Everything posted by druxey
I build guitars, so why not model ships?
druxey replied to cooltouch's topic in New member Introductions
Welcome, cooltouch. As a luthier, you will already have a wide range of skills and knowledge that translate into ship modelling. As an entry point, avoid cheap and nasty (often knock-off) imports, vintage kits or too-good-to-be-true offers. Also avoid over-elaborate subjects. I do not recommend a 100 gun ship for starters! Here are two suggestions (you will doubtless get a zillion more!): Syren Ship Model Company's Royal Barge Model Shipway's Bounty's launch The first is not cheap, but it is has high quality materials. -
I love the observation and rendering of details! Try painting Silkspan and draping it for a coat or slicker. It will drape better at small scale than material.
Gary: The stool sits at the angle of the sheer. The floor of the quarter gallery is at the same angle and height as the sheer and round up of the deck inboard. Bend your mind around that! Fitting the floor to the inside of the gallery at the correct angles will amuse you for some time....
Lovely progress, Rob. I have to keep reminding myself of the small scale you are working at.
- 1,208 replies
- great republic
- clipper
Help evaluating old model of screw steamer USS BROOKLYN
druxey replied to Cono's topic in New member Introductions
And the flag looks way too recent as well! -
glues decking sheets
druxey replied to Kurt Johnson's topic in Building, Framing, Planking and plating a ships hull and deck
To prevent curling due to moisture in white or yellow glue, dampen down the upper side of the sheet to equalize the moisture content both on sides of it. -
I concur with Bob's comments and assessment. It is an interesting historic artefact. -
Richard: your app looks like a great one. If available, I imagine a lot of folk would use it!
No, I wasn't messing with you, Gregory - it's the rope manufacturers that supply line in metric that are!
Also, irritatingly, 0.6mm diameter is not helpful when one is working in a feet and inches scale! On needs to make a metric-to-duodecimal conversion, then factor in the proportion (e.g. 1:24 scale). Aaargh!
On the other hand, rope is usually measured by circumference. A fair approximation is to wrap 3, 6 or 9 turns and measure across, then divide this measurement by 3 as appropriate. (Rope circumference to diameter is a factor of 3.1416.)
Newbie paint questions...
druxey replied to CPDDET's topic in Painting, finishing and weathering products and techniques
As Bob says, first test any new paint or combination out on a surface other than your model! -
Is it possible to use fine wire as a support armature for modelling the Fimo/Sculpey on?
I'm sorry to read of all the stress that you and your family have been through. I'm glad that things are improving. Another small project might be one of Chuck Passaro's Syren Ship Model Company's open boats. The Medway's longboat has a modest amount of rigging for you to get your teeth into.
