Everything posted by Gregory
There was no mention of a kit or kit supplied sails. The technique in the link I provided uses SilkSpan.
Here is a nice topic that talks about making sails. No reason it shouldn't work well for any sail making project.
@schooner While that sounds like a great idea, I would hold off with any glue until you are sure the line in question will not need to be adjusted any further.
- 106 replies
- Grecian
- baltimore clipper
(and 4 more)
Here is a nice example of coil making from Glenn Barlow Make sure you click on the arrow in the upper right corner.
- 106 replies
- Grecian
- baltimore clipper
(and 4 more)
Do you think you could get a picture with your hand showing close to, or touching the boat? It would be great to get a better sense of perspective.
Focus Stacking
Gregory replied to Dennis P Finegan's topic in Photographing your work. How to do this.
@modeller_masa Looks like you are going to way too much trouble for me at this stage in life, but I defer to your expertise. Your methods produce some interesting results. I'll try to present some examples from my fairly low-end Panasonic DC-FZ80K. -
Focus Stacking
Glenn, there seems to be two sets of approach going on here. BrochBoating is referring to cameras that have a post editing feature built into the camera, where you get a stacked image saved in the camera. In my Panasonic it takes 40 images ( a video actually ) in one second, while advancing the focus from near to far. It then compiles them into a single image. The results are so-so in my opinion, but I may not be utilizing the feature to it's greatest advantage. I'm not sure what modeller_masa is on about. I think he is moving the subject and or the camera. That said, knowing your photography expertise, and having seen your work, I'm sure you are using a method that produces superior results. -
Focus Stacking
Some (?) Panasonic cameras have this feature also, and the merging takes place in the camera. Chances are, a higher end camera and post processing could result in a better result, but I have found it works pretty good at my level of expertise. -
I don't think that gap would exist on this type of ship. It would be similar to something like this on the Winchelsea. You might also look at how the rails are laid out on Winchelsea. Don't try to duplicate it. Just follow the general layout. There are a lot of different views in Chuck's Winchelsea log.
CNC Desktop Router Reviews
Gregory replied to tmj's topic in CAD and 3D Modelling/Drafting Plans with Software
Does Fusion 360 do all the toolpath plotting that those other programs do? I'll have to dig into it if it does.. No sense in having two tools for the same job.. -
Here's a nice demo with Vcarve -
FWIW I found a contemporary model in the Gallery that shows shrouds in pairs: There are several other models but I couldn't really tell. I can't tell on the Cheerful model, but Chuck chose to go with pairs, and I think he saw the model in person. Petersson. shows pairs. I trust Goodwin had good reason to go with single. P.S. Sails The cutter models I have seen with full sails looked somewhat clunky to me, and really detracted from the over-all look. In your case, I think they would really detract from all of your fine work.
- 562 replies
- vanguard models
- alert
Great info Allan What I find interesting is that the article says it is thousands of feet deep, yet in the picture we see a scuba diver and substantial ambient lighting. Obviously not a picture of the wreck. Of course the video depicts a very different environment. Why can't the media do better than that.
Dangerous? Any good saw is dangerous. How well does it work?
Just to add a little to the discussion. Here is a video that shows what a program like Meshcam could add to the CNC workflow, even with the lower end desktop machines. At $250 for the standard version, it's probably less than you would spend on decent carving bits. -
How has it performed under load? What kind of load?
If I may, and Chuck will correct me if I'm wrong, The bits closest to the fore mast are for handling rigging, the riding bits, just aft, are for handling the anchor cables.
- 1,784 replies
- winchelsea
- Syren Ship Model Company
@wefalck Excellent points, but when you address all the shortcomings of the KS230 , you now have an FET costing $300 .more. Forgive the cliche, but you can't have your cake and eat it too..
