Everything posted by AnobiumPunctatum
Hi Kris, sorry to hear all this. If you need help to use your drawings in another more common format, I can help you converting your Rhino files.
It's looking really nice, but a shame that you hide your beautyful framework.
- 1,041 replies
Hello Dave, I took my time this morning to read through your build log. Really nice and clean model.
- 143 replies
This week I got a "little" parcel with really nice milled boxwood from hobymill.eu. Vahur put also some extra sheets and wood samples to my order. The timber has real nice color and was excellent packed. Also the contact and information of Vahur was great. Hobbymill gets from me ⭐⭐⭐⭐⭐ of five possible. Highly recommended
Thank's very much. Let's answer your questions: In the moment, this is my plan but I don't know if I will change this with more experience in frame building. The advantage of the method are the different levels, which make the build much easier. By the testframe I did not have any problems, to get the frame out. I don't need much glue during the build. You can also use a colophane foil or a thin layer of clear varnish to avoid problems. Yes, I got one last year. The idea is a first result of my learning curve. I have a lot of other ideas, but for these I have to learn 3D construction. All my drawings are in the moment in 2D and for Triton I will not change this.
The last two years I needed my workshop as homeoffice. I started building Cheerful at the dining table, but this was also not a good idea. Now I am back in my office which gives me the possibility to use my workshop as shipyard again. To practice I build a test frame from an old piece of wood. Instead of a paper base, I milled a template from plywood, which already takes into account the different thicknesses of the futtocks. On this template, the futtocks were first glued together and then the chocks were added. Finally a photo of the finished test-frame. Now I can start with the serial production.
In 1/48 I don't know an manufacturer of mediaeval figures. In 1/72 you can find lot of figures by Valdemar Miniatures. I planned to use them by a small cog diorama.
