Everything posted by druxey
One can occasionally find wheel chucks on eBay under 'watchmakers lathe'. I was able to get two sets, large and small, at different times. However, often the ones you see are either rusted or beaten up.
I thought that we were referring to figure 19 in Falconer, not 18, Mark! In any case, it appears that the breech rope has been shortened in figure 19 in order to secure the gun against the bulwark - it's not in 'action' position and cannot be run in. Presumably one end of the breeching at the bulwark is loosened from the ringbolt, pulled taut and re-secured.
This is my last shot (pun intended) on this topic! A cut splice in the breeching would allow for some lateral movement in a gun trained around and firing, without slewing it back on recoil. The later pattern of gun with a cascabel ring would allow the same degree of freedom, but without the complication of making a cut splice.
Ah, then you'll appreciate a neat suture line even more, Tony.
- 124 replies
- longboat
- Chaloupe Armee En Guerre
Congratulations, Gerald. Exquisite work! The working pump is a miniature masterpiece.
- 281 replies
- falls of clyde
- tanker
Very nicely executed, Tony. Best wishes for a successful outcome for you next week! Show your surgeon these photos and tell him/her that you expect a similar level of accuracy and neatness.
- 124 replies
- longboat
Preprinted lines
druxey replied to achuck49's topic in Building, Framing, Planking and plating a ships hull and deck
Tracing paper and pencil, then use graphite paper to transfer down the lines on the blank side. Use tape to make sure the traced pattern does not slip! Graphite paper should be available at your local Michael's or art store. -
Nicely executed, Ben. I bet when you actually got to doing it, it wasn't as bad as you expected.
- 64 replies
- medway longboat
- Syren Ship Model Company
