allanyed
Posts posted by allanyed
  1. 6 hours ago, DaveBaxt said:
    can I assume that the main preventer stay is on the top and connnects to the crows feet?
    In  photos of various ships on the RMG Collections site, both the fore preventer stay and main preventer stay are on top of the stays and attached to the masts  with attendant crows feet added to protect the stays from chafing from the sails.
    Two examples: https://www.rmg.co.uk/collections/objects/rmgc-object-66415  and
     https://www.rmg.co.uk/collections/objects/rmgc-object-66189     I would guess this is more likely than the fore mast stays being done differently than the main mast stays, but one never knows.
    Allan
  2. Welcome to MSW Doug,
    Are you speaking of European boxwood or castello boxwood, which is a wonderful wood with which to work? Take Bob's post seriously.  If you're going to be painting the hull, consider something like poplar or basswood.  I predominantly use castello boxwood for period ships that are not painted, but for schooners and such that will be painted, it is not necessary to go to the expense if you don't want to.
    As to figuring the amount of lumber, look at the amount of space from keel to the top of the futtocks at midships.   Multiply times the length, then double it to cover port and starboard.  Add another 20% for mistakes and waste if buying planks. In the long run  I agree with Bob in that it is better to buy billets of timber and cutting it to size.  The waste in sawdust is high but it is the same for anyone supplying finished planking so you will be paying for the wood plus the labor that goes into it.   It only takes a few models to get your money back on a good saw and thickness sander with the savings.  If you are not sure, calculate what you need then price billets versus pre-cut planking.   You can then figure the return on investment on the equipment.    Boxwood, be it European or castello, is getting more difficult to find.  When my stock runs out may be looking at Alaskan cedar billets as well.    BTW, Castello is not really a true boxwood but it really is super to work with.
    Allan
  3. 30 minutes ago, DonBMichigan said:
    Once the filling is done, it will be painted. The sawdust and PVA idea seems like a reasonable solution for this size gap. I can try it on some scrap wood and see how it goes.
    It actually might be easier to take out the piece and make a new one.  Your call of course, but just a thought.  Many of us like to use posterboard stock which is pretty stiff or even the cardboard on the back of a tablet to make a template then go from there.  Saves a lot of shaping and do-overs.
    Allan
  4. 1 hour ago, JoeMacD said:
    Jason thank you for posting your build of the Fair American, your build will be of great help to me when I begin building mine. I have 3 more boat models to do before I feel ready to tackle the Fair American.
    KEEP UP THE GREAT WORK!!
    Welcome to MSW Joe.   Please do post a little introduction about yourself in the new member forum.
    Again, welcome to MSW!!!
    Allan
  5. On 2/5/2023 at 10:06 PM, JLong said:
    black mast ''seat'' on the deck - what is that called
    It seems like you are referring to the wedges.  It is not a ring, but individual wedges that are inserted into the partners and will stand proud of the deck by several inches.  This ring of wedges is often covered with tarred canvas or other means.   Assuming you are not exposing any framing you can fake the top of the ring of covered wedges with a solid ring that would stick up above the deck about 0.08 inches more or less at your scale.
    Photos of the partners and a sketch of faked wedges follow that may make more sense than words.
    Allan
    Partners
    Wedges
  6. 1 hour ago, Snug Harbor Johnny said:
    Yet manufacturers are advised by their lawyers to be SUPER cautious and plaster warnings all over whatever product they are selling.
    CYA is rampant.  Look at pharma ads for examples.  It takes longer to rattle off the side effects than the benefit.
    Don,
    Regarding the subject at hand, how large are the gaps?   As mentioned above, sawdust and pva work well.   One quick way is to fill the gap (if small) with pva and hit it with an orbital mouse or similar.
    Sorry to bring this up, but as you are adding strakes, if there is a large gap, remove the plank before gluing it in place and re-shape it or replace it with a new one that has been properly pre-shaped as shown in the planking tutorial by David Antscherl in the Articles data base here at MSW (https://thenrg.org/resources/Documents/articles/APrimerOnPlanking.pdf) or shown in Chuck Passaro's four part video on how to pre-shape the planks with heated edge bending  Part one --> https://www.youtube.com/watch?v=KCWooJ1o3cM     Both methods yield properly planked hulls without gaps.
    Allan
  7. 5 hours ago, Peter6172 said:
    as the bevel on the forward face differs to that on the aft face so a lot of careful fitting up with files
    You are absolutely correct about this.  I do find that SHARP chisels make short work of the bevel on the futtocks and chocks compared to using files.  Of course, in the end, whatever works for you is the way to go.  There are 8 pages of text and drawings on making these joints that are EXTREMELY helpful in volume I of The Fully Framed Model by David Antscherl.
    Allan
  8. 5 hours ago, tj456 said:
    The ones on the Constitution in Boston are almost round and the size of a person's head
    Such a huge model is a marvel to me and such a great opportunity for detailing.  Congrats on taking up the challenge!
    Regarding your comment on the Constitution, normally it is a not usually a good idea to use a ship of one nation  from 1600 as prototypical to one from another nation from 1800 without researching each item first.   The differences are vast.  Just as the shape of the hull and the scantlings changed continually,  the rigging styles and items changed in size, shape and methods of belaying changed continually as well.  For example, we often we see modern ship models with belaying pins when there should be few or none at all for that type and era of ship.   If you have a chance to study David Lee's book on rigging, you will see that he shows many changes of rigging from 1625 to 1860 for British ships alone.   R.C. Anderson's on rigging book would also be useful as it is mainly for the 17th century.
    Regarding the shroud rigging, the lower deadeyes sat differently on the channels.  The support that ran from the deadeye down to the hull  was flat iron until about 1720 when two or three long links plus a strap came into use.  I do not recall ever seeing small linked chain like in the photo in post #7 above but perhaps someone else has.  Slots in the outer edges of the channels on British ships was not introduced until 1771.  Prior to that, there were square holes in the channels set back from the edge.   There are photos of models including those of the Mayflower and the Prince Royal (1610) at Royal Museum Greenwich Collections website that you might find helpful even though they are not contemporary built. https://www.rmg.co.uk/collections/objects
    Allan
  9. This thread got me doing some digging and there was reference to the fluyt like shape, but none claimed she was Dutch built.  Everything indicates she was English built but I thought looking depictions as well as Mayflower II,  the layouts might have some similarities to the fluyt plans.   As there is no contemporary information on the details being discussed the fluyt layout idea may be completely off base,........ or not. Sorry for causing any confusion. 😀
  10. On 2/2/2023 at 7:35 PM, GrandpaPhil said:
    I have a lot more fun with these than I do kits.
    Ain't that the truth!!!   I imagine more would get into it, but no doubt investment in space and tools can be a major issue.  Then again, for tools, add up the cost of 3 or 4 high quality kits and this would get a nice little shop going.
  11. Hi Scotty
    Glad to see you started the build log.   I really appreciate the story behind it and that you picked up the model to see it through to the end!
    For the future...... consider studying the hull planking tutorial in the articles data base by David Antscherl here at MSW and the four part YouTube videos on planking by Chuck Passaro.  You can find them it on-line and in an old post here at MSW https://modelshipworld.com/topic/22975-chuck-passaros-planking-videos-where-are-they/
    Rather than go into a long explanation, compare the results of two photos below.  In the lower pic, note how all planks are tapered to nearly half their widest point and end at the rabbet.   Again, this is something to consider for the future.   If your model  has two layers of planking, you may want to give it a try for the outer layer.   It takes most of us a bunch of do-overs but gets easier with experience.
    Allan
    2123345137_plankingatthebow3.jpg.aec417f1867ff3e25108f0cefd659469.jpg1104725512_Correctplanking.thumb.jpg.9b19e704b0cea9edd3032c0a4f889750.jpg
