Posts posted by ERS Rich
The kits from Scale Auto Works look awesome…..
Good luck with the Bugatti!
-Rich
You need a reference line - it is the waterline.
Mark the waterline. Use the plans to mark the waterline on the stem and stern post. Place the model on blocks so the stem and stern waterline marks are level. Connect the two marks with a marking gauge.
Use the plans, and dividers, at each frame transfer the distance from the waterline to bottom of the whale to the model. Do same for top of wale, gunports, etc.
Fantastic! Sounds like you are ready to go! Same as full size woodworking, just smaller.
Cheers
- Keith Black, mtaylor and Scottish Guy
- 3
Welcome to Model Ship World. I don’t know about the difference between the 2 Victory kits…. Certainly these kits will help you increase your skill. Consider a plastic kit has all the parts made, each part needs a little work, sanding, filing, to get a good fit. So less time building. Knowing how to apply a finish is crucial. Plastic offers the opportunity to experiment with different paint to find out what works best for you - enamel? Acrylic.? Brush or airbrush?
The Hallberg Rassy 57 yacht is certainly a good subject. Recommend that you find a similar wooden Yacht ship kit before trying “scratch building”. Consider jumping from plastic to wood modeling is a big step. Because if it’s new to you, wood working takes some time to learn: understanding tools, sharpening, and wood characteristics. However, you may already understand this! If so you are ahead of the average bear.
Another advantage of a kit is the instructions will lead you through the process, and some of the components will be prefabricated, saving time, and there are plenty of parts that require scratch building techniques.
Agree that Vanguard is a great way to get started.
Good luck with your projects,
-Rich
- 3
Hi Kurt,
A couple of things if I may.
Following up on our conversation about finishing. Understand avoiding oil based products and sticking to acrylics. Shellac is another alternative. It’s alcohol based, so the alcohol evaporates quickly, but there are fumes to manage, though they can dissipate quickly when applied in small amounts with a brush. I use rattle can shellac on hulls, applied outside.
Regarding planking. My results improved after understanding the concepts of belts and plank width/tapering. “Planking the Built Up Ship Model” by Jim Roberts is a big help, sold by Model Shipways. And I invested in a pair of proportional dividers - my Constitution Hull build log, link below shows how I used them. And plenty of info about this on MSW.
Thanks, have a good day,
-Rich
10 minutes ago, KurtH said:
This is my idea of the fairing of the hull
Hi Kurt, it looks like you’re on the right track. Looking forward to the plank installation.
-Rich
- KurtH, HardeeHarHar and Mr Whippy
- 2
- 1
Looking forward to your return. Get well soon!
- Keith Black, Glen McGuire, AJohnson and 2 others
- 5
Wandered into this discussion……
Circling back to the original post….the questions are relatively basic and reasonable.
If you have never owned a table saw, any table saw, respect the machine and the damage it can do to yourself and others.
Get basic instruction before using it. Plenty of instruction on Youtube and better yet, look for a local woodworking class.
Fundamentally if the blade is stoped midway through a cut, it is a dangerous situation, stop, STEP SIDEWAYS away from the saw and unplug it. Watch out the wood could eject back towards you with enough force to hurt you.
Understand that when cutting, one side of the piece, usually the waste, must be free to move away from the blade. That’s why NEVER use the Mitre Gauge and Fence at the same time. A bound piece of wood can easily eject from the machine, back towards you, and hurt you.
Lots of great suggestions on this thread. Understand the basics.
If you use the saw frequently, stay focused, accidents, and one will most likely happen to you, occur when we let our guard down. Always stand slightly off center, if the machine ejects a piece of wood you will not have time to get out of the way.
Again, respect the machine, it doesn’t have a conscious.
- Roger Pellett, Ryland Craze, mtaylor and 1 other
- 4
On 1/8/2024 at 5:00 PM, xodar461 said:
- how visible would nail holes be at that distance
Thanks for mentioning this, given how long it takes to build a ship model, one wonders how much time is taken up with “invisible” things such this, or other trivial details pursued for the sake of “realism”, especially by newcomers. Time which could be spent completing the project and gaining satisfaction from that.
- Old Collingwood, mtaylor, Egilman and 1 other
- 4
Enjoying this, thanks for posting.
- Jack12477, Old Collingwood, Canute and 3 others
- 6
A couple of thoughts, Have used AV paint, with a Paasche Talon, for the last few years and happy with the results. Have never tried adding gloss medium to paint, rather I use the Vallejo gloss resin. Have found the gloss finish can be built up with thin coats.
Tamiya Flat black may be worth a try.
Good luck with it…..
- Keith Black, Canute and mtaylor
- 3
Mucho important. The instructions probably do not emphasize that planks must be tapered. If needed look it up here, along with the concept of planking belts. An understanding of planking is probably the biggest thing one needs to learn when getting started. See my Constitution log, link below for pointers.
Have also found if you are on a certain step, it helps to look ahead in the instructions for addition images related to that step.
Good luck with your project!
Welcome to model ship world and good luck with your Victory!
- Keith Black, Malcolm Brown and mtaylor
- 3
May copper the hull, maybe, cost makes me think twice. Have Caldercraft Snake, came with the plates, probably build that first…..
Yes Avi, I can’t remember exactly how I prepped the metal before painting. Just tool a look for my painting notebook and can’t find it.
My rudder is static.
I did paint the hull with Tamiya Dark Copper acrylic, and my build log says the wood was prepped with Varethsne Ipswich pine stain. I like priming with stain, as it seals the wood fibers but doesn’t completely fill the grain. It takes acrylic well and leaves the wood grain, so the surface doesn’t appear plastic.
I’m thinking about picking up the Constitution this fall. Working on two other square rig hulls at the moment, the thought is masting and rigging all three simultaneously.
I’ve also been experimenting with Mr Metal primer. Brush applied as I don’t want to deal with the spray fumes. It takes acrylic well.
- GGibson, schooner and Bill Morrison
- 3
My two cents….have found CA on bullkheads does not immediately set, and have to do a second application after the first sort of dries, the first application is probably filling in the end grain. Also, at the bulkhead, CA will easily bond the long grain along the edge of the new plank to the edge of the previous plank.
My method is generous Titebond on the plank edge, CA on the bulkheads, install the plank, hold with fingers at the bulkeads, reapply CA if necessary when a plank does not hold at the bulkhead. Then clamp the installed plank along the edge up against the previous plank.
Have a rag ready to deal with the squeeze out or scrape after the Titebond sets.
The CA provides initial hold, the Titebond provides the ultimate strength.
It may be helpful to watch Youtube for cabinetmakers glueing up panels to learn about glue, and dealing with squeeze out.
My Constitution build log may be helpful.
Good luck.
Yes, seems like file down the “triangle” to a round pin, looks to me that the triangle was formed by a bit of flash from the casting process…..
- Avi and mort stoll
- 2
Welcome and greetings from Massachusetts, USA.
Good luck with your project.
Have fun!
- JeffT, mtaylor and Keith Black
- 3
Welcome to Model Ship World!!
- mtaylor and Peterairfix
- 1
- 1
Welcome and greetings from USA. Good luck with your work.
-Rich
- Keith Black, Shuriksun and mtaylor
- 3
Sort of circling back to the question.
I’ll seal with one of these products. Given the coarse grain, leaning towards the Gesso, thinned down and, shot with the Iwata RG-3 mini sprayer. It’s slightly gap filling as well.
This Hermione is an old AL kit about 10 or more years old….goal is to practice and improve techniques - get a visually convincing result - a model of the ship, rather than an exact reproduction.
Cheers
Beginner looking for advice on first kit
in New member Introductions
Posted · Edited by ERS Rich
Welcome.
Start with something small and inexpensive. Open boat, fishing boat, a single mast at the most. Something that can be quickly finished. Check the post about those who start big projects and never finish.
Good luck with it….
