dvm27
Everything posted by dvm27
  1. The officer gets a spoon and cup (great details by the way) but no light in the filling room? I think OSHA would level a fine for that.
  2. Scratch building is chock full of learning experiences. Hopefully you are using PVA glue which is easily debonded with isopropyl alcohol. May I suggest you prepare a test scarph joint with your tissue paper then debond it with PVA. I'm suggesting this because some papers I tried actually created a black mess during the debonding process and ruined the piece. Of course if you are planning to build a perfect, error free model this is not a concern but I buy my alcohol by the gallons. Also test the finish you propose to use to make sure it doesn't make the tissue paper bleed. Finally, I have found that using thicker tissue paper results in a weaker joint. Perforating the tissue paper prior to gluing the mating segment seems to help this. As well make sure to use treenails or brass fastening to reinforce these joints. You're off to a great start!
  3. What a pleasure it must be to be able to design and laser cut your own custom cabin partitions. You may not like kitchen sinking but I guarantee yours is the only model with the correct three nail pattern on the cabin planking. Would you like to borrow Gus, our office cat, to take care of your rat problem?
  4. I was fortunate enough to have visited the Museum just before it closed. I felt it was one of the best museums I have ever visited. Had the same thought about the Science Museum in England in the late 70's. At least I am fortunate to be so close to the Annapolis Museum where ship models take center stage thanks to a generous grant from an earlier class.
  5. I didn't actually notice that the swivel stocks were not on the original model Chuck. But the swivels ("ten 1/2 pounder swivel guns") are clearly noted in Winfield's British Warships in the Age of Sail 1714-1792 as specified for the Cruiser class. Of interest to us modelers is that only enough swivel guns to fit out one side was required. As they were so light they could be carried to the other side as needed.
  6. I use small pieces of index card held together with white glue. Just keep building them using small pieces of card. On some patterns like the mast step I'll have assembled 7 or 8 pieces of card. The unplanked side is a bit tricky. You can either extend the bulkhead all the way to the frame or stop where the planking would have been (leaving a gap). See Chuck's Speedwell below. As you'll find, it is much easier to leave a gap then achieve a perfect mating with the planking! https://modelshipworld.com/uploads/monthly_2024_03/forecastlebulkhead5.jpg.9ce18fb61c7a32f2595493a29fab12d3.jpg
  7. You should cut as close to the line as you are comfortable doing without cutting into the line. I used to leave about 1/16" using my scroll saw then sanded to the lines on my disk sander or oscillating spindle sander. After some practice I'm able to cut to within a whisker of the line and that is sufficient. Fairing after the hull is assembled will blend everything together. As well, I don't bevel the frames (except the hawse and cant frames) prior to installing as over-bevelling even one futtock will affect several frames before and after it.
  8. Lovely work. Anyone who completes one of those Marine Models (was it Bliss marine Co?) with their "pre-carved" hulls has my utmost respect. Give me plank on frame any day!
  9. One of my employees was awakened by the noise of the crash and actually witnessed the collapse. She lives less than a mile away and felt her house shake. I believe Andy is correct in that abutments would have deflected the ship and probably prevented this disaster. I believe they are discussing dredging the channel to make it more compatible with today's modern ships. The Port of Baltimore is seriously outdated and they will hopefully use this tragic opportunity to not only rebuild the bridge but better accommodate deep water ships.
  10. Those small details are lots of fun to add but you'll never see them on the final model, especially when encased. But some future observer will be delighted when they use their home Target brand home endoscope.
  11. I ordered from the website two weeks ago and the order was promptly dispatched. But the order was for accessories/sanding paper. With regards to the actual hard goods I believe the family is still working on a plan to maintain the business but this will take awhile.
  12. Good looking rope! Keep in mind that your model rope is cable laid (left twist) vs the actual cannon depicted which has right hand laid rope. Just a technical point but one that's fun to know because on every ship you now visit you'll be looking for the lay of the rope!
  13. Very innovative approach to the deadwood. I will follow with interest!
  14. What a wonderful teaching project Toni! I look forward to your takes on splices, rigging the blocks, etc.
  15. Why not really commit Chuck? Our Speedwell was based in part on the Royal Caroline design. I'm sure your daughter would apperciate these furnishings.
  16. Don't forget guys, you can always rig Speedwell as well. Full rigging instructions are included in volume 2 of the Speedwell book.
  17. Nice job on the cupola Chuck. I like the dulled copper version and it suits your approach well (making a model of the NMM model).
  18. Speedwell was designed for shore patrol so overnight accomodations were not usually a worry. Your "great cabin" would have been occupied by a Lieutenant (she didn't rate a Captain) and I'll be he would have been thrilled with your ecoutriments.
  19. That looks much better! I noted the cheeks looked funny but figured it was the camera angle. I was about to send you a PM but your friend beet me to it.
  20. I have dozens of Speedwell NMM photos but curiously, not one of this area. I'm posting a photo of my completed Q'deck so people can see what you're shooting for. It's not as elegant as yours but should give people an idea of how it all comes together.
  21. Very well thought out Chuck. This a very distinct feature on the model and you are off to a great start. Maybe show a photo of the contemporary model so folks can see what you're after?
  22. That is a dream workshop Gianpiero. I love the way your bench power tools slide out for easy access. And you have your very own museum to boot! Speaking for everyone else here - we're jealous!
  23. David Antscherl, in The Fully Framed Model, Volume 11, discusses this issue and concludes that either a grating or clerestory-style companionway would be appropriate for a 1779 vessel of 300 tons. On my Pegasus model I opted for the more visually interesting clerestory-style companion.
