Everything posted by dvm27
Great to have you back Remco. My holly from that era has also toned down to resemble the boxwood. I imagine at some point you will touch up those wales. I would encourage newcomers to this log to check out remco's earlier work. It's amongst the best you'll find on this forum.
- 1,214 replies
- sloop
- kingfisher
HM Cutter Cheerful 1806 by Erik W - 1:48 scale
dvm27 replied to Erik W's topic in - Build logs for subjects built 1801 - 1850
Lovely work Erik. Those tricky lower bibb details are especially well done -
They must think you are building an important model to be so accomodating. I agree that there must have been sheaves in those slots to redirect the rope or the chaffing would result in frequent replacement. I'm betting that the builder of this model had rigging fatigue at this point and probably just wanted to be finished. He never counted on a Johann to scrutinize is work centuries later!
Well Bill, if leaving them overlong "kind of makes you ill" then you really have no choice but to modify them (assuming your sources are correct). It should be fairly easy to scan the sails and reduce them in size proportionally. Or you could just leave them as is and noone else would be the wiser (except you). But if you plan on making more model ships you should get in the habit of correcting inaccuracies whenever possible. It's an important step in becoming a semi or scratch builder. Loved our annual visits to Baguio in the 1970's during university breaks!
Swan class 3D model in progress
dvm27 replied to dvm27's topic in CAD and 3D Modelling/Drafting Plans with Software
Thank you Denis for taking this amazing journey with us. You've managed to bring our 3D model to life and helped many Swan class modelers along the way. Best of luck on your future modeling.- 141 replies
- pof swan series
- swan
That is a gorgeous ship model, Ben. Did you give any thought to adding stump masts? I look forward to your new work of your Swan model in the upcoming year(s). Greg
- 399 replies
- winchelsea
- Syren Ship Model Company
My advice would be to remove the bulk of the material prior to mounting on the keel. But, as Druxey points out, you need to be super careful not to exceed the frame margins fore or aft. Thus, I leave 1/16" material proud of the bevel lines. Doing this on the table sander is perhaps not ideal. The reason is that the bevel is constantly changing from extreme to narrow as you go up the frame. If you're going to build many models you may wish to invest in an oscillating spindle sander, It is fantastic for outside and inside curves and for bevel work as well. You control the angle of the bevel, not the machine. with a little practice you can bevel very precisely and in very tight areas. As an alternate, consider using a Dremel rotary tool with their different sanding sleaves. You can remove the bulk with their 80 grit and progress to 180 as you approach the bevel lines.
- 92 replies
I believe that is a very workable solution Johann. It is, of course, preferable to use the contemporary model as a primary source but I think sometimes we take these models as gospel. It is possible that the original builder made errors, took time saving shortcuts or omitted details because of any reason you could think of that is just as relevant to us modern builders. Perhaps, being near the end of the rigging process he just wanted to be done and chose this quick and easy method to end the line. I do know that, in 150 years, someone making a model of your model will have the most complete and well researched Creole model ever built.
Brilliant work, Chuck! I love how you "blacked out" the underside of the deck. Your New Jersey club is one of the luckiest around with you as a Captain. What scale is the sectional model? The faux metal work looks like the real deal. I'm betting this sectional model will show up in your store at some point as who wouldn't want to make one as a fun side product?
Kit review 1:10 Military Turbofan engine - TECHING (build review)
dvm27 replied to James H's topic in Non ship-related reviews
That is one cool model. I'm thinking of building one for my Grandson. He has just started on a path for commercial aviation and he would go crazy for this. Unfortunately, it may have the opposite effect on his parents! -
I've spent a fair amount of time ripping out stuff and redoing problem area(s). I promise you that once she's in a case you will barely notice her. So what's another month or so in the construction time? The hardest decision is whether or not to redo something and once that decision is made progress is fast.
How will laser cutters compliment our hobby tomorrow?
dvm27 replied to EspenT's topic in 3D-Printing and Laser-Cutting.
Yes, I enjoy working with wood as well but when it comes to making hundreds of blocks, belaying pins, cleats, etc. I think 3D printing is the way to go. Chucks 3D fittings look exactly like box or pearwood so I'm happy to use them. The limiting factor is, of course, preparation of the stl or other cutting files required to 3D print them. I feel that's a level of computer expertise beyond my aging skillset. -
They sell mini crock pots on Walmart. Plug it in and wait until hot and do as Tony says. You can unplug the crock pot when finished and keep the solution covered. It lasts for months.
- 257 replies
- pegasus
- Swan-class
I use a 1:5 dilution. None of my blackened fittings have faded over time and I don't get the flaking and uneven coatings I used to get when I used stronger solutions. I can't stress enough that the fitting needs to be spotlessly clean and free from oils so I wear disposable gloves. I do suspect that some of the results depend on the specific type of brass you are using. Being an alloy, perhaps the proportions of copper and zinc vary based on the type of brass. I do note that since I have been using Sparex before etching my results are much more consistent. I've never used Pewter black for brass Kenny. I've always used brass black. Not sure what the difference is though.
- 257 replies
- pegasus
- Swan-class
Here is a video link to Kudin's method of turning in the deadeyes. It takes some practice but worked well for me on my last project. Try to master the seizings as you'll need them for many aspects of rigging. https://www.youtube.com/watch?v=NzVOOi3Eo5U
perhaps you can post an actual rendering every once and awhile so that the technically challenged amongst us can fully appreciate the results of your work.- 141 replies
- pof swan series
- swan
Welcome back Denis! I doubt that most of our followers are aware that you have further developed the 3D model with sails and ropes to accommodate gamers (where the big bucks are). I'm sure that 99.9% of them will not notice that your rope is laid left-handed vs the traditional right-handed method so I won't point that out 😉. Still, if you are able to reverse the lay with the simple click of a button I know you will do it as you are OCD when it comes to details.- 141 replies
- pof swan series
- swan
Try contacting Ben at the Midwest Modelers Shop. His e-mail address is TheMidwestModelShop@gmail.com. He has built a couple of Titanic models for clients and has many subscribers so he may be able to find you a model. You may also wish to check out Fine Art Models https://fineartmodels.com/titanic/. They have built the finest Titanic model at 1:48 but also sold 1:192 models.
You should put a small ruler in your photos for reference. It's hard to believe the complexity of your work at this scale. I wish your log had an index because it should become the new bible of ship model rigging. Your split thimbles look perfect. Can you point me to the section where you manufactured these?
