Everything posted by knightyo
Just my 2 cents Joe, but if you've already done the Syren, this project would be a great next step. Especially since it's going to be done in this forum format with so many builder logs, and the teacher always within hail.
- 1,784 replies
- winchelsea
- Syren Ship Model Company
The planes will definitely be a challenge. It will also take a lot of time to install the appropriate RC gear so they can all be individually flown and landed on the flight deck.. Alan
- 345 replies
- graf zeppelin
- trumpeter
Whoever is trying to charge $100 USD for a 1/350 model should probably receive a kind note that they might want to think about reviewing their pricing structures. lol
- 345 replies
- graf zeppelin
- trumpeter
Welcome to the hobby! Since this is your first go, it might be a good idea to trace the bulkheads onto a very inexpensive, soft wood, and then practice planking the model with inexpensive soft wood planks. Maybe even over and over until you have the "feel" for how to do it. It's pretty easy to create test hulls to practice upon. Alan
Maybe even a V-1 and it's portable launching pad. How's that for interesting? 😀
- 345 replies
- graf zeppelin
- trumpeter
Greg, The below elevator looks incredible. It's really fun to see your work. P.S. Was there a specific book which inspired this build, or just an interest in alternate history in general? Alan
- 345 replies
- graf zeppelin
- trumpeter
It looks fantastic, Chuck. Alan
- 1,784 replies
- winchelsea
I've been sucked back into the plastic realm due to watching some of incredible plastic models being built on here recently (still need to finish my Syren/Triton/Nina, but that's beside the point ). I was in the hobby store the other day debating what type of primer to apply to my 1/350 Fletcher. I've stayed away from Vallejo due to the experiences that Greg has relayed in his log; the guy in the hobby store (who actually seemed extremely knowledgeable) said that he loved Mr. Surfacer, and used it for all of his work. Other's might chime in if they've used this product. For brass parts.. I picked up a package of 2 small brass rods at Lowe's (in nuts and bolts section) for around 8 bucks, and copied Greg's method of inserting them into wood blocks in the hull. It was extremely easy! (I used a 2-part epoxy to secure the wood blanks into the hull). Alan
Nice flight decks! I hadn't realized how long this was. You might need a new bookshelf!
- 345 replies
- graf zeppelin
- trumpeter
Greg, are you going to incorporate any lighting? That could help show off some of the internals.... Alan
- 345 replies
- graf zeppelin
- trumpeter
Another stunning model. I think it's now time for a carrier... They cost a "trifle" more, but think of the enjoyment the rest of us will have watching you work on her. 😀 Alan
RE the black paper caulking. He probably glued black paper strips on the edges of his planks. (Just one edge, as the "other" side of the plank receives it's caulking from its neighbor plank). I think the easiest and safest way to caulk is by coloring the edges with a graphite pencil. Alan
- 87 replies
- scottish maid
- artesania latina
Still fiddling with the finish on the main model. This morning I applied a 50/50 mixture of tung/mineral spirits to the "virgin" sections. We'll see how it goes. I also began cutting out my pre-soaked/bent "side ribs" to place next to the "ribs" on the bottom of the boat. Once the ribs have been installed, I'll cut the tops off of them on each side, as another plank will be running along the top of the inside of the boat under the rail. I'll also sand all of the ribs smooth and uniform. However... This morning when I began dry placing a few side ribs in the boat, I realized that all the ribs were far, far too wide! There's a part of me which wants to go ahead and install the rest of them, but the part that will win out is the part which knows that overly wide ribs will drive me nuts. Now the question is how to thin them. The bottom ribs have already been glued. It actually might be easiest to install them all, and sand them in place as opposed to trying to sand the remainder before installing.. They are so small, they are pretty hard to handle. Alan
Tung Oil "Experiment"
knightyo replied to knightyo's topic in Painting, finishing and weathering products and techniques
Bob, I'd heard that as well. I'm using Formby's. I'm not at home right now, but I'm pretty sure it isn't real tung oil. I have to admit I'd wondered if my model would spontaneously combust or not. Alan -
Excellent feedback. Thank you! I'll fiddle with what I've already done, then thin the oil with mineral spirits, and proceed according to the above instruction. Mark, no danger of glue spots on this one. I'd sanded the rails down with progressively finer grits until the last phase, which was done with a grit almost as fine as paper. I do wonder if the surface was "too" smooth, not allowing the oil to penetrate properly... Alan -
It looks like I have an interesting experiment on my hands (below). The right side of the back rail has had tung oil applied, and apparently the back rail received a few drops as well. The "splotchiness" of the finish has been an unfortunate surprise. I've been reading logs regarding tung oil; it appears that some people apply directly to the model at 100% strength, whereas others apply a 50/50 mixture of tung and mineral spirits. I suspect now that I should have applied a 50/50 mixture to avoid splotchiness. Thoughts? I've also heard that "more is better", and that splotchiness can be overcome with more coats. I can go that route, or apply mineral spirits now to remove what has been done to date. Thoughts? I'm not sure how to proceed. The frustrating thing is that I tested the tung oil at 100% strength on identically sanded samples, and none of them revealed the splotchiness effect. Just this rail. The sides also look acceptable with just the "shiyiness" aspect to address.... Alan
I've been attempting to draw out the deck planking pattern for my Triton project on graph paper which has worked out very well for me in the past. However, since the deck planks taper towards the bow/stern resulting in curved planks and planks with differing widths, my graph paper and pencil method has been leaving a lot to be desired. What would be the easiest software solution to fiddle with planking pattern design? I've been told Sketchup is the way to go since I have virtually zero drawing/CAD experience, but wanted to check with this group as well... Alan
