mikegr
Posts posted by mikegr
7 hours ago, RogerF said:
Full build on youtube.
This is the first full build of FH's deluxe Hood I've come across.
There are many interesting details to be found here. In particular there are (for me at least) interesting sequences of build where PE and plastic parts are combined, paint masking and as for the rigging.... well, not sure I'm up to that but by the time I get that far I'll probably do the same but not use copper wire for some areas as in this build. Now I just need to find the time to get on with my own model.😬
The Asian channel owner makes elite builds. The sea bed is top world class, comparing to Flodberg and Katseas creations. However require more materials and its more complicated to be built.
- Old Collingwood, mtaylor, lmagna and 2 others
- 5
I am in a hurry to finish it by this Sunday at least the model if not the sea bed.
I glued almost everything except few pieces left as well as rails on main deck. I did also deck weathering. After gluing parts, rigging and weathering. I do rigging first before works comes first , then pleasure(rigging is boring).
7 hours ago, king derelict said:
Hi Mike
Yes, there are periods where the log seems to be pacing the build!
My plan with the sea scape is to add toilet paper soaked in dilute white glue to modify the sea and add some ordered swells as well as bow wave. I haven't done much of this so I'm not aiming for heroic seas but rather those quiet seas in the North Atlantic between the rough stuff
Alan
In that case you can also consider some watercolor paper bases
- Canute, lmagna, Old Collingwood and 1 other
- 4
On 10/6/2021 at 2:47 AM, king derelict said:
And just in time to avoid falling off the front page a late update.
That is another type of addiction.
Sometimes I compress my work time in order to post my updates regularly.😁
On the aerial picture I sent you can see the weird color of the Atlantic although this might be somewhere of North UK coast.
The problem with aluminum foil is that sea will look a bit messy as the waves are not pointing to a specific direction. Of course this does happen sometimes in reality its just for me looks a bit unusual.
For wood I use dry type from 80 to 240 grit. For hull sanding and other tasks I use sanding sponges I like their grip and the shape.
I also use rectangle ones which I replace the paper once it get worn. I glue it with PVA. Sometimes I combine grit. One flat side 240 grit, other with 120 etc...
- thibaultron, Canute, mtaylor and 1 other
- 4
On 10/5/2021 at 5:14 PM, Haze Gray said:
Hi Ron, pretty easy actually, you can just pour some in by the corner.
I think slicing software does estimane the amount of resin needed. Is it reliable?
- mtaylor, thibaultron, Egilman and 1 other
- 4
On 6/6/2021 at 3:19 PM, ChrisLBren said:
LOL - at 130 per month for the next 10 months - I cant leave this build to chance until he earns the skills. And Im having too much fun with it !!!!!!
Because its for him.
Otherwise a modeler wouldn't spend 1500$ for a kit with plastic deck🙂
- CDW, thibaultron, Baker and 5 others
- 8
Opening the box of the Pyotr Velikiy , its easy for someone to realize why these ships are considered battlecruisers. Their size is close to ww2 battleships. My workbench is occupied so i took the photos on top of my deep freezer, the only available flat space in the room.
The kits itself has 550 pieces and its 72 cm long. It has 16 sprues, 3 of them in clear color and one additional with PE radar parts. The radar parts comes both in grey and clear plastic as well in PE form.
The instruction manual comes in 24 pages plus the illustrated sheet for painting reference. The hull is also in one piece, no waterline
option is available
The PE parts as expected are more than the previous kit and certainly they wil take this ship to another level of details. The railings provided could be enough for two medium size 1/350 ships.
Finally i took two comparison shots so we can better understand the size of the kits.
Pyotr Velikiy is in the middle, Panteleyev on the upper side and Sovremenny at the lower.
I resized Pyotr Velikiy to 1/700 and compared again. Still stands with dignity
I hope i can take some comparable shots with the finished models soon.
Admiral Panteleyev.
This is No 04516 , PE i ordered are for the later versions of the kit 04517 Udaloy and 04531 Admiral Chabanenko. These were hard to be found in Europe, i hope there won't be dramatic differences between 04516 and 04517 same class ships.
This one is slightly bigger about 46cm. There are also 390+ pieces here but i see 9 sprues. Perhaps Trumpeter has limited the counter to 390.
There is waterline/full hull option except that bow sonar comes as a separate part now. A pleasant addition is the illustrated color sheet for decals and paint guide, like in most 1/700 kits. Pretty useful. I will use it as a reference for the Sovremenny kit as well. Another difference is a sprue with clear parts, not only for the helicopters but for some superstructure parts. Interesting.
These ships have two distinctive complex radar towers. These are well made with good detail. Adding the PE parts i think will make the kit look quite handsome. Finally, a small set with PE parts mainly for the radar assembly is provided as well.
Overall it is a nice kit comparable to the more quality series of 1/700 scale like the Battleship Roma, West Virginia and more.
The PE set arrived in perfect condition. It looks quite decent and very detailed. There is an additional set comparing to Sovremenny kit containing many high detailed grills. This is definitely a welcoming addition. If built properly will result in one of the most impressive modern ship kit.
For the Walrus aircraft there is not PE parts. So I had to based on my skills. There is a set Walrus aircraft from flyhawk offering amazing details but waiting some weeks to get them is not an option. Besides this is an obsolete built, 100% perfection is impossible. I mostly use these models as a test field for materials and techniques that is haven't used in the past like PE, rigging and ofcourse making realistic sea bed.
The kit is quite similar to the 1/700 series. It has a full hull/waterline option as well as some basic PE parts for the radar mast. The total length is almost 45 cms. There are 8 sprues for a total of 390+ pieces according to the box.
The instructions are in the form of a single color 12 page booklet with detailed pictures. Painting instructions are in black and white which i dont like much.
Finally there is one decal sheet with lots of number decals, so builder can choose which ship of the class will resemble.
As for the PE parts as wasn't sure what to expect as i had no other experience with this company.
There is on sheet with railing bars, and two others with various parts. Although packed with caution i noticed a few bends. Also the last sheet had some marks like light rust (on PE?). I sanded it and gone right away. Bends also were not an issue no part seemed damaged.
I did some cut testing. With used blade on hard and soft surface. Finely attached parts would cut easily while thicker joints could be cut only on hard surface without the risk of damaging the part. In short, while they are not as crispy and easy to handle as A quality PEs, there are better than various chinese makers i have used in the past. We will see in the future how they appear on the model.
Normaly i do not collect or build 1/350 models cause of their bulk. However as i was browsing i found a company called microdesign specialized in PE parts for Russian - Soviet (and not only) model planes, ships ,armor etc. They have over 5500 product codes, pretty impressive. Their prices were quite tempting, especially off Ebay were -30% . So i placed the order right from a Russian store, they even respond on Sunday and after two weeks i got them in hand.
Meanwhile i had ordered the ship kits from nearby Bulgaria, got them in just 2 days.
I will start from the cheapest one Project 956 Sovremenny. For the 26 euros paid i didn't expect much but a 3 ship display would look great so why not...
- cog, Old Collingwood, thibaultron and 4 others
- 7
Rebuilding the fleet by mikegr - 1/700 - restoring old plastic models
I finished rigging added rails and whatever boats I could found as I have missed a couple. Took the pic with light near the bright wall so 0.05 mm elastic rigging can be visible. Anchor chains and weathering are left for tomorrow.
