Everything posted by realworkingsailor
Yeah... nice quick way to clean up blocks by the dozen... Although you started with some pretty rough looking customers there..... Andy
From what I hear, Anja, you don't have anything to fear from the Rocky Mountain fleet., or the Northern Lakes Guard, even the Mississippi Peacemaker or the Seaboard Fisheries Patrol. In honour your stabilizing effect on the European Block, your peaceful merchant vessels are granted free and safe passage. Andy
- 1,668 replies
- syren
- model shipways
Are you sure there was a mistake somewhere? I can't see anything wrong.... good fix When in doubt.. listen to the wabbits.... but don't believe a word those groundhogs say... they're nothing but a pack of liars... Andy
- 1,319 replies
- caldercraft
- Victory
It should hold it's shape when it's cooled down with minimal spring back. EIther way a bit of minor bracing and you'll be good. Andy
- 326 replies
- vinal haven
- steam ship
I think he's trying to intimidate someone.... I wonder who.....
- 1,668 replies
- syren
- model shipways
Something you might want to consider trying instead: http://www.micromark.com/spike-insertion-plier,8242.html Much more accurate. Andy
We're all with you Sjors, build her the best way you see fit, she looks great no matter what Andy
Perhaps I should have explained better We're just talking hot water here, just below the boiling point. Enough to soften the styrene and make it a little more pliable. As I said before make sure you have all your window and door openings cut first. Then just take a frying pan large enough to fit your sheet in and fill it with about 1" or so of water. Bring it up nearly to a boil (and even if it is boiling, there's still no worry). Dip your sheet in for a couple seconds, remove it and form it around your mandrel. The mandrel should be pretty much the shape of the curve of your pilot house. If you do the same thing with a second uncut sheet, you can lay that one over the first one and clamp them down with rubber bands or what not. I'm imagining the radius for you pilot house (at this scale) is reasonably generous. You could avoid heating, but the plastic would simply fight you at every turn (pardon the pun). Another, dryer option you can try (and this really works better when there are no openings to cut), is to simply wrap they styrene sheet dry around a mandrel and heat it with a hair dryer. Hope that helps.. Andy
- 326 replies
- vinal haven
- steam ship
Great... Pirates of the Dairy Case..... Andy
St George...Is that your final answer? Yeah.. your last one would be correct. Built 1924, scrapped 2005 at Industrial Marine and Salvage, Port Colborne. I love that place despite the obvious saddness of ships being cut up, you do get that last chance to see some really old graceful ships And Jan.. I've not posted that one before... you may think you've seen it before... :P Andy
Sorry Anja.... waayyyy off... you'll have to look harder than that.... Wayne.. thought you guys liked "Andy Original" photos... makes things more fun right? Andy
Then maybe Wiki got the photo reversed... http://upload.wikimedia.org/wikipedia/commons/8/8a/USS_Idaho_sunk_with_USS_Mississippi_in_background.jpg Anyway.... it's still both of 'em!
Got 'em Both... "Kilkis" Ex USS Idaho (Sunk in foreground) and "Limnos" (Ex USS Mississippi) in the backgorund. Andy
She will also come with much better instructions... and even better than that... the guy who designed her has been known to hang around here...so I'm told.... Andy
- 773 replies
- san francisco ii
- artesania latina
Robbyn.. to really secure your channels, no matter which glue you use, it's best to add some pins. Basically take the head off a brass nail, and drill a hole in the inside edge of the channel. Glue the pin in the hole with the pointy end out. Do that 2 or 3 (or more, depends on the size of the channel) times. Line up the channel and press firmly enough to the hull of your ship to make a little dimple, then drill another hole, at the dimples in the hull, to accept the pins. Doing that will ensure that your channles are strong enough to withstand any pressure from rigging. Andy
- 773 replies
- san francisco ii
- artesania latina
I agree with Augie... take all the time you need... no rush just because we're all nipping at your heels like a pack of crazed chihuahuas Andy
Battery Pwered Demel
realworkingsailor replied to hopeful's topic in Modeling tools and Workshop Equipment
Never noticed any problems with mine... seems to have all the power and torque of the full size. No trouble cutting through nickel silver model rails with a cutoff disc. And being smaller it's quite a bit easier to control... Andy -
As long as you've got a decent mandrel, a little hot water and you should have no trouble bending the sheet around.... just cut out any openings first and have another layer to sandwich the piece.
- 326 replies
- vinal haven
- steam ship
Ahh... see.. you're getting the hang of it.. Auther K Atkinson Yup, rail car ferry, steam powered... used to run on Lake Michigan. Andy
I've got to do something to keep you guys challenged.... (besides.. I don't have to worry about violating any copyrights) Andy
