Everything posted by druxey
Somehow I missed your June 30 post, Eberhard. I had assumed the break was for reasons of business, not a nasty virus. I'm glad to read that you have recovered and can continue your beautiful miniature work. Gute gesundheit!
H.M.S. Atalanta - Drafting my own plans
druxey replied to Ben752's topic in CAD and 3D Modelling/Drafting Plans with Software
Sometimes the stem curve is made of two different radii, which complicates things! If you are lucky, you can see the prick-mark left by the draftsman's compass when he drew the arcs for the stem and rabbet. Take a line vertically up from the point where the straight part of the rabbet begins to curve and look carefully. The other method is to make an arc of the specified radius (13' 7 1/2" in your example) and put the center at different points along the curve and strike several arcs. The intersection of those arcs will locate the center of the curve. -
If it's any help, try to control your breathing while painting small detail. That will steady your hands. Nevertheless, your painted decoration looks beautiful.
Your work at such small scale is very impressive, Javier!
- 11 replies
Gosh, Michael; we may have stood side by side back then without knowing it! I did exactly the same thing. The treatment of windows - more properly termed lights - was a convention seen on many display models from about 1880 to 1950.
- 749 replies
- albertic
- ocean liner
Beautifully realized, Doris. The earlier the subject, the less information we have. Have you looked at photographs of Vasa's head to see the seats of ease on that ship? Although Swedish, it is almost contemporary to Royal Katherine. That may give you a guide. If I may comment, the Vale painting seems to have the figure and tip of the knee of the head slightly more angled up than in the Sheldon model. You might want to check that.
- 1,035 replies
- royal katherine
- ship of the line
I hate making tree-nails
druxey replied to barkeater's topic in Building, Framing, Planking and plating a ships hull and deck
Hah! You had us. -
HMCSS Victoria 1855 by BANYAN - 1:72
druxey replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Ah! That is another level of difficulty, then. Either decal or photoetch seem to be the only realistic possibilities for those details.- 1,005 replies
- gun dispatch vessel
- victoria
"The stern post to be of good wound? oak tim of the best kind free from defects. sq. at head 12 1/2 (which is t run up to bolt in the Lua? deck beam)" This should probably read: "The stern post to be of good sound oak timber of the best kind free from defects." The contract and 'as built' plans trump any other reference! There were variances with any Swan class ship. Your filling transoms, provided they fair properly (check using both buttock lines and proof diagonals) will be confirmed correct. The head of the stern post in Atalanta appears to be at the level of the top of the wing transom (ZAZ 4485), as there is no indication of a gudgeon strap on the rudder any higher. It is hard to tell, because of other overlaid detail. -
For the brass wheel rim at that scale, would a ring of thin brass wire carefully flattened out do the trick?- 1,005 replies
- victoria
Bamboo through a Byrnes' drawplate (feed in from the small hole side!) makes the job very quick and pleasant. -
Looking better and better! I do spot a minute difference with your vent, but I shan't tell anyone. It's still far nicer than any effort of mine!
- 749 replies
- albertic
- ocean liner
Beautifully fitted joints!
New member with a question about shipping models
druxey replied to CJ2S's topic in New member Introductions
Unless you cannot move them carefully yourself, as these models have great family sentimental value, you should consider a professional company that specializes in moving art and museum objects. Call your local art gallery or museum to find out who they use. It will not be cheap, but they will move the models safely and fully insured. -
Best wishes, John, while you are on the rough road. Also condolences to Pam and yourself on your recent loss.
