Gregory
Everything posted by Gregory
  1. Without anything else to go on, you lost your symmetry somewhere.. So, you lost your mirror image.. This has happened to me before. Could be a flaw in the kit design.. Something to keep in mind next build.. I don't think it is a big detractor in an otherwise good build so far..
  2. Do you have a close-up of this area. I would like to see if I can sort out your mirroring problem..
  3. I have three different Dremel tools. This one is easy to hold and has very low torque.. It usually stops before doing damage.. Dremel 2050 With all Dremel's I would recommend the three jawed chuck.. Keyless Chuck
  4. It looks like a beveling tool rather than tapering, and would work with very small bites. I see the angle of the blade ( flat ) as a design shortcoming.
  5. You might try some Fiebing's leather dye. I have used their Burgundy for a reddish look on some boxwood blocks. It can be lightened by wiping quickly after application, with alcohol..
  6. According to the book " The Low Black Schooner " by John Rousmaniere, she was launched with copper..
  7. I thought it might mean something like that, but I see topics that are days and weeks old that haven't changed since my last visit..
  8. What does the red box with the word " New" mean? Just wondering, cause all forums show that for me..
  9. Just a little more detail to Ponder. You may run into a problem using the planking fan if you don't have wider planking stock than that provided in the kit. However you can work around this by using stealers at the stern. Marquardt's drawing shows at least two stealers and they can be used to accommodate the increased space compared to midships. I've highlighted the two stealers I see. The stealer makes two planks become three. At the other end, there is less space, and tapering will take care of that. However, you don't want the planks at the stem to be too narrow. I believe no more than half a full size plank. This can be mitigated with a ' drop ' plank. I don't know if Marquardt's drawings show any of those. Here is an example from Chuck's Winchelsea. Two planks become one. Please forgive me if I have made undue assumptions about your knowledge or lack thereof regarding stealers and drop planks. ( Some references refer to drop planks as stealers also. )
  10. Very nice work. I envy how you have been able to progress the way you have in a relatively short period of time..
  11. The head rails are so far above what has ever been part of a kit.. While I may not build the Winchelsea, it is like master ship modeling school to follow along and anticipate using your ideas in my future builds.
  12. No need to apologize.. There are more builds that never get finished compared to those that are.. Too bad we all cannot get paid to do this, and be able to pay someone else to do the chores that take us away from ship building.
  13. If I may, I seem to remember Chuck discussing this way back when. Not sure if it is Bulkhead 21, but here is the mention.
  14. The original posts seems to be talking about using it off the spool for rigging line. I would be curious to see examples in various sizes that have the appearance of rope.. The crochet thread I have seen wouldn't work for me..
  15. I would say a drawback, is that it doesn't have a rope-like appearance.
  16. Anything above 6mm would be a really good exercise in making one's own blocks.. If you have a small table saw, this method from Mondfeld would be a breeze..
  17. Here's my .02 on a block tumbler/buster. I made this little guy out of a little parts keeper with a screw on lid. Lined with 400 grit sandpaper. The disc moves freely up and down to make the parts bounce around and up and down. Here are the blocks that came with my Model Shipways 18th Century Longboat. 3 and 4 mm.. Note the red circle. Block is not useable. Blocks inside my tumbler. Cap on. I hold the container and run the mini Dremel at about 1-2K for a couple of minutes. Here is the result on the left. Some improvement, but nothing to compare with the good aftermarket blocks. Here is one of the 4mm stropped up. Back away ten feet and they are not bad at all.. Another problem with the kit blocks are the defects. Even if the sheave hole is in the right place, the groove needs to be deeper and at least as wide as the hole to look right. A lot of kits don't have enough to begin with, and the defective ones will have to be replaced. Before I go here is another use I found for my little tumbler. I cut out these wood beads with my laser. Here they are after tumbling. ( Ignore the one that didn't round up like it should have. It got trapped in the tumbler somewhere ) I was experimenting with making some parral beads.
  18. Cost might be one reason. A lot/some of kit supplied blocks can be made 100% better by rounding off the sharp edges. Some of them are hopeless when the sheave hole/s is not positioned in a a way for them to look remotely realistic. Have you seen any of the " block buster " tools. They can do quick work of rounding of the edges. I can show you some examples later. I think it is great for you to see this as a way to improve your build. I have seen some great workmanship really overshadowed by the poor quality blocks provided with a kit. Before you buy a set for a particular kit, don't rule out putting together your own set by purchasing from Syren. I have bought some of the blocks from Crafty Sailor with a slight cost advantage but the Syren blocks are better quality.
  19. Different strokes for different folks. I have occasion to use very small amounts, and will put a few drops in the target area and spread it with a brush. If I need more, the tops of the bottles screw off and I can pour what I need in a small dish or whatever.
  20. I have squeeze bottles with airtight caps and it stores just fine.. Bottles
