Everything posted by druxey
Dan: I think that two generations of model makers have been a little misled by Longridge's (correct) assertion that the lines of these timbers converge to a point somewhere in the air. However, the shipbuilders (and we modelmakers) have no need to actually figure out this virtual vanishing point. All we need to know is the width across the wing counter and the spacing and sided widths of the counter timbers. We also need to know the width across the top timbers at the stern, then proportionally divide up that distance into the intervals and (now narrowed) sidings of the counter timbers. There is no need to figure out where that imaginary meeting point is.
- 1,215 replies
- sloop
- kingfisher
Fascinating discussion on the merits of water tank design! And great work as usual, Ed.
- 3,618 replies
- young america
- clipper
Too much! Next, it's be Phillips screw heads, then maybe even Torx.... It's madness, I tell you, Andy!
- 2,215 replies
Thanks for the scale slotted screws, Michael. I knew you could do them!
- 2,215 replies
Those are interesting figures, Gaetan. Thanks for posting them. I assume therefore that the slight acidity does not affect wood but is sufficient, in combination with UV light, to deteriorate rigging cotton, linen or silk.
- 3,618 replies
- young america
- clipper
Would Austrian archives possibly have information if these were captured ships?
HMS Naiad 1797 by albert - FINISHED - 1/48
druxey replied to albert's topic in - Build logs for subjects built 1751 - 1800
Well achieved, Albert! That's the most difficult part of the model done. -
You might wish to consider conservators' (microcrystalline) wax: it is colourless and pH neutral.
- 3,618 replies
- young america
- clipper
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
druxey replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
Your work always makes me smile, Doris. Dobri!- 883 replies
- royal caroline
- ship of the line
I suppose the screws for the hinges will be scale slot-headed ones as well? Those are lovely looking hinge knuckles, Michael.
- 2,215 replies
Looking ship-shape and Bristol fashion, Ben. You may wish to consider shortening those bolts so that they don't project above the keel, otherwise they will be in the way of the frames later on.
- 889 replies
I use an off-the-shelf bottle of deionized water. Usually I think it's intended for steam irons. Try your local supermarket household aisle.
- 346 replies
- terror
- polar exploration
You could order Jax brass blackening agent from Lacy's in Toronto.
- 346 replies
- terror
- polar exploration
What you do with modelling clay in small sizes is very, very impressive!- 883 replies
- royal caroline
- ship of the line
I use my blackening agent at between 8:1 and 10:1 with deionized water and get good, if slower, results. And no flakiness either. See if that helps.
- 346 replies
- terror
- polar exploration
Lovely work. I do notice, however, that in the photos the blackened surfaces look a bit blotchy. Try buffing with a soft cloth or Q-tip and you should get a nice, even low-sheen finish. Do protect the wood, though, now that the metal is in place.
- 346 replies
- terror
- polar exploration
Thanks for my smile for the day, Michael. Looks great!
- 2,215 replies
If you've never done cant frames before, don't be discouraged if you have to take more than one run at them. We all did the first (and sometimes the second) time! You'll be breaking out the isopropanol at some point with the best of us. But, with persistence, you'll win.
- 889 replies
Well done on those double-ring stanchions, Dan. Having done them myself, with much cursing, I know just how tricky they can be! Your solution looks great.
Your accurate mark-out of the building board will more than pay off soon! Nicely executed, Ben.
- 889 replies
Always a pleasure to see your progress, Gaetan! She's one magnificent monster of a model.
- 728 replies
- le fleuron
- 64 gun
Get the outline of the counter drawn out using a piece of tracing paper. Then play around on the tracing until the spacing and slope of the lettering looks right. Transfer the design back on to the counter using transfer paper. This is like graphite paper, only comes in different colours, including white. One can find transfer paper at craft stores like Michael's. Then you are ready to paint with confidence.
Now you are having altogether too much fun!
- 1,449 replies
