Everything posted by realworkingsailor
Never Mind.. Battleship HMS Vanguard
Obviously the Queen Elizabeth and a King George V class Battleship
Just make sure you have a planned escape route when you do.... Oh yeah... Keep your head down when you run.... something might get hurled in your direction too.... Andy
Hey... that looks pretty sweet.. You're quite the artist! Andy
- 366 replies
- granado
- caldercraft
Ohh.... I think I get it... (BTW... Canada) Have you ever tried Maple Syrup on Ice Cream? Andy
Pretty sweet Augie! No more schooner for you... Andy
- 1,668 replies
- syren
- model shipways
Painting White Metal
realworkingsailor replied to Micklen32's topic in Metal Work, Soldering and Metal Fittings
I've seen it sold in bottles, for a better price than the rattle cans, but not that often.... Andy -
I've got a good iron wiht an adjustable power setting, although for most work I do I leave it at the full 25 watt setting. This is where plug in ones help, too, let it get really hot..., that way it only take momentary contact to make the solder flow. and make sure you contact both pieces, otherwise you'll get a "cold" solder joint (basically a weak joint that won't last). Your solder sounds ok for this kind of work. I know there are a lot who recommend silver solder, but I've never felt the need (And I'm sure that's going to stir up a hornet's nest.. ). As for the metal.. you can solder copper, or brass equally as effectively. Andy
- 773 replies
- san francisco ii
- artesania latina
First off, you need to clean the metal, get rid of any residual oils leftover from the molding process and any contaminants from handling (mild dishsoap works well enough, rinse afterwards). Leave everything to dry thoroughly and don't handle the parts with your bare hands. As for paint, I would recommend that whatever you choose, first start with a primer. I'm a fan of Tamiya, myself, as it will go well with just about any type of paint, acrylic, laquer or enamel. The tamiya primer is dry enough within an hour or so, so you can paint overtop pretty quickly. Let your paint dry thoroughly, then put a coat of sealant, like Testor's Glosscote, or Dullcote, to protect the paint. This will make it less prone to chipping, or wearing off corners etc if you need to handle the items. Andy -
It looks good for a first try Soldering is one of those things that always gets better with practice. My first solder joints where even lumpier than yours. You'll know when you get it right, with a good hot iron the tiniest drop of solder will just get wicked in between the pieces and you'll never see it again.. just a small heat stain on the part Andy
- 773 replies
- san francisco ii
- artesania latina
I'm surprised you've got time to do anything hobby-like at all, if the thing to which you are referring to is the thing of which I am thinking... hopefully things will go better for you soon enough... Out of simple curiosity... since you live on the west coast.. why not saunter down to the warf and see if one of the local fish mongers has any idea? (If you have the time, of course...) Andy
I must agree with everyone else here, you work is impressive. I admire how clean and tight and crisp your work is. I do admire the Brandenburg ships, yours is no exception. Very nicely done. Andy
Hrm.... Jan.. you did... she's yours..
I think she's French: CV Bearn Andy
Hey Grant, glad to hear you're on the mend. And yes.. single malt is one of those great simple pleasures in life.. although I've never heard of pouring it over ice cream.... Andy
I've had some startlingly fast results using acrylic paint thinner, basically a mix of ammonia and glycol esters. If you have Windex brand window cleaner, or some other ammonia based window cleaner, that should work just as well. Andy
I've done it too... I know how you feel.... Andy
Looks like someone attacked the bow with liquid paper..... you should be ok this time Andy
I dunno either.. the first part of the instructions makes sense.. but then the rest of it... Waugh! I've tried searching online for variou iterations of Gilson Tackle.. Gilson Block, Gilson Winch..etc... Lot's of old rust.... not much information.... Sorry... Andy
Hey Popeye... Haven't heard form you in a while.... must be the book.. Andy
- 552 replies
- maine lobster boat
- Midwest Products
