druxey
Everything posted by druxey
  1. It has been published for over a century and is a quarterly, peer reviewed, research journal. Fascinating articles on all eras, book reviews, etc.
  2. Perhaps: "The White Hound needs 12 (guns) of 4 or 5 pound caliber..."
  3. I agree with Waldemar: the (half) plan view is superimposed on the profile drawing!
  4. Well done! The forward edge of the knee is rounded off, so when at anchor the cable doesn't get damaged by rubbing against any sharp corners. See Greg's photos.
  5. It's all part of our learning curve, bitao. My first fully framed model had parts re-built four times!
  6. Roger: your draught is interesting. What reference do you have for the recurve of the upper stem?
  7. Certainly the plan under the model helps keep the frames to the correct spread or width.
  8. Coming along well, Stuglo! Those 'hidden' details are intriguing to make and install. They certainly give one a good idea of how crowded everything was in these small ships.
  9. I use Lepage's wood filler, natural, in the tube. Works well; dries fairly quickly and sands well, if a little dusty. Have the vacuum handy!
  10. The plank ends need to be sanded completely flush to the transoms. If there is any small gap left, then use filler. Otherwise you'll be making a lot of dust if you fill first!
  11. Thanks, Wayne! Those two PDF's are very interesting - at least, to me!
  12. The strand issue could be minimized by paint, perhaps, smeared into the conts of the line?
  13. I agree that, at your scale, fiber rather than metal for rigging would be far easier to work and look just fine.
  14. Sometimes the aft upper end of a framed hull like that can distort before being tied together with all the other framing, beams and knees. My first model had that issue as the upper works were only in frame for some years. I actually needed to bury tie rods under the quarter deck beams to pull the topsides into spec'd width!
  15. Kevin: The rule of thumb is one riser depth plus one tread width totals approximately 18". So a six inch rise, 12" tread, etc. (Sorry, you metric folk!) This applies to flights of stairs, within certain parameters. Ladders, being steeper, are another matter. Around 10" spacing seems average.
  16. I agree with Allan; about 10", but slight variations depending on total rise without any uneven step in the run!
  17. A very respectable result for a first outing. That is not a simple model for an absolute beginner. Well done for persisting, Bill!
