Everything posted by Jim Lad
Your local brick yard has done you proud, Augie! John
- 2,191 replies
- confederacy
- Model Shipways
Bob, you certainly put your eight hours to good use. She's looking 'ichiban'. John
- 196 replies
- higaki kaisen
- woody joe
Congratulations, Ollie - very well done, mate! She looks absolutely first class. John
- 803 replies
- colonial cutter
- modellers shipyard
Bulkhead Fairing Questions
Jim Lad replied to Jon219's topic in Building, Framing, Planking and plating a ships hull and deck
If you're going to fully plank the hull then a shim, if needed, can be of virtually anything as it won't be seen. Whether or not a shim would need steaming or soaking would depend on the type of wood and thickness you need. Give it a go and see what happens. John -
Alister, Both these photos show ships in port. The following photo is of a ship at sea (Loch Tay 1869). John
- 803 replies
- colonial cutter
Sorry, Piet, but I don't see the fuse screwed into the nose of that shell for the deck gun! John
Ollie, I assume that the style of your coils is as per the kit instructions and indeed you will see a lot of models on the forum with coils made up exactly like that. You'll also see such coils on many modern replicas and restored ships, however the traditional method of make up coils was a simple coil dropped over the pin, as you will see in many contemporary photos of old sailing ships. The photos below date from the 1840's (first photo) and 1850's (second photo) and shown perhaps not in brilliant clarity, what I mean. John
- 803 replies
- colonial cutter
Ollie, your only problem now is that your next models have to be of a size to fit the other shelves. John
- 803 replies
- colonial cutter
Very nice, Augie. As for the stove base, simply order a couple of hundred very tiny bricks from your local brick yard! John
- 2,191 replies
- confederacy
- Model Shipways
Harriet McGregor by Boccherini
Jim Lad replied to Boccherini's topic in - Build logs for subjects built 1851 - 1900
Very nice indeed, mate! John -
When you have the time, Michael. We're a patient mob! John
- 2,207 replies
Ollie, The gaff angle still looks a little 'flat' for cutters in general, however the drawing and also the painting of her meeting the Makassar trepangers show it at exactly that angle, so leave it as is. That painting also shows her carrying a much larger ensign, however that may be artistic licence to show clearly that she was a British ship, although ships of the time tended to carry very large ensigns. As a personal choice I think I'd leave the ensign off unless you intend to rig her with sails as well. With bare rigging the ensign draws the eye away from the model. John
- 803 replies
- colonial cutter
Thanks again for your support, folks! John
- 745 replies
- francis pritt
- mission ship
I would say definitely a boom crutch. The fact that lines cross on the plan is not a definite indication that the crutch was outboard of the rail, as draughtsmen of the time often crossed lines which, by strict modern convention, shouldn't have been. This is clear from some of the lines shown on the detail of the plan of my 'Stag', below, showing the lower sheet block; rudder and tiller and deckhouse all in solid lines behind the bulwark (with the rudder and tiller also behind the deckhouse). The red arrows on the pictures below show the boom crutches. John Detail of Stag Contemporary model at NMM
That looks really nice, Grant. It's hard to tell from your photo, but just double check that the scale height is OK before you get much further along. John
