Posts posted by chris watton
There really sin't a lot of difference, size wise, between the 24 and 32 pounder barrels, the latter being a tad 'fatter', and that's it, as they're the same length.
- hollowneck, Mr Whippy, jpalmer1970 and 1 other
- 4
Post is awful, your barrels were posted two days ago!
- mtaylor, Blue Ensign, hollowneck and 2 others
- 5
Oars would add a little more expense, as they would be a whole sheet of pear, and the pear sheet count is already very high for what I hope was a £240 kit. It is something I have thought of, however, so will see. I still may put it on hold anyway.
- mtaylor, Canute, thibaultron and 3 others
- 6
46 guns in total, 26 x 24 pounders, 2 x 12 pounder longs guns and 18 x 42 pounder carronades.
Classed as a 38 gun frigate at the time!
- jpalmer1970, mgatrost, AJohnson and 4 others
- 7
Even my wife loves the Trial Cutter. So much so that she said it can be displayed in the living room, and that;'s where it is.
Adder does have a couple of things going for it, it has a nice flat stern, so easy to plank there, and I have done my best to make adding the pre cut bulwarks around the bow as painless as possible - plus you get two full fat 24 pounders!
It seems these were not coppered straight away, but on average a year after launch, so I will do the bottom white.
- jpalmer1970, thibaultron, Vane and 10 others
- 8
- 3
- 2
2 minutes ago, Vane said:
I cant say its a beauty like the Speedy, but its good to have some more odd kits to build as well. I was always thinking you might do a Bomb vessel at some point, but this gun brig is definitely unique and it will be really interesting to see how it turns out when finished!
Funny you say that, I have considered more than once whilst developing this if it's worth continuing, and abandoning the development, as it's not exactly a looker...
- AJohnson, mtaylor, thibaultron and 4 others
- 7
9 minutes ago, druxey said:
Presumably for emergency use only if the wheel were disabled.
That is my thinking.
I am also thinking that perhaps the chasers had some kind of 'chock' along the bow that touched the front trucks/wheels.
- thibaultron, mtaylor, Oboship and 3 others
- 6
The upper tiller was an auxiliary, as there is another tiller arm that runs below the upper deck (which is operated with the ships wheel). So the upper tiller arm may not have been fitted in place if not required.
- mtaylor, thibaultron and Canute
- 3
When designing Revenge, I was in close contact with an expert of this period (I no longer have his details, as this was 15 years ago). Revenge was a very large vessel for her time, and I was told she would have had that upper lateen yard. This is also shown in many contemporary pictures, so I was advised to add it.
- AJohnson, thibaultron, druxey and 9 others
- 12
If I added an extra gun port aft of the main channels when every plan of the Acute Class (and there are a lot of them) does not show this, then it would no longer be an accurate (or as near as damn it) representation of an Acute Class gun brig, but fantasy. As Andy points out, it seems the fore deck was designed specifically for carriage guns, to minimise the recoil of the carriage. The drop down at the fore deck is significant.
Having said that about the plans, they did 'Troll' me in one area, the main channels and mast. On the main profile the main mast is a couple of feet forward of where it is indicated on the deck and cutaway profile plans. I always use the main profile for the hull and major fittings and the deck for the deck fittings positions) . However, when I fitted the fore most main channel to my model, which secured just one chainplate, I realised this single channel was too far forward (just aft of the side steps) of the main mast (how did I miss this when drawing the parts..). The deck and side cutaway profile chainplates/channels are not the same as the main lines plan. Easy enough fix, though, I just had to re do the aft most main channel to incorporate and extra chainplate slot.
The rudder appears to have two tillers, the lower one I assume was fitted with the tackle for the wheel, running under the upper deck, and the upper tiller having an auxiliary role
32 minutes ago, AlanDavison said:
A intriguing layout.
The 24 pounders look as though they would be difficult to control, especially as the breaching ropes either side of the gun would have to be of such different lengths. I can see the gun slewing all over the place when recoiling.
Might not the guns be mounted on rails or sledges to stop this?
I thought that, but I still feel this is too early for such carriages, and I suspect later gun brigs changed to sliding carriages as a result of the lessons learned from these 2nd generation vessels. Also, it looks like the second gun port from the front was for the long guns, so they would need to be moved.
ETA - Plus the fact that fore deck droops down means that it must have been designed that way specifically for carriage mounted guns, presumably to lessen the recoil.
- ccoyle, Edwardkenway, mtaylor and 7 others
- 10
I have been progressing with a small/medium kit before plunging into another long term development.
All designs/laser cut files are done, including three PE sheets, and now I am working on drawings. Once all drawings are complete, I shall start building the model for the manual, and may do a build log.
This is the gun brig Adder, of the Acute Class of 1797. My two main sources state it is a 14 gun brig, 12 x 18 pounder carronades and 2 x 24 pounders in the bow - but they may have been 12 gun brigs, as the only way to get the extra two carronades in position is to fill the stern chaser ports.
It is a great looking ship, and quite formidable in her time, as the French found out at the Battle of Quiberon Bay (1759).
Can't wait to see how much that figurehead will cost me....
- Malcolm Greig, Nirvana, hollowneck and 8 others
- 11
Mid-19th Century has little appeal for me, am more of a 17th and 18th Century aesthetic kind of guy!
- thibaultron, KentM, hollowneck and 8 others
- 11
4 hours ago, JacquesCousteau said:
Very cool list! Good to see the Imperieuse on there, the combination of a Spanish hull and British fittings and arrangements sounds like an interesting combination.
You mentioned that the list didn't include smaller kits. Any plans for more fishing vessels? The Nisha is on my wish list, although it will have to wait until after a move...
I think that 6 fishing boats is already enough for my range. If I did more, they would need to be very different and perhaps non UK. I would like to do a kit for under £100 at some point, though.
I am wondering if there's be any interest in the colonial merchantman Susan Constant?
20 minutes ago, Katsumoto said:
Royal George would be the “flagship” of your productline. I’ll be the first to buy. What a nice alternative to all the HMS Victory buildlogs that would be. It would be a huge ammount of work to design and produce I guess…
a nice list for sure you have!
Yes, Royal George was one of the first I chose when compiling my first 'To Do' list back in 2019, and has always been earmarked for the 'Flagship' of the range. But it will be a 2 year development, and I have to consider where and how to compromise so the end kit cost isn't too crazy. Pointless spending years on development and buying expensive materials if the end result is something people cannot afford....
HMS Indefatigable 1794 by Blue Ensign - FINISHED - Vanguard Models - 1:64 scale
It really is no big deal. I have many books that show the extra detail on the carriages, and many books that do not.
If you prefer plain wheels for the carriages, it is simply a case of a very light sanding to remove the light etched detail, or even simpler, just fix the wheels so the detail is on the inside.
Either way, the choice is there.
