensons book but they are not from the Bluenose, they are based on photographs of the Schooner Caroline Rose.
Just wondering if the inside would be painted white
Regards
Richard
Very nice Keith 👍
Regards
Richard
- mtaylor, FriedClams and Keith Black
- 3
Brilliant Keith 👍
Regards
Richard
- mtaylor, Keith Black, KeithAug and 1 other
- 4
A joy to watch an artist
Regards
Richard
- KeithAug, FriedClams, mtaylor and 1 other
- 4
Not nice to hear pinging, could you put a small bow in the bowsprit so you don't need to tighten the rigging as much 🤔 you might get this pinging again 1 month or a year or two later, just a thought.
Regards
Richard
- Keith Black, FriedClams, KeithAug and 1 other
- 4
Germania Nova 1911 by KeithAug - FINISHED - Scale 1:36 - replica of schooner Germania 1908
Just caught up with all your brilliants' Keith just outstanding 👍
Regards
Richard
