Everything posted by mtaylor
Can someone give me a run down of Santa Maria kits?
mtaylor replied to a topic in Wood ship model kits
I go along with Gregory... use the index and eyeball the buillds. You'll see what's involved and also get a sense of the pros and cons of each manufacturer's product. -
Wife says I needed a hobby in Texas!!
mtaylor replied to DAGGERZ's topic in New member Introductions
Years ago (maybe 10 or so), did the same thing anytime we took a road trip. While me lady did what she wanted, I fiddle with bits and pieces of model ship. -
MagEyes anybody use them ? Which ones and Y
mtaylor replied to NovaStorm's topic in Modeling tools and Workshop Equipment
Enlightening conversation. I read Y.T.s reference "review" an took a look. I do have a "no-name" magnifier visor but it's only one magnification and basically well-used and scratched up pretty bad. I'm looking at this one that was referenced" https://www.amazon.com/Yoctosun-Head-Set-Magnifier-1-5X-2X-2-5X-3-5X-Magnification/dp/B073RFZS94/ref=cm_cr_srp_d_rvw_txt?ie=UTF8 Looks like a reasonable set, to me and gives me choices on magnification. -
Great work, Eric. Looks like you even got the little view ports on the forward wooden shades.
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Sweet work, JCT. Looks super nice. I hope you will put her in a case. BTW, I love that jig for the ratlines when you're tying near the top.
Have you gone back to the topic that you posted on this before? There's answers to your question there. https://modelshipworld.com/topic/21147-blue-jacket-revenue-cutter/
The catch is, we moderators don't know if they've been abandoned. We've had builders who have had to stop due to family things and then one, two, three years later come back. No gold stars. We're pretty much non-judgement here as we have builders from super expert to beginners. As for searching... the downloadable indexes work well and will tell you which builds are "completed".
Proxxon jigsaw or a scroll saw
mtaylor replied to Edwardkenway's topic in Modeling tools and Workshop Equipment
I'll add one... There's more than couple excellent scratch builds on MSW where only hand tools were used. Could be money or perhaps they like the feel and ambience of working wood by hand. And some of us have power tools for the heavy work and then hand tools for the precision work. -
kit review 1:35 Viking Longship – 11th Century - Dusek Ship Kits
mtaylor replied to James H's topic in REVIEWS: Model kits
Looks like an interesting model. 60 to 100 warriors on it and with several, one see why the Celts would have this prayer: "“From the fury of the Northmen, O Lord deliver us.” -
Thanks for the likes. Pat, ribands are on the menu of "must do". Luckily, I had ordered more plywood last week as I suspected that if I didn't, Murphy would run amok and he did. Somehow, I had two sets of CAD drawings instead of one original and one copy to be transferred to the laptop running the cutter. <double facepalm time). Which means that many of frames were cut with the wrong CAD drawings. Steps have been taken to ensure this doesn't happen again: a good self flogging and a temporary reduction in the rum ration. Any way, when the wood gets here, I'll recut the frames that need cutting, make extra ribs (especially for the bow) and also sort out adding new ones to replace the 6-7 I have to remove for the gunports. I'm probably going to use a mixture if filler woods below the deck line such as balsa and basswood and possibly some much of scrap plywood to align the bulkheads and also strengthen and straighten the false keel. Now to be patient waiting for the plywood to arrive from Maine.
Update, finally. I've managed to do the false keel in one piece. Thank heavens for small favors on that one. I've also cut out the all bulkheads, managed to make the keel, stem, and sternpost. In the photos, are the false keel with the bulkheads simply fitted. I'm having a few "minor" issues with the framing bits breaking off but I'm working on a solution. As it is, 6 maybe 7 need to come off anyway due to being in the way of the gunports. I will say that I'm glad I'm doing her in 1:48 but 1:64. She's still a big girl. As for the framing bits breaking, I think I had too much "heat" with the laser and I've have some ideas which is the next couple of days project. I do need to cut "false" frame ends because like pointed out, many will get off for the ports especially the forward 6 bulkheads. I'll either cut new bulkheads (after modifying the framing bits or fix what I have. I'm hoping fixing works better rather than having to order more wood. Anyway, here's photos. So until next time...
Yves, If you can take the shafts apart, maybe sliding some shrink tube over them and couplers will work She's looking very good and very real.
Hi Michael, Pontiachedmark had some really good advice. Definitely a build log will help with your ships.
Don't feel bad. This project was my first scratch build also. Well.. actually I did a 1:24 cannon first, but I digress. I remember redoing the frames. As I recall, I did the first one about 3 times... then started the next one. I think by the time I was happy with all frames I could have built several models from the throw aways.
- 94 replies
- Triton
- first attempt
gun ports
mtaylor replied to Anthony Hearne's topic in Building, Framing, Planking and plating a ships hull and deck
Being a Corel kit and based on the instructions that Anthony has.... best bet without a lot work is just build it as the kit shows. But then again, I like bashing kits. -
Thanks for all the recommendations. I like Allan's idea and if I have cut anything bigger than I can laser, I'll give that try. I ended up with a small can of "Spray Mount" from Scotch brand after speaking with the sale person at the local office supply house. It's holding fine and when I'm done, a bit acetone should clean the wood up nicely for gluing bulkheads, etc. I think this is the only time I'll have to use it as I can laser the bulkheads (whew!) as I'm not the best scroll saw operator.
