Everything posted by AnobiumPunctatum
The planking is looking really good
- 452 replies
- cheerful
- Syren Ship Model Company
It's allways fascinating to follow your logs. I've learned a lot fromin the past years. Thanks
- 191 replies
- young america
- clipper
THE 74-GUN SHIP by Jeronimo
AnobiumPunctatum replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
Great, really great.- 194 replies
Looks really good. Your work is very accurate and precise.
- 504 replies
- washington
- galley
Congrats Ed. The book would be a nice Christmas gift
- 3,618 replies
- young america
- clipper
Really intersting jig for the milling job, Mick. I'll cover your idea for my build. Thanks
- 504 replies
- washington
- galley
Shipyard H.M.S. Wolf, 1754 - 1:72 Scale Laser Cut Kit
AnobiumPunctatum replied to catopower's topic in Card and Paper Models
Perhaps it's interesting for you. Here's the link to the company which produces these cardbord and some nice paper kits: http://www.model-shipyard.com/html/indexuk.html -
Really nice progress, Nils
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
I've finished the "Disposition of Frames" drawing. I am not quite happy with the position of the timberheads between station line 17 and 19. But this is the position I got from the As Built plan of the Fly. Next I will built my building board and start with the model.
- 102 replies
Very nice hull, Ed . Your method is completly diefferent from every other methods, I've seen before.
- 191 replies
- young america
- clipper
Thanks druxey. That sentence helps me a lot. I hope now, that I can finish the drawing until this weekend.
- 102 replies
@Ed Thank you. I use also the waterlines of the half breath plan. I am sure that's a lot more work to draw this manually because it was more than enough work with my CAD. You're right. But it made a lot of fun to do this exercise. Also I had some points I want to check with the drawing. On the Half Breath Plan were only the positions and angles of every second cant frame given. I wanted to check the reconstrction of the other cants. What's with the position of the gun ports? WHich cant frames do I have to shift? Is every timberhead given in the Sheer and Profile drawing on top of a frame? If I compared the position of the timberheads given in the Sheer and Profile of Fly and in the DOF plan of Cygnet, I found some alterations, for example at the fore cants. I wanted to check the consequences for the frame design. @druxey I've checked the position of all timberheads of the Sheer and Profile drawing and my reconstruction again. At the after cant frames I found two timberheads whose position do not really match with my cants. The position of the other four timberheads is ok. So I think to change my design will not solve the problem. What do you think is the better solution? To move the timberhead or to add a timber between the frames and not to change the position. @all Thanks for your interest and hints, which I really appreciate.
- 102 replies
Thanks for the Likes and comments @druxey Hopefully yes, but I will check this again and add them to the drawing. There is one timerhead, which was also shown on the Cygnet drawing that is positioned between two frames.
- 102 replies
Today it rained all day, so I had enough time to finish the design of the cant frames The Bollard Timbers and Hawse Pieces are missing to complete the planning of framework. The individual components and the frames I'll draw later during the build. Next, the construction of the two-stage slipway is on the ToDo list, then I can lay down the keel for the model.
- 102 replies
Hi Mick, I'll follow your log with interest. It's a very uncommon type of ship and so very interesting
- 504 replies
- washington
- galley
In the moment I am working on a corrected disposition of frames drawing for my sloop The basis are DOF of Cygnet (ZAZ4691) Dimensions given in "The Ship Builders Repository", 1788 (1) Dimensions given in Steel "The Element and Practice of Naval Architecture", 1805 (1) Antscherl TFFM, Volume 1 (1) The dimensions I took from Allan Yedlinsky "Scantlings of Royal Navy Ships 1719-1805". The original books are unfortunately to expansive for my hobby budget. The different timbers for the keel and the knee of the head, I took from David's book. I only adapt these to the other proportions. After a lot of measurements in the DOF of Cygnet and comparing with the given dimensions, I decided to follow Steel. I am really surprised how well the frames fit to the original drawing. If you compare the numbers of the sweep ports with the original drawing, yo see that there is one port missing, because it was not shown on the As built drawing. In the moment I am drawing the cant frames, which is much easier as by my second project.
- 102 replies
