Everything posted by Mike Y
what is the ideal modelling table?
Mike Y replied to AON's topic in Modeling tools and Workshop Equipment
Hm.. Modelling the tables to model the ships could be as interesting as modelling the ships themselves! Currently designing the work bench for a living room builders. It should be nice (so there would be no need to hide it somewhere), not big (only most used tools in it, other goes to the storage shelf), but also it should have a shape allowing an easy dust cleaning. And safe from kids. -
Just use some reversable glue, so you can add alcohol or water and remove incorrect plank. It is tricky on such open hull, and do not count on sanding to make it smooth - planks are too thin. But just take it slowlt, you will make it!
- 132 replies
- 18th century longboat
- model shipways
Wow! How do you make such a crisp edge? What is the trick for such a finishing? Could you please share some of your techologies? I guess it is hand plane and chisels, and then sanding with a sandpaper wrapped around a block, to avoid smoothing the edges? Or there is something else? Or you skip the sanding completely, and use only chisels and magic? I understand that question sounds strange, "please explain your mastership in a few words", but really hope to learn proper techiques! Spent evening re-reading the whole log again, fantastic level! Such a pleasure to see! And how do you finish the wood, for example, frames and beams? On a photos I even don't see the poly, or it is a very thin layer?
- 1,192 replies
- sloop
- kingfisher
Looks good! Doublecheck that all frames are properly aligned, so there would be no "holes" and "bulges" because some frame is a bit non-aligned. I did that mistake on my pinnace, it's unfixable on later phases. Take a plank and see how it goes, hull must be perfectly symmetric. Small hint - it would be easier to make a planking if you glue all frames together with a few strips on top: And then glue some scrap wood in the center of the hull, to just clamp it into a table vice: It is much easier to plank when hull is firmly fixed, you don't need to hold it, and frames are not wiggling (because they are glued together). All that strips will go away when you remove the frame centers, so they do not affect any end result.
- 132 replies
- model shipways
You can fair them after installation on a keel, to get a proper shape. However, do it carefully to avoid breaking the frames. Knife or some light touch of a dremel, or whatever tool you prefer. But only up/down sanding, do not sand back and forth, otherwise a frame can break.
- 132 replies
- model shipways
Not sure if there is any, it's quite straightforward: take a plank, put it on a future frames like you are doing the planking, and make sure that all bulkheads have a full contact with the plank, not only in a small point.
- 132 replies
- model shipways
That wood is quite thick, coarse sandpaper will not sand it away. Also, 240 grit is just to remove the char, then you use higher grits (320 -> 600 -> 1200) to make it smooth and shiny At least, that worked perfectly on pinnace, sister kit for longboat. Will try it on longboat itself in a few weeks, but as far as I remember, the wood is the same, and they are produced on same laser cutter.
- 335 replies
- Finished
Not yet, but she is close And I also need to build a display case, already bought some plexiglass for it.
- 137 replies
- finished
- model shipways
Slowly finishing interior details. Mounted splash protectors, rings, some decorative things near a few twarts, small ladder for a captain. Some things are done not according to the manual (different position on splash protectors, etc). So far I like the modified parts compared to pictures in manual Rudder tiller was nice, but too small for that scale. Made another one, bigger. Maybe it is not in scale, but now it will not break if a fly poops on it Connection between carved part and turned part is enforced with a small brass rod. It is a pity that connection is visible, will try better next time: And that is a moulded boxwood strip instead of friesers (that look like an overdecoration imho). I understand that are a part of contemporary model, plus the whole point of captain pinnace is to flash, so it was overdecorated. But I like a more laconic design, so replaced most flashy parts with less flashy, but elegant:
- 137 replies
- finished
- model shipways
I sanded it away with 240 grit easilly, does it work for you? Congratulations, following the build with interest! I will also start my boxwood longboat build in a month or so
- 335 replies
- Finished
It is the first model where even the dust looks authentic! Exceptional!
- 226 replies
- cumberland
- 74 gun
Sanding the inside of boat hulls.
Mike Y replied to Modeler12's topic in Modeling tools and Workshop Equipment
The sanding drums come in different grits, so you can use the fine one. Sorry, that's the only picture I managed to google, with a coarse grit But yes, they are to remove most of the material, while the final polish is always manual. -
Wow! What kind of a glue do you use? And how do you prevent the hull from warping when wet? Planks will expand, and then leave the gaps when dried. Or there is a trick to prevent that? Looking forward to see the video of first voyage, and more detailed photos! Incredibly interesting project!
Just out of curiosity - if you apply the poly to frames now, how can you sand the internal side of the hull later? Or you will skip that step?
- 372 replies
Killed around 10hr on inboard panels, and not sure if they make things nicer or not. Probably, I should have definitely skipped the panels on the rear part of the ship. Very hard to get a proper precision with such small things. Even if they are nice on micro scale, under magnifier, on a larger scale panels are not perfectly aligned together: Also finished a rudder tiller. It have two pieces - carved part and turned part glued together. I am very happy with boxwood, so strong wood and so easy to carve! On that photo, one cell is 5mm (1/6 inches): Now will try to cover all that small particles with wipe-on poly and install to the model.
- 137 replies
- finished
- model shipways
Grant, Ian, oh yes! It is a new amazing skill, I never thought that wood could be that solid.
- 137 replies
- finished
- model shipways
Started interior panels. Feeling like a jewlery master, they are sooooo small! I cant make it without a magnifying glass, any attempt to photo them without it fails. Boxwood behaves perfectly, no splitting, no cracking, and tweezers do not leave any traces on it! That is how one panel looks through a magnifying glass: 2.5 hours later, and I just installed bottom parts for all panels on one side of the boat... Looking forward for a weird weekend I wonder how I was supposed to make them with a basswood from the kit? Tried it, just for fun, it is close to impossible, the wood grains are too big.
- 137 replies
- finished
- model shipways
Received a boxwood upgrade package from HobbyMill! Technically speaking, it is for longboat (next build), but it has three big sheets of different thickness, and I milled a few strips from 1/32 sheet to make a nice decorations for my pinnace. Newly purchased table saw from Proxxon helped with it, surprisingly decent accuracy if push the sheet accurately without twisting. It is far from being a precise machinery, but for $120 it is more then good! I tried to make a moulded strips for interior panels, but can't get an accurate edge on basswood strips. You can see it on thwarts, mould looks crappy. Totally different story with boxwood! It is my first experience with it, and I am totally happy! Nice color, very solid, holds a nice edge, now I see why it is so popular! Sorry for a bad photo, that is the best I can get with an iphone camera... Let's see how the result will look like! Now I can't whine about bad wood anymore
- 137 replies
- finished
- model shipways
