Gregory
Everything posted by Gregory
  1. John Fox III just posted this in another topic: I hadn't see this before, but it looks like it might be a great tool for tracing/designing parts for our lasers.. QCAD
  2. Great suggestion John! I have not heard of that before but it looks like a great 2D design/drawing program. It looks like a great resource for laser work. A robust tracing feature is at the heart of laser work. QCAD It is open source and free..
  3. Actually, with this hull form, the planking fans out at the stern for several planks.. This is a snip from the Cheerful plans drawn by Chuck.. Without wider planking stock this is not possible. Your plans may show what are called stealers that are used to fill in gaps that would develop if the uniform planking strips are used..
  4. The Mariner's Mirror is the international journal of the Society for Nautical Research.
  5. Something to keep in mind: I rarely include tabs on my parts to be cut after the laser is done. With no tabs, air assist can blow small parts around, to end up in the exhaust or in the path of the laser down range. Air assist is more useful for me on thicker stock, greater than 1/16..
  6. Before I had my 40w C02, I used a low power laser for scoring on anything thicker than 1/32, followed up with a scroll saw, which tended to follow the scoring.
  7. Have you settled on the Domanoff type machine? While I have seen that it can produce decent scale rope they can be problematic and limited when it comes to making a wide variety of rope. For different size rope, you would have to change the bobbins, and you are limited to four strands of any one size. Which means for a particular size rope made from a particular size thread, to get a larger rope, you would have to make 2 or more lines, then wind them onto bobbins, and proceed to make larger rope from them. With a rope walk like the Syren Rope Rocket, you don't have to worry about bobbins, you just use any length of thread, depending on the length of the line you want to make. You can also increase the size of the rope by adding more threads to the 4 whorls that make up the heart of the machine. It is not as compact as the Domanoff, but is much more versatile. Then there is the Frolic style, discussed here: , but requires a lot of DYI.. There are a lot of satisfied Rope Rocket users here at MSW.
  8. Fusion 360 is great for 2D and 3d.. Free for personal use..
  9. While we are at it: I just came across this in my browsing. An America model by Loyd McCaffery I can see myself using a similar design on a future project.. Simple but very elegant.
  10. Does Glowforge have air assist? It will reduce charring somewhat. I have found the amount of charring has the most to do with the type of wood and how seasoned it is.
  11. I think the pear would be great for a custom base/cradle/pedestals. You can get some good ideas from the models at NMM
  12. Embedded in the PDF are some links: Those links are broken. The domain is dead..
  13. Once again Chris, my comments were not questioning the quality of your work. I just found the MDF cradle to look rather incongruous in the context of the box art..
  14. The acetate is very nice. I was reluctant to make comments that sound critical, I just felt the MDF cradle really detracted from the otherwise beautiful model in the photographs..
  15. Chris, Any thoughts on coming up with display pedestals for your box art and promo pictures that are a little more in keeping with the quality of this beautiful piece of art? I realize display option details will be up to each builder, but I find the base as shown somewhat distracting from the rest of the fine workmanship.
  16. He had a build log for the ZHL Royal Caroline, a knock off of the Mantua/Panart kit, over at another forum.
  17. Bob Hunt was once a respected contributor to the ship modeling community, but he has chosen to go over to the dark side and support the theft of intellectual property.. https://modelshipworld.com/forum/149-our-stance-on-piracy-in-the-hobby/ I would not recommend supporting his business.. It's ironic in that he has often complained of people stealing his intellectual and real property..
  18. I have seen many contemporary models where the blocks are approaching black.. Then there are these, which I believe may be boxwood, as the color is a lot like very old boxwood carvings I have seen. I have seen similar blocks on other contemporary models. If I could source blocks like this, it would never occur to me to try to stain them, but as I said above, I really don't want to wait 200 years for the color to develop. The boxwood blocks I have acquired from Syren, the quality of which can't be matched from any other source, are too light for my taste. After reading the info in this discussion I have dyed some of my 'Chuck' blocks with some Fiebing's leather dye with results I like.
  19. Exactly.. Hard to wrap my head around this with no sail present.. It would be like adding reef points with no sails..
  20. Like you, I don't want to struggle with these numbers, but you might find this interesting.. With your Rope Rocket at 26 feet moving 3 feet with tensioning, that comes out to about 11.5%. I checked my rope walk, and with 55 inches of thread, it starts to lay up after the looper travels about 6.5 inches, or 11.8%..
  21. Like Chuck says, you can over think it, and gain absolutely nothing.. FWIW, with my set-up, when you have twisted the yarns enough, the rope starts to lay up.. This will vary with the type of thread.. Counting would be pointless.. I have been curious about what the RPM of my whorl gears are.. I might get around to checking it someday..
  22. The laying up is only a small fraction of the twisting of the strands, and it also depends on the length of the rope. The longer the rope, the more twists in the lay up. I have a more traditional rope walk with motor driven whorls and a looper that is driven by tension. I would guess the yarns/threads are twisted hundreds of times for each twist in the strands in the layed up rope.
  23. There are the trees, and there is the forest.. While the rigging in many ways defines these ships and their models, what the modeler hopes to achieve is worth consideration.. If you are going to model without sails, I feel a lot of the sail handling rigging would detract from what you have in the absence of sails..
