Everything posted by Rustyj
Thanks Augie and Ben! Hi Mark, Yes toys I mean tools are great! I can see where a duplicator would be a god send! Edit...Though it's not a Sherline the Unimat link was very informative. Re-edit: Sherline version is great too. Re-re-edit: Vanda-lay link will save me a bunch of searching. Re-re-re edit: Do-over's. It seems everyday has to many do-overs! Thanks Joe. druxey, the design and execution is a bit over my head at this point but maybe in the future. Ok here is the result of the duplication. An acceptable job. Not perfect but they won't be right next to each other so all should be good.
- 421 replies
- granado
- bomb ketch
Hi Remco, As I follow along with all the rest I used to continuously think that you couldn't continue to stun me with your work. You have proven me wrong more times than I can count. Simply wonderful !
- 1,215 replies
- sloop
- kingfisher
Hi Mark, I guess I'm very productive then cause I've surely made a mess. No thumb twiddling going on here although work has gotten in the way a bit. As suggested I cut as deep as I could and the used a jewelers blade to finish the cut. Here is the first barrel painted and just set in the carriage. Now comes the fun part! Trying to duplicate a second barrel that comes close to the first.
- 421 replies
- granado
- bomb ketch
Very nice Mark. It's really rewarding to look back and see an improvement. I'm sure there will be many more in the future.
Thank you all for stopping by and the likes. Thanks Dubz. Mark I wouldn't want to be standing next to when it was fired let alone be down range when she let loose! Thanks Bob I am really happy with how she looks. Hi Grant. Sorry to disappoint but I played with one 1/2" dowel while waiting for the rod to arrive. Now I will make a confession. Machine equipment is no stranger to me. When I was a young'in I had training in machining engines. I could bore an engine block, hone a cylinder or machine a head to a couple of thousandths. I just never played with a lathe. Also it's been 37 plus years since I used any of that equipment so I wasn't sure if any feel was left. Now all you lathe users I have a bit of a bone to pick with you! No one ever mentioned how messy these things are. Now I'm no neat freak by any means but man it makes a mess. Here is a the cannon barrel turned to the correct taper . And here it is completed except I have now realized that I don't have a cut off tool! Oh goody something new to get! I can see where this can be very addictive.
- 421 replies
- granado
- bomb ketch
Thanks Ben and Floyd! Putting aside the temptation to stick every piece of wood, plastic and metal in the lathe and "turn it" I've placed the mortar in it's carriage. Here she is set to be stowed. And here it is set in firing position. Now I can move on and attempt to turn some cannon barrels!!!!!!!
- 421 replies
- granado
- bomb ketch
I had to threaten her a bit but in the end the funds were available and that’s what counts! LOL
- 421 replies
- granado
- bomb ketch
Thanks Michael. The rod is a dirty cream color. I painted it with with regular acrylic paint.
- 421 replies
- granado
- bomb ketch
Thank you all. Hi Bob, The lathe arrived last Wednesday and I played with some scrap wood until the rod arrived Friday afternoon. I sent several hours in the shop Saturday getting used to it. I must say the quality of the chucks, cutters and lathe make it much easier. Antony. Calipers, rulers pencils and any other items I think I may need are on hand. Unfortunately no digital readout on the slides. LOL Mark, beginners luck! Not wood or brass. It's 1 1/2" nylon rod. I was going to use that for practice but it worked so nice I kept it. The cannon barrels will be aluminum rod. The nylon rod is too flexible at 5/8" diameter. Thanks druxey and Augie, As I said beginners luck and good tools.
- 421 replies
- granado
- bomb ketch
Hi All, It's been a bit since my last post. Life, sub zero temperatures and feet of snow have all conspired to slow me down. Well the lathe has arrived and the learning curve is steep but the Sherline is a truly fine lathe. Thanks all for talking me into it. I tinkered around turning some scraps trying to figure out what I was doing and one mortar has been made. More coats of paint are needed and then it will be mounted to the carriage. The new carriages have also been made. Here is a comparison between the two. After that the fun continues when I have to try and figure out how to turn two cannon barrels. Well not only do I have to make two but for some reason they have to match. Hmmmmm...........
- 421 replies
- granado
- bomb ketch
US Brig Syren by knightyo
Rustyj replied to knightyo's topic in - Build logs for subjects built 1801 - 1850
Hi Alan, It' so great to have you back and your Syren log too! -
Very nice Bob and I'n sure there will be a mirror image of the starboard side! No pressure
- 1,477 replies
- essex
- model shipways
Very nice work Bob. Visible or not it sure looks good and we will always know it’s there.
- 1,477 replies
- essex
- model shipways
Hi Augie, I share your pain! The planking looks very good. It looks like you got the planks to lay nicely against the bulkheads and the run is very nice as well. Well done.
- 2,191 replies
- confederacy
- Model Shipways
Thank you all for stopping by for a look and all the likes! Grant, "Creative Accounting" here usually comes with free room and board for 5 to 10 years. Not to worry the lathe will be here eventually. I have received a notification from the author of the plans that there was a slight error. The cannon were drawn at the wrong size. The new sheet of plans was received and you can see the difference below. Good news is that I haven't made the barrels so nothing lost there and I will get some more practice making the carriages today. Also I have made the ladder but it is just set in place for now. I want to be able to remove it for when I rig the cannon.
- 421 replies
- granado
- bomb ketch
Hi Bob, If you hadn’t put the penny there you couldn’t tell they weren’t full size. Very nice!
- 1,477 replies
- essex
- model shipways
Hi Jan, I'll have to get a guard who will break fingers if anyone tries to open the covers! Grant I have to payeth the tax man first then we can order the lathe so sayeth the Admiral. Thank you Dirk. That mean a lot to me.
- 421 replies
- granado
- bomb ketch
The cleats on the rail that are really squarish looking were made just as the plans have them drawn. They are listed as a kevel cleat. I'm unsure if I will leave them looking new and unused or I will pop them off and give them some sanding. Thanks Christian. Playing with different woods was one of the most fun parts. Ok the hatch covers have been completed, sanded and one coat of wipe on poly applied. She's now ready for the open sea! That would be if there was cannon aboard.
- 421 replies
- granado
- bomb ketch
Hi Mark. Sorry to hear about the need to restart the Licorne. Reading your points of learning I see that I've suffered each and everyone of them but unlike you l haven't learned from them. Good luck with Licorne 2.0.
Joe, Colin and Antony, Thanks for the kind words! Mark That would be the start of a "really bad day". Here is the framing for the canopy. In the first picture you can see how it sets into the slots cut into the bulkhead.
- 421 replies
- granado
- bomb ketch
