Everything posted by druxey
THE BLACKEN-IT TRIALS
druxey replied to Erebus and Terror's topic in Metal Work, Soldering and Metal Fittings
Recently I've experimented with abrading the metal surface before blackening in order to avoid nasty chemicals. I've been using Scotch-BriteTM radial bristle disks that are 400-grit. These disks, in a rotary tool, make short work of getting to a clean metal surface. The flexible bristles get into nooks and crannies nicely. I use the same technique prior to silver soldering. -
Lovely, lovely. But Ed - with all your sophisticated tools, jigs and fixtures, you are still using a razor blade??? Try a #11 surgical blade in a surgical handle.
- 3,618 replies
- young america
- clipper
50-gun ship by newbee - 1/72 scale
druxey replied to newbee's topic in - Build logs for subjects built 1751 - 1800
Apparently the articles on the 50-gun ship also appeared in book form, along with two other models by R.J Collins (Myrmidon of the 1780's and a sixth rate of the 1680's). A search on abebooks might yield you a result. -
Thank you for these exhaustive test results, E&T. They are very informative. -
I don't know which you are better at: model making or photography! Both are excellent, Gaetan.
- 728 replies
- le fleuron
- 64 gun
ancre Le Fleuron by cabrapente - FINISHED
druxey replied to cabrapente's topic in - Build logs for subjects built 1501 - 1750
Now that was a lot of work! Very nicely done, Cabrapente. I particularly like the metal strops that you've made.- 332 replies
- le fleuron
- 64 gun
There are 5 sheets in the plan set, apparently. The how to model this subject was described in a series of 1953 Model Engineer articles by R.J. Collins. I believe that the plan set is still available (search on-line) and old copies of Model Engineer can be found on e-Bay. Happy hunting! -
Renshape for scratch builders
druxey replied to rshousha's topic in Modeling tools and Workshop Equipment
High density foams have been around for a while. I've used them in theatrical set construction in the past. They work very well for carving in detail but, as mentioned, are very expensive and only available in large chunks. My only reservation would be the longevity of the material, but for most folk this probably isn't a big consideration.- 11 replies
- scratch building
- parts
- (and 8 more)
Superb work, Ed - but now you've made me run out of superlatives!
- 3,618 replies
- young america
- clipper
Interesting thread. I recall visiting an English country church in my childhood. There was an ossuary in the undercroft with stacks of both femurs and skulls. I presume these had been disinterred from the churchyard to make room for newer arrivals (think of the graveyard scene in Hamlet).
Pete is correct: in the 18th century the copper strakes started at the keel and were laid parallel to it. This results in the highest strakes running out at an angle fore and aft at the waterline. On way the sharp ends were dealt with was with a wood batten nailed along the waterline overlapping the edges of the copper. Another, probably later, way was to run the top two strakes of copper along the waterline. See the photos of a coppered model of Bellona on the National Maritime Museum's 'Collections' site that shows the earlier method.
I like your pin-holes idea for maintaining position of the square on the building board. Good move!
- 889 replies
Card, ply; it doesn't matter which material the square is made from. The important thing is that it's not made of metal, so that if it falls over on the model it won't damage it.
- 889 replies
I don't think anyone gets this right the first - or even second - time around. Eventually you will nail it, Ben. I find that a heavy card square set up on the board aligned with the layout helps a lot.
- 889 replies
"What will they think?" That's a pretty powerful motivator, Ed, especially when you've set our expectations so high! But you've never disappointed us yet.
- 3,618 replies
- young america
- clipper
Sorry, folks, but I respectfully beg to differ. The planking runs at the bow don't look right to my eye. The garboard strake runs too far up the bow, causing crowding further up the bow (if it were the right way up!). See my sketch for what I think would be closer to the way it was done. Others have already commented on the plank butt scheme, which seems random to me. However, ultimately the result has to please the builder.
That last photo, with the height of the keelson, gives one a real appreciation of both the original ship's structure and your re-creation of it, Ed.
- 3,618 replies
- young america
- clipper
From contemporary models, the wash cants appear to be composed of planks laid diagonally, as Dan has shown.
what is the ideal modelling table?
druxey replied to AON's topic in Modeling tools and Workshop Equipment
Better smuggle your new stuff in using plain brown bags, Alan!
