Everything posted by Jim Lad
Or the 0.5 you showed previously also looks good, Ollie - have you tried the small holes with the filler? John
- 803 replies
- colonial cutter
- modellers shipyard
That deck has come up really well, mate! John
- 803 replies
- colonial cutter
Looks like you're making good progress. John
- 113 replies
- bohuslän
- nordic class boats
Grant - nice to know that my secret's safe! Bob - if you're referring to the cant frame rabbets, they're measured from the last square frame and the lines marked with a squar held against the bottom of the keel. John
- 745 replies
- francis pritt
- mission ship
Russ - I'll just leave them as they are and watch myself when fitting the cants. Ron - those first few frames on the left are for right at the stern. John
- 745 replies
- francis pritt
- mission ship
Ah! The keel laid - and very nicely worked scarphs, too! John
- 346 replies
- terror
- polar exploration
Bugger!!! I'm such a genius of a model maker that I only need to mark one face of my frames on my plan; so naturally when I marked out the forward cant frames I measured from the wrong side of the frame and the rabbets I cut were all 1/8" too far aft, so I've had to re-do them and the rabbets are now twice as wide as they should be. The mistake will be hidden once the model is planked, and all I have to do is to make sure the cant frames are hard against the forward edge of the rabbets when I fit them, but it's still really annoying!!! Here are my extra wide cant frame rabbets (just don't tell anyone I'm such a muppet!) At least I've got some more frame blanks cut out. Very soon I'm going to have to make up a framing jig and start cutting out and fitting frames. The frame blanks that I've made so far. John
- 745 replies
- francis pritt
- mission ship
Just catching up, Remco. I've tucked that washer idea away for future use. John
- 1,215 replies
- sloop
- kingfisher
There are no rules laid down for the width or length of hull planks on British merchant ships - only the thickness and the spacing of the plank butts. In practice, a plank width averaging about 8 inches would be OK - this would be about 4mm at your scale. Remember that the planks on a ship are not parallel sided, but vary considerably with the shape of the hull. The widest planks will normally be found at the stern and the narrowest at the bow. With an average 4mm wide plank you should aim for no more than about 6mm for the widest planking and narrowing to no less than about 2mm. The average plank length would be no more than 25 to 30 feet in real practice, which would equate to roughly 150 to 180 mm on you model. When planking the 'shift of butts', you should try and plan for a minimum plank length of about 6 feet, or about 36mm on the model. John
That looks very impressive, Augie! It's good to see that you lot in the U.S. finally got around to having a new year - make it a good one.
- 2,191 replies
- confederacy
- Model Shipways
Esion, Most thread will stretch quite a bit, so it's a good idea to hang it up with weights on it for a while. This is especially important for shrouds and stays, which have some tension on them on the model. John
Sorry to hear about the chain plate, Pat. It's amazing just how much pressure a model's rigging can exert! John
- 517 replies
- Endeavour
- Artesania Latina
