Everything posted by augie
It's always good to step back once in a while and enjoy what you've done. Very nice......and really small!
Don't feel bad Robbyn. I do that stuff routinely. It's called missing the tree for the forest
- 234 replies
- 18th century longboat
- model shipways
Very nice Kevin and the daylight is a big plus. Now enough 1:1 work, let's see some heavy metal @ 1:200
No.....the 3rd bedroom is the shipyard With that kind of ceiling height he can easily build a 1:24 HMS Victory !!!!!
- 1,873 replies
- occre
- san ildefonso
Really coming along Andy. Time spent doing something right the first time is time well spent. Whether it can be seen or not. Time spent re-doing something is not nearly as productive. You made me think for a second ...... I've spent 2 hard months framing my Confederacy and, in the end, not even one member of the frame will be visible !! That's modeling
- 188 replies
- constitution
- mamoli
OK, I couldn't stay out of the shop so here's a small update The hances and midship rails have been completed. These will act as a substrate for the hull planking to come. Fairing the hances to the hull shape was challenging (I won't mention the pencil sander again) but test planks seem to lie nicely at this point: Next up will be laying out the sweep ports. There is a half cord of lumber, 3/8" square, that needs to be fitted between the bulkheads and faired prior to laying these out. Keep a weather eye out for a cloud of sawdust over the Rockies
- 2,191 replies
- confederacy
- Model Shipways
The new project revealed. She has a certain no-nonsense, workmanlike quality about her that I find most admirable. I'm a bit startled by the draft ..... but the old designers had their reasons. I'm certain you'll do her proud, John. Particularly at 1:48. Allow me to pull up a chair. Bon Voyage !!
- 745 replies
- francis pritt
- mission ship
Treenail detail option?
augie replied to S.Coleman's topic in Building, Framing, Planking and plating a ships hull and deck
The technique I've used is based on Chucks. Basically, you select a pin vise drill size that suits your scale and eye. It's important to try some samples on a scrap prototype deck before you commit. On a 1:64, about a #70 size hole looks good to me for treenails. I have used a #65 for keel bolts if you require those. Line up your holes with a piece of tape to keep them straight. Be careful with the spacing. Drill the holes and then GENTLY clean/round them out with an awl, needle or other smooth, sharp object. Do NOT makes the holes any bigger. The choose your filler and determine the color beforehand. I use a tinted filler called 'Hobbylite' which is a light wood color. Force it into the drilled holes, wipe it off smooth before it dries and then let it set. A light sanding with something like 320 grit can be done when it's set. Then finish it along with the deck itself. I like them barely visible so that you are aware they are there yet not overpowering. I can not emphasize enough making the trial runs off the ship until you are satisfied. -
OK, that's it. I'm closing down the shipyard. Rumours of planking, speculation on next ship, specters of the dark side. This place is getting like Saturday Nite Live . In truth, all that's happened is that I've managed to keep the universally feared "Oh s_ _ t_" to one every other day rather than 2 per hour. Be back when the snow flies (Monday)
- 2,191 replies
- confederacy
- Model Shipways
Call 1-800-Hot-Water. The shipyard will not tolerate delays
- 1,755 replies
- constitution
- constructo
I'm with Larry, Impressive is certainly the word. Hope you don't intend to use her as a door stop
- 1,873 replies
- occre
- san ildefonso
Thanks everyone! A few leagues to travel before planking becomes the order of the day. Lots of timber to still lay in. Then we need to pick a proper red for the bulwarks. All fun stuff . MARK--- no, no elk hunting down here at what we call 'sea level' (5230 feet). Do have some fishing to do this next week before winter closes in. And you think retirement is gonna be easy. I'm waiting to see what happens to you in 13 days!
- 2,191 replies
- confederacy
- Model Shipways
Gun port framing has been completed : I used a spacer this time around to insure that the ports are all the same width and set at the correct angle. Everything was faired into the hull . Sanded and filed the inside of each port so they are basically ready for painting in a few days. Next up is a rail amidships and some hances.
- 2,191 replies
- confederacy
- Model Shipways
Nice find ---- and congrats on the negotiation skills
- 421 replies
- granado
- bomb ketch
Are we encountering a bout of mid-build doldrums? STOP COUNTING I think we all hit this once in a while. The final goal is fixed in your mind. Keep the steps reasonable and defined and, one by one, they get completed. I know you know this! Enjoy yourself. Winter is coming
Both classics in their own right. Thanks for the smile Larry. Now we can wait for the other 'Two outta Three".
- 1,873 replies
- occre
- san ildefonso
