Everything posted by druxey
Usually the sides of the ports were vertical, as you have in 'C'. However, depending on the ship, if there were drag (floating lower at the stern than bow) the ports would appear as if 'leaning' backwards. The frames were normally set upright on the keel, the sides of the frames forming the sides of the ports.
How to deal with badly drawn plans?
druxey replied to Redshirt's topic in CAD and 3D Modelling/Drafting Plans with Software
I'd forgotten to mention the David White series, which was excellent. Well worth hunting down indeed. -
Undoubtedly the Science Museum ship models are all in storage vaults somewhere in England.... I do not believe that they have been 'de-acquisitioned', or this would be public knowledge.
- 3,618 replies
- young america
- clipper
I, too, use the small rechargeable butane torch seen in the photo on the right. I have also used an oxy/propane torch with interchangeable tips in a jeweler's studio. For larger pieces this will provide more even heating more rapidly.
- 749 replies
- albertic
- ocean liner
It would be great if I could persuade folk to bend planks (by steam or dry heat) so that they would be shaped to 'sit' nicely along the hull without need for 'persuasion' by screws, clamps or other devices of torture!
Something like this from the RMG 'Collections' site? Object ID SLR2302 Description Scale: Unknown. A midship model showing a proposed method of hull construction with double-rigged iron frames and wooden planking. The model is made largely in wood with a planked hull and wooden frames to the upperworks. Two decks are depicted in frame, the main deck having a large hatch with a wooden edge. The deck beams are composite with wooden beams sandwiched between metal beams and with metal diagonal bracing. The deck below is identical in terms of composition and layout, but without the diagonal bracing. Two slender metal supports run vertically at either end of the section, fore and aft of the hatches, and terminating at the keelson. A paper label has been applied to the edge of the main deck hatch frame marked "15". Date made circa 1864 Read more at http://collections.rmg.co.uk/collections/objects/68261.html#SwHmmpfrbz0IJQCp.99
...aaand - down the rabbit hole you go! -
Not wanting to put you off, Gemma, but there's an awful lot to learn about naval architecture! One article that is helpful in basics was published many years ago in Model Shipwright. No's 22, 23. I'm PM'ing you information. -
Yes, that Longridge book is a nostalgic one for all the pre-war sources of materials that existed then. Unlike his Anatomy of Nelson's Ships, there is little on hull structure. A framed model of Cutty Sark would be a nice challenge for Gerald Wingrove! How about it, Gerald?
- 3,618 replies
- young america
- clipper
Very neatly done, Toni. I like the clerestory lights.
- 1,449 replies
Nice to see your progress, Michael. Enjoy using your new micro-torch with that beautifully engineered third hand. Is the torch oxy-propane?
- 749 replies
- albertic
- ocean liner
Longridge also had a two-volume book published on building the model.
- 3,618 replies
- young america
- clipper
Welcome aboard, Kiran. We look forward to seeing what you've been modelling.
PRINS WILLEM by juzek
druxey replied to juzek's topic in - Build logs for subjects built 1501 - 1750
Very interesting building techniques, Andrzej! Nicely done. -
Unlike the unfortunate Captain, I hope you return! She looks to be taking shape quite nicely now, Steven. You seem to have cornered the market for push pins.
That's remarkably good miniature turning on the Unimat, John!
- 30 replies
- philadelphia
- diorama
(and 3 more)
