yamsterman
Posts posted by yamsterman
hi all
some more photo experiments.
some with just led room light on.
the yellower ones are with the desk lamp on.
1/10 scale resin busts.
naval midship man about to board enemy vessel
a pirate!!!
and just for fun wellington and napolean.
moderaters feel free too move these if they are in the wrong section.
cheers...mick
- GrandpaPhil, mtaylor, Canute and 1 other
- 4
- GrandpaPhil, Chuck Seiler, Canute and 1 other
- 4
hi guys
please note this item is no longer available
cheers....mick
hi guy
I reckon the hinges work out to approx 1/2 inch thick in real life.
started off with k+s special shapes metal 1/16 by 1/32 as the basic strap material which was the soldered and filed to shape.
In an ideal world i would have prefered 1/16 by 1/64 but could not get hold of any so they do look a bit chunky.
Im not sure the guys that built these ships would have been overly concerned, they would have probably used/manufactured whatever was to hand.
Im off now to scour the internet looking for brass strips!!
regards...mick
- mtaylor, Ryland Craze, Canute and 1 other
- 4
hi carl
thanks for your kind words . finding another job is going to be a long slog.....not entitled to benefits other than jobseekers allowance for six months,which will not amount to a great deal ....apparently i have too much money in the bank!!!!!
taking the opportunity of my enforced sabatical to catch up with a few jobs before i can get back to modelmaking.
parents estate will be resolved this week so one less thing to worry about.
must endeavour to get washington galley finished and then decided on the next project.
just had three deliveries from chuck at syren will take the obligatory photos once the camera battery has charge up!
cheers...mick
hi all
cant believe its been so long since i posted anything!
unfortunately two family bereavements, both parents, and being recently made redundant after 27 years with the same company has kept me otherwise engaged.
I have not forgotten about everybody and the site and hopefully will soon be back in the thick of it.
cheers....mick
hi will
look forward to you starting your log
with regards to the stove.......silver solder paste as used by jewellers was the prime "glue".
comes in three basic forms low temp medium temp and high temp.........start with the high and work down to the low for the final bits.
i did try using two part epoxy on a previous attempt but was not happy with the results.
cheers....mick
hi again
i forgot to mention in the previous post that a little help is required.Regarding the lateen rig. The plans show only the basic position of the ropes.
my knowledge of lateen rig is scanty to say the least.
some help with regards to how the ropes were attached to the yards and how the ropes were joined together (see photos) would be gratefully received.
cheers....mick
- GrandpaPhil, kurtvd19, tlevine and 8 others
- 11
working a crazy shift pattern that let no time for anything paul.......shift pattern has now reverted to something like normal.
mick is now officially a happy bunny
cheers for now
- mtaylor, paulsutcliffe, Canute and 1 other
- 4
hi all
just stopping by to let you know im still here.........work will recommmence shortly!!!!!
cheers...mick
- Tigersteve, Canute, kurtvd19 and 1 other
- 4
- jwvolz, Rustyj, Tigersteve and 16 others
- 19
- usedtosail, druxey, davec and 15 others
- 18
Hi paul
No straight out of the box .....just snipped off about 0.5mm above the joint and bashed away!
Cheers....mick
- Canute, mtaylor and paulsutcliffe
- 3
Hi paul
The hinges are 1/16 by 1/32 brass strip silver soldered to 1/16 od brass tube.
The pins are 1/16 brass rod soldered to the same diameter tube , the tube then filed to the width of the rod.
The two are connected by a 0.8mm diameter brass rivet which is cut off and the end peinned over with a small hammer.
The hinge will be glued to the gunport with epoxy and smaller rivets dropped through the holes to represent bolt heads.
The pin will locate into the hull.
Hope this helps
Cheers.....mick
- alde, aviaamator, usedtosail and 17 others
- 20
- aviaamator, Valeriy V, hexnut and 7 others
- 10
Hi all
On a slightly different note a lovely slab of beech arrived the other morning for the new workbench.
Still got to make some drawers for the left and right sides.....vacuum lived in the middle!
Bench top is 2m in length.....plenty of space for tools!
Just waiting for the danish too dry.
Cheers.....mick
THE 74 GUN SHIP by Jean boudriot
in Traders, Dealers, Buying or Selling anything? - Discuss New Products and Ship Model Goodies here as well!!
Now sold.
