Everything posted by WBlakeny
To fix the bulkheads, i first made a cart template using the side which was not damaged. Afterwards i glued the template on the bulkhead. I then filled the voids at the corners with some wood filler. Once dry, i sanded the corners smooth. I remade the part that was to much damaged, using some old plywood i had lying around.
Hello everyone I'd like to start a new log for the Yamato. This kit is the one DeAgostini brought out a couple of years ago here in Belgium. I was able to buy this kit from anoter shipmodeller who had lost intrest in building her. He let her go for only 50 € so this was really a bargain This is what i got : I must admit i'm a little terrified of the adventure ahead of me, after watching the the superb logs and builds of Greg's Yamato and Carl's Musashi. The latter being the Yamato's sister ship. I hope i can do her credit by building a nice model of the greatest warship of her time.
What an enormous amount of details! I've started a Yamato by Deagostini and will be looking at your model a lot. It's so inspiring.
Hope you don't mind having me along. Interesting project! The Revell "Golden Hind" was one of the first models i've built as well, about 25 years ago.
- 756 replies
- galleon
- golden hind
Thank you Ray for the compliment!! And BIG thanks to you all for the likes and following my little boat.
- 144 replies
- corsair
- bermuda boat
I progressed on the cabin. I made the hatches. They were used to store the cooking gear and other stuff. First i had to make some dummy beams to provide some support for the hatches. I made those from some scrap plywood on which i matched the curve of the cabin walls. I glued them in place and let them dry overnight. After marking the middle of the cabin with the laser i placed some cherry planks. Then i filled the open spaces with the maple planks. I had to to taper 5 planks on each side in order to fill it up nicely. Then using a scraper, and sanding with different grits, I obtained a smooth result.
- 144 replies
- corsair
- bermuda boat
Thanks Christian It is appeasing indeed, although i have to do things a couple of times sometimes before i get it right.
- 144 replies
- corsair
- bermuda boat
MONTAÑES by Amalio
WBlakeny replied to Amalio's topic in - Build logs for subjects built 1751 - 1800
Wow. Superbly done. Beautiful... -
I've continued working on the cabin. I measured the place where the crossbeam must fit in the planks. Afterwards after sawing i glued both planks in place and let try dry overnight. I then made the tree pieces to cross the cabin. And glued them in place.
- 144 replies
- corsair
- bermuda boat
Thank you Bob. She's certainly starting to look like a boat
- 144 replies
- corsair
- bermuda boat
Some criteria for starting a new group project
WBlakeny replied to Chuck's topic in Group Projects on Model Ship World
I also would definitely join a group build on making figures. -
- 144 replies
- corsair
- bermuda boat
