Everything posted by dvm27
Spectacular, Keith! May your model remain dust free for eternity as that dark wood attracts dust like a magnet.
Well, when Chuck finishes the behemoth Speedwell he is currently working on he might very well consider working on such a project. I think it would be relatively easy to laser cut or CNC all the frames and build a model Reed (and McNarry) style. Of course with my crappy vision and decreasing manual dexterity executing the gilded carvings and fittings would be problematic but I would be happy with just a Navy Board version of one of his models. And, it would fit on a corner of my desk! Now let's all bombard Chuck with requests for this. He'll be delighted!
So your panels are not built up, correct? Just lines penciled in and carved to shape. Extraordinary work Siggi.
I usually use five minute epoxy when fastening brass to wood. Haven't had a problem with glue adherence but you do need to be neat and remove the excess before it sets. Perhaps with the blackened PE items you should run the bottom surface against some 180 sandpaper to remove the blackening and give it a bit of a tooth?
- 560 replies
- vanguard models
- alert
Yes, you can do that for .0006 cents cheaper on the Sherline mill.
That was some fun. Bet you can't wait to do the other side! Two tips I find useful: 1. When drawing bamboo, run it through the last hole 2-3 times. Only one pass causes compression and not necessarily cutting of all the bamboo fibers. 2. When final trimming of the plankshear use a sanding stick that is long enough to level both the port and starboard plankshears at the same time. This will help insure they are level athwartship.
- 1,074 replies
Very meticulous instructions Chuck. Great tip about reversing the cut due to grain. Something every woodworker eventually learns. I am frequently asked which power tool I use the most. Without a doubt it is the Byrnes disk sander. You can do those heels perfectly in ten seconds and creating bevels is a snap with just a little practice. I would encourage any builder who plans on making more than just a ship model or two to consider placing this on their holiday gift list.
Great tip Bob. I have found that a 50% white glue/PVA solution sometimes leaves a bit of a whitish crust on my darker rope. I'll certainly give the shellac a try.
EURYALUS 1803 by Peter6172 - 1:48
dvm27 replied to Peter6172's topic in - Build logs for subjects built 1801 - 1850
Well done on those hawse timbers. I found that cutting the air spaces on the mill was problematic due to the difficulties of holding the angled pieces securely in the mill vice. I actually mortised out these faces on the Byrnes saw. As the cut does not extend to the top or bottom of the hawse timber you always have two parallel faces contacting the table top. Then it's simply nibbling 1/2" from each or both faces of the timber. If doing it this way make sure to mark the top and bottom lines on the temporarily assembled timbers then disassemble and cut. -
Congrats on the purchase of the Sherline lathe, Mike. There are a million useful accessories but personally I find the 90 degrees angle plate and rotary table the most useful. You're going to have a lot of fun with it! The fore deadwood looks terrific. There's no magic formula for creating work like Mikes, Fred. It requires a dedication to perfection and to make each piece as perfect as possible. His tip about using light to see how tight the joints are is excellent. I don't have a window in my workshop so I use a light box. They're inexpensive (for example https://www.amazon.com/Drawing-Brightness-Adjustable-Animation-Sketching/dp/B07KLY84NB/ref=asc_df_B07KLY84NB/?tag=hyprod-20&linkCode=df0&hvadid=475857625827&hvpos=&hvnetw=g&hvrand=5262790266934135879&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9012258&hvtargid=pla-748436973284&psc=1). Where ever you see light between two mating surfaces is a low spot. Use pencil marks to delineate the contacting surfaces then reduce these with a sanding block. Just sand a little at a time and use the light box after each adjustment. The other tip I can offer is to do all work under magnification. If you're satisfied with the work at 2-3 times magnification you should have good results with the naked eye. Personally I do all my work with a 5x Optivisor.
You got it. I inherited a ton of tools from my father in law who was a machinist. This bevel edged blade was amongst them. I had no idea they were so much more expensive than a regular bladed edge but the tool is fantastic for transferring lines from table to model. I put no finish on my models. Personal preference.
Every update you post automatically merits a hit on the Wow button. I was wondering if the opaque whitish color of the lower hull suggests the white stuff paint used in this period or if the painters will revisit this area in the future
My only comment is that I despise you for making this look so easy! This section took me a month or so with lots of scrap pieces. I found the transition from the aft cant to the first full frame especially troublesome. I am compelled to point out, however, the horrific omission of a treenail on the fore face of cant number five. I'm sure everyone else is up in arms at this as well.
